3.7 nitrous - Mustang Evolution
Old 06-07-2014, 08:16 AM   #1
Sebas395's Avatar
3.7 nitrous
Hey I'm thinking about using nitrous but don't know what kit to buy. I never used nitrous before. Should I go with a NOS sniper kit? And do u have to have a tune with it?
Sebas395 is offline   Reply With Quote
Old 06-08-2014, 05:00 PM   #2
Sebas395's Avatar
Anyone?
Old 06-08-2014, 05:09 PM   #3
Ish416's Avatar
This is the kit I will personally be going with - 2011-2014 3.7L V6 Mustang Hard-line Plate System - Ford Systems - EFI Wet Nitrous Systems
and this - Brand X Stage 2 Accessory Package for 4AN Systems - Accessory Packages - Nitrous Accessories
There is nothing wrong with the NOS Sniper kits, I just think the two things I listed are of better quality and price. It is also made specifically for a 3.7 Mustang.
Yes you will need a tune. Depending on the size of the shot, you may need to go to a 1 step colder spark plug (copper or iridium, NOT platinum). Generally for every 75 shot of nitrous you should drop to a 1 step colder plug.
Old 06-08-2014, 05:12 PM   #4
Sebas395's Avatar
Would I need to delete my cats as well?
Old 06-08-2014, 05:13 PM   #5
Ish416's Avatar
You shouldn't need to. However, deleting them or going with higher flow cats wouldn't be a bad idea.
Old 06-08-2014, 05:14 PM   #6
Sebas395's Avatar
That kit is $700, the sniper kit is only $420 right?
Old 06-08-2014, 05:44 PM   #7
Ish416's Avatar
It looks like the Sniper kit goes for around $420. However, that is only about half of what you need.
You will need a window switch, a blow down tube, purge kit and bottle warmer.
Like I also mentioned, the Nitrous Outlet kit is specifally designed for the 3.7 Mustang. So all of the wiring, mounting points, etc, will be exact. With the NOS kit, you will have to figure all that stuff out yourself.
The Nitrous Outlet kit also uses a plate instead of a nozzle. The plate systems tend to produce better results as it atomizes the nitrous and fuel better than the nozzle systems.
Also, nozzle systems are more likely to cause fuel puddling in the intake, usually resulting in the upper intake and hood being blown off the car. This is the result of the fuel not being atomized well enough.
It's your money, buy what you want. I however, will be spending my money on the setup I listed.
nitrous
Running a bigger shot of nitrous / NITROUS GUYS Jsmorley81 2011-2014 Mustang GT 5 02-14-2014 01:31 PM
Nitrous Express wet nitrous kit Zim Mustang Parts for Sale and Wanted 24 06-15-2005 12:43 PM
getting nitrous MusclesFromBrussels Pre-2005 V6 Mustang 11 08-06-2003 02:43 PM
SC and Nitrous ERICK Pre-2005 V6 Mustang 11 07-21-2003 08:28 PM
Supercharger or Nitrous? ERICK Pre-2005 V6 Mustang 8 05-12-2003 02:41 PM
02:39 AM
