How to launch? - Mustang Evolution
Old 06-07-2014, 08:18 PM   #1
MustacheMustang's Avatar
How to launch?
Hello my 3Point7 Cycloners! I've been wondering how to launch in our vehicles but wasn't sure how to do it the right way, I've tried searching on youtube, no luck.
I know you kinda have to play around with it and find a certain rpm I believe. I have an auto trans.
I've been told by a gto owner that you have to hold the brake, find the sweet rpm spot then, let go of the brake and don't floor the pedal until you've shifted unto second. Any ideas would be appreciated so I can learn how. Thanks! V6 PWR!!
Sent from my SAMSUNG-SM-N900A using Mustang Evolution mobile app
MustacheMustang is offline   Reply With Quote
Old 06-07-2014, 10:12 PM   #2
Region: Alaska
With an auto you should be able to hold the gas wide open and the brake and not do a burnout. 2013/14s you can any way. Especially on a drag strip just floor both pedals and dump the brake.
CFYA2818 is offline   Reply With Quote
Old 06-07-2014, 10:37 PM   #3
Sanguin's Avatar
The speed at which you shove the accelerator down varies on a lot of things: hp, grip, gears. You basically want the tires on the verge of breaking loose so you get maximum traction. As long as you don't break them loose, you can give it gas faster.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 06-07-2014, 10:48 PM   #4
GrabberMeBlue's Avatar
I think he's talking about the 2013/2014 where the RPMs won't go any higher than 2000 RPM while doing a power stand, no matter how far you mash the gas.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 06-07-2014, 10:53 PM   #5
I know tunes can cancel this. Do you know if the FRPP tune can?
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 06-07-2014, 11:00 PM   #6
That I don't know. I only know that on a stock tune 2013/2014 Ford no longer allows you to get the RPMs up to do a power stand. Even turning off Advance Trac and Traction Control. I have a 2012, but I did read that Ford did this on the 2013/2014s. I think I might have first looked that up last year when I tried on my 2012 and found that mine did the same unless I turned off Advance Trac and Traction Control.
1979 Gold Trans Am
Old 06-07-2014, 11:03 PM   #7
Oh2freshstang's Avatar
Basically is just hold down the brake plus press the gas pedal to the desired rpms then let go of brake & hit the gas all the way!
Getting a good/perfect launch tho takes practice! U have to play with the rpms & find your sweet spot where ur giving it as much gas pedal as u can without spinning the tires!
When I had my 3.7 tune & CAI only I had the best launch at about 2.5-3k rpms.
Old 06-07-2014, 11:45 PM   #8
mark_ash0426's Avatar
Same here but about that RPM my tires start to break loose so i have to do about 2.3 2.5 max
Aye bro i might get those springs installed tomorrow ill put up some pics as soon as i get it done 👍
mark_ash0426 is offline   Reply With Quote
Old 06-08-2014, 12:20 AM   #9
Thanks for all the replies guys! I deeply appreciate it all. I do have a 13 base model v6. So ill have to give that launch control a try when there's no cops around. Haha thanks again!
Old 06-08-2014, 01:03 AM   #10
andrewheath09's Avatar
I wouldn't figure you would be worried about cops at the track. Because that's where you're testing it I assume. Cough. Cough. Lol
Sent from my SM-N900V using Mustang Evolution mobile app
andrewheath09 is offline   Reply With Quote
Old 06-08-2014, 02:57 AM   #11
Originally Posted by mark_ash0426 View Post
Same here but about that RPM my tires start to break loose so i have to do about 2.3 2.5 max Aye bro i might get those springs installed tomorrow ill put up some pics as soon as i get it done ddc4d
Dope! Yea def post pics bro!
Old 06-08-2014, 08:37 AM   #12
WipeYourEyes's Avatar
1. First gear
2. Hold break
3. Hold gas until 2,000-3,000 rpm
4. Let go of break
5. Shift 2, 3, D
WipeYourEyes is offline   Reply With Quote
Old 06-08-2014, 11:18 AM   #13
Sanguin's Avatar
When dragging, you let the car shift unless you have a manual valve body on the automatic. The car will shift better and more consistent than you ever will.
dump the clutch before launch? good advise? jones4stangs Pre-2005 V6 Mustang 2 10-26-2005 12:18 AM
How to launch on a 1999 v6 w/ 4.10 gears ntc432 Pre-2005 V6 Mustang 6 05-30-2005 08:25 PM
nice launch Warfire80 The Bar 6 05-21-2004 10:46 AM
Drag Launch Springs 02whitestang Pre-2005 V6 Mustang 1 11-22-2003 01:41 PM
.. Official Office 2003 System Launch Thread ...? ..... Yeah Laser02 The Bar 4 11-06-2003 02:14 PM
12:19 PM
