73mm Throttle Body - Mustang Evolution
Old 06-14-2014, 07:37 PM   #1
JoeyM91's Avatar
73mm Throttle Body
I know some folks already have this mod but after doing some research, the realistic gains from upgrading to the $400 throttle body are very minimal. Really, only an increase to low end throttle response.
It seems the upper intake would need to be ported or forced induction to see any gains and even then, minimal.
Any opinions on this? At the moment I think I'll get it, but it's very far down on the list.
Old 06-14-2014, 07:44 PM   #2
WipeYourEyes's Avatar
A throttle body spacer will give you more of an hp increase than a new throttle body
WipeYourEyes is offline   Reply With Quote
Old 06-14-2014, 07:49 PM   #3
No.
If you are wanting high end gains you won't find them with the TB but the low/mid range has shown definitive gains. Better for street use, not much use for high RPM racing.
LiveWire003 is offline   Reply With Quote
Old 06-14-2014, 07:51 PM   #4
Yes for right off the line 800 - 2500 RPM
Old 06-14-2014, 07:58 PM   #5
JoeyM91's Avatar
I will never put a spacer on mine lol. You get slightly more low-end but the swirling of the air in the intake creates turbulence on the top-end robbing you of more top-end power than it gives down low.
They were meant for trucks to give them more low end torque for towing.
BBK 73mm Throttle Body StewartL1189 General Mustang Discussion 14 09-10-2015 07:28 AM
73mm or not strike1980 Pre-2005 V6 Mustang 2 04-25-2005 09:16 AM
Body Kits, Body Kits, Body Kits! *DUW* *WW* Dom Mustang Audio & Video 75 02-01-2004 07:11 PM
How do you add a larger throttle body? gdcpony Pre-2005 V6 Mustang 15 09-22-2003 04:13 PM
Throttle Body Cleaning Bad??? 6erstang Pre-2005 V6 Mustang 31 08-15-2003 04:08 PM
» Members Mustangs
Pig
gtcpa
Lil6
austinh1999
Add your Mustang
04:48 AM
