Quarter mile times - Mustang Evolution
Old 06-20-2014, 10:19 PM   #1
Cruz_'s Avatar
Quarter mile times
What quarter mile times are '13-14 base V6 mustangs getting at the 1/4 mile times? And how about '13-14 GTs? Thanks in advance yall😊
Cruz_ is offline   Reply With Quote
Old 06-21-2014, 05:29 AM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Check out the At The Track section of the forums. Both answers can be found there. In fact, I believe the most recent thread is about 11+ GT 1/4 mile times. You can also use the Search function found towards the top right of the forum webpage. I've only had the chance to run an 1/8 mile so I couldn't really tell you my 1/4 mile time.
2012 Kona Blue 3.7L V6:
Old 06-21-2014, 10:50 PM   #3
From what I've read the V6's range from 13.8's to 14.2's while the GT's range from 12.5's to 12.8's, considering this is 100% stock (down to the tires). I'm hoping to get my V6 to the track soon and see what it does. I would imagine there would be some variation in the times compared by models because of the added weight of a fully loaded mustang opposed to a base. There was just a local guy here in NC with a stock powered 5.0 with radials and skinny tires up front break into the 11's.
It's really hard to base what a car is capable of compared to what people actually run especially with the GT's because when you have that much power the drive mod can make .5-1 second difference at minimum.
StarzTA17 is offline   Reply With Quote
Old 06-22-2014, 04:42 PM   #4
smurf stang's Avatar
Alot of variables on 1/4 mile times like.....
Driver mod (the most important)
Track conditions
DA
2016 VW GTI 2.0 Turbo
Old 06-22-2014, 04:55 PM   #5
JoeyM91's Avatar
Track conditions
DA
+1, Car and driver got the stock V6 at a best of 13.6, but that was with an experienced driver.
Old 06-22-2014, 10:03 PM   #6
GrabberBlue1993's Avatar
Stock would be about 14 seconds, throw a tuner and better tires on it and you'll be under 13.5 maybe even low 13's. Add a CAI, headers, throttle body, an aggressive tune and some suspension work with some really good tires and you'll even break into the 12's.
"At least it isn't a Honda"
GrabberBlue1993 is offline   Reply With Quote
Quarter mile times list mods Marc3.71994 2011-2014 V6 Mustang 16 01-22-2013 10:15 AM
Quarter mile times??.?.? SolidRRaxle At the Track 16 10-23-2012 11:59 PM
Quarter mile times 98projectpony At the Track 2 12-05-2011 09:34 AM
Quarter mile times MUSPOR911 New Member Introductions & Greetings 12 12-28-2010 01:03 PM
quarter mile times tigerfan2771 2005-2010 Mustang GT 1 12-28-2010 12:34 PM
10:46 PM
