Interior upgrade on a base - Mustang Evolution
Old 06-24-2014, 05:06 PM   #1
sunnytan06's Avatar
I have a v6 base model. Seeing people have the nice track apps and fancy readings I would really like to have one in my car. Does anyone here know how and if it's possible to swap one for my car? Thanks
sunnytan06 is offline   Reply With Quote
Old 06-24-2014, 06:56 PM   #2
It will cost you a pretty penny. Some of the things you'll need are a new dash panel to fit a double din receiver that has the apps you are referring to. The dash panel will run you around $250. Then you'll need a double din receiver that could run you anywhere from $350+. Further, you will need sync capabilities which will you could install yourself for $64. After everything is said and done you are talking over $1000. If you think it's worth it, do it. I would recommend having it professionally done though.
blp12 is offline   Reply With Quote
Old 06-24-2014, 07:11 PM   #3
rmb427r's Avatar
Also, I believe Sync corresponds with the VIN number. Since yours didn't come with it, I'm not sure it will work.
Personally, I don't think it's worth pursuing. Get some good gauges like Aeroforce which use the OBDII and a good head unit instead.
Ron..
2008 Roush 427R
2014 V6 Prem
rmb427r is offline   Reply With Quote
Old 06-24-2014, 08:36 PM   #4
Socal Stangman's Avatar
I believe he's referring to the gauge cluster. On my 2014 I have a display in between the gauges. That's where the tripometer is along with readings on some engine info. There are also track apps in...0-60 and braking is all I can think of right now, but I think there are around 4-5 different track apps on it. I don't believe it has anything to do with sync either.
Old 06-24-2014, 09:52 PM   #5
This might work for you:
How to install a 2013 Mustang Track Apps Instrument Cluster in a 2013 Base model GT
symon_say is offline   Reply With Quote
Old 06-24-2014, 11:03 PM   #6
sunnytan06's Avatar
Yea it's the cluster. Forgot what it's called. So no sync is fine
Old 06-25-2014, 09:37 PM   #7
wgolden30's Avatar
Interested in this
wgolden30 is offline   Reply With Quote
Mustang V6 base Speaker Upgrade paintmann111 Mustang Audio & Video 5 01-31-2014 05:03 AM
base model stereo upgrade GWraith Mustang Audio & Video 15 10-19-2013 02:34 PM
Base 13 V6 or Base 13 5.0 2011 Kona Blue General Mustang Discussion 68 03-12-2013 09:50 AM
2001 Base V6 Convertible Interior Indicators? wolverine9827 Pre-2005 V6 Mustang 2 02-09-2011 10:44 AM
02 base cd/cass, is car pre wired for mach460 upgrade? swgasteve Mustang Audio & Video 4 12-16-2006 05:57 AM
03:17 AM
