Problems with Bama Hybrid Tune - Mustang Evolution
Old 06-25-2014, 02:29 PM   #1
TedG's Avatar
I have a '14 V6 Auto with the Bama 93 octane Hybrid Tune. The tune is great 90% of the time. MPG is very good and intitial accelleration is excellent. The problem occurs at full throttle when I reach 5th or 6th gear and the car hesitates and loses the excellent accelleration. It's like it bogs down. I have sent this question to AM/Bama but I haven't received a reply.
Has anyone else experienced this problem?
Become an Organ Donor today: http://donatelife.net/register-now/
Save as many as 50 lives. Thanks.
TedG is offline   Reply With Quote
Old 06-25-2014, 02:37 PM   #2
bazinga11's Avatar
Yep I have had the same problem a few times. I have a manual tranny, and it used to jerk/hesitate under WOT. Keep an eye on your a/f ratio when it's misbehaving in gear 5
|| ~BlackOnBlack~ ||
Old 06-25-2014, 06:27 PM   #3
Jaylg86's Avatar
Yes me too! I'm running a R 93 tune from bama.. Been so busy with work havnt dealt with the problem
Jaylg86 is offline   Reply With Quote
Old 06-25-2014, 06:31 PM   #4
Jaylg86's Avatar
Sorry meant to elaborate more.. I feel it when I hit the gas hard.. The RPM's will fluctuate with a gradual loss of speed to only regain it self to continue up the RPM's .. I thought it was a gear issue but do believe it's a tune issue with gas and oxygen ratios.. I now need to figure out how to data log..
Old 06-25-2014, 09:03 PM   #5
JoeyM91's Avatar
Plug your tuner into the OBII port, select Data Log from the menu, start the logging and run your car as normal. It will create a file you use the SCT software to pull from the tuner and that's what you send Bama. But they can give you more in-depth directions if need be.
Old 06-25-2014, 09:10 PM   #6
wgolden30's Avatar
I have seen this too with my car, interested on results
wgolden30 is offline   Reply With Quote
Old 06-25-2014, 09:50 PM   #7
mikeygaga's Avatar
I'll go ahead and be "that guy" and say spend $75 on an mpt tune.. it's awesome.
2016 GT- Lund tune, jlt intake, mbrp catback.
2014 3.7 - SOLD
mikeygaga is offline   Reply With Quote
Old 06-25-2014, 09:53 PM   #8
JoeyM91's Avatar
Originally Posted by mikeygaga View Post
I'll go ahead and be "that guy" and say buy an mpt tune.. it's awesome.
Just got mine in today just for ****s and giggles. Runs pretty strong except they put a limiter of 105 mph for some reason, even though I asked to keep it removed . I e-mailed em.
Also considering Lund, $200, but they offer free revisions for modifications you do like Bama does.
Old 06-25-2014, 09:58 PM   #9
mikeygaga's Avatar
I'm pretty sure you can adjust the limiter in the beginning of the tune where it asks if you want to "adjust for changes" or something like that. I saw "speed limiter" in there as one of the options.
What shift setting or do you have manual?
2014 3.7 - SOLD
Old 06-25-2014, 10:21 PM   #10
Jaylg86's Avatar
I was using the performance 93 when I had issues, I swapped to R93 and did a couple 0-60 and I am pretty sure I solved it.. And my car wasn't surging so much.. So maybe it's the auto relearn or maybe it was a bad tune.. On a free day I will data log it
Old 06-26-2014, 07:20 AM   #11
TedG's Avatar
I called AM for Datalog instructions, and the rep asked what the problem was. I explained the bog-down when the car reached 5th/6th gears. The rep dismissed it saying that it was normal since 5th and 6th gears are overdrive gears and the true acceleration occurs in 1 through 4.
I don't know if I have a problem or not. 1 through 4 are excellent. I'm just not convinced by the rep's explaination, yet it does make some sense.
I'll just have to find shorter on-ramps so I only accelerate through 4 gears.
Old 06-26-2014, 07:33 AM   #12
I gave up on BAMA they are ridiculous. I am tired of waiting for answers and tunes. I finally got MPT and couldn't be happier. With MPT i did not even feel the need to log and send back the data for review. With BAMA even if you log and send the data you don't get reply for weeks. Its been about a month or more i bought a tuner and i still don't have a correct working tune from BAMA. AM is excellent but BAMA is just ridiculous now.
FordMustang12 is offline   Reply With Quote
Old 06-26-2014, 07:38 AM   #13
SixBanger's Avatar
No. While 5 and 6 are overdrive hears, RPMs should be steady throughout. There's no reason for your hesitation. But trying to accelerate in 6th isn't gonna happen anyways. If I put the pedal to the floor in 6th gear, RPMs and speed very slowly creep up, no hesitation or a/f problems.
2014 V6 Base Coupe, Sterling Gray Metallic///3.31 Gears///FP6 Appearance Package///Tech. Package///Reverse Sensing and Security Package///Mods: Boss 302 grille, MMD Ducktail Spoiler, Weathertech Floor Mats, Bassani Axle-Back Exhaust
SixBanger is offline   Reply With Quote
Old 06-26-2014, 08:14 AM   #14
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
This is correct. My car has 660 RWHP and is a manual, when shifting into 6th, the car completely falls on its face. After 4th gear these cars definitely struggle, 5th isn't as bad as 6th.
We can absolutely look into this further for you and see what we can come up with. The Bama team would be happy to help. Shoot me a PM with your order number included and I'll gladly have our head tuning specialist reach out to you!
Hope this helps.
-Dan
BAMA 93 Hybrid Tune with ghost cam Sterlingbeast5.0 2011-2014 Mustang GT 130 06-09-2014 03:42 PM
Bama hybrid tune vs race tune tq hp curve rick9550 2011-2014 Mustang GT 7 07-14-2013 06:54 PM
bama race tune > bama hybrid tune 13 stang22 2011-2014 V6 Mustang 11 04-16-2013 05:26 PM
hybrid tune vs. race tune 13 stang22 2011-2014 V6 Mustang 37 03-30-2013 08:38 PM
Dyno with Bama Hybrid Tune nosympathy 2011-2014 Mustang GT 13 12-07-2012 09:52 PM
12:51 AM
