2014 Water Leak - Mustang Evolution
Old 06-25-2014, 06:39 PM   #1
2014 Water Leak
Most people know that the 05-09 mustangs had the passenger side water leak. There was a TSB about it. Most people think Ford fixed the problem but they didn't. I just got my 2014 3 days ago and just found out it leaks as well. Pissed off is an understatement for me right now. So, check your cars whenever it rains. I spent over. $2,000 trying to fix the leak in my 06 and now my new 14 does the same thing. I've always liked Ford but I'm becoming more of a Camaro person every time it rains.
ThatsCoolBro is offline   Reply With Quote
Old 06-25-2014, 08:06 PM   #2
Where does it leak exactly?
Jwizzle is offline   Reply With Quote
Old 06-25-2014, 08:10 PM   #3
Any pics?
Thanks
Ranger052 is offline   Reply With Quote
Old 06-25-2014, 08:13 PM   #4
If you take off the panel right next to the SJB on the passenger side. It's coming from the top of where the A- pillar meets the dash. Feel underneath your carpet and the multi colored insulation might be wet. The leak comes from right above SJB
Old 06-25-2014, 08:24 PM   #5
Originally Posted by Ranger052 View Post
Any pics?
Thanks
Yeah I'll post them in a minute. My power went out and my phone died. It's been a bad day
Old 06-25-2014, 08:34 PM   #6
Name:	ImageUploadedByMustang Evolution1403749842.004736.jpg
ID:	160084Click image for larger version
Name:	ImageUploadedByMustang Evolution1403749863.925248.jpg
ID:	160085Click image for larger version
Name:	ImageUploadedByMustang Evolution1403749899.874916.jpg
ID:	160086Click image for larger version
Name:	ImageUploadedByMustang Evolution1403749913.012907.jpg
The multi colored insulation stuff is what is damp. The 3rd pic is looking up into the dash if you put your head under the dash by the SJB and just look up. The 4th pic is DampRid and it sucks the moisture out of the air and helps prevent mildew/gets rid of mildew smell. I used it in my 06 when it leaked and had no mildew smell.
Old 06-25-2014, 08:58 PM   #7
Thanks, i will check mine tomorrow since here in Miami is raining everyday
Old 06-25-2014, 09:00 PM   #8
2 Stangz's Avatar
Region: Nevada
Well... At least your Mustang starts up. Chevy can't even figure out an ignition system in these new slowmaros
Old 06-25-2014, 09:05 PM   #9
Haha yeah that is true. I called Ford as soon as I found out. My heart dropped and I could hardly talk I was so mad. I finally got my dream car exactly how I wanted it with a manual transmission and then it has to leak.
Old 06-25-2014, 09:06 PM   #10
Yeah, I live in SW Florida so we have been getting a lot of rain as well. Just feeling the top of the carpet isn't enough. You need to pull that panel away and try to find water. I only felt a little but enough for it to potentially rust the metal
Old 06-25-2014, 09:08 PM   #11
JoeyM91's Avatar
I haven't had any issues with leaking on mine. Granted it's an '11. Any holes or chunks in your weather stripping on the door frame?
Old 06-25-2014, 09:09 PM   #12
We are close then i am in kendall.
Old 06-25-2014, 09:22 PM   #13
Not that I can see or tell. I took the cowel off tonight to see if the grommets are not sealed. Apparently Ford now sprays over the heat sealed cowel grommets with paint and clear coat. The window weather stripping should be fine considering the car is only 4 months old. I was really hoping the leak was gone… I’m taking it to my dealership in the morning and if it’s still leaking after 3 trips, I’m gonna lemon it.
Old 06-26-2014, 07:51 PM   #14
Name:	ImageUploadedByMustang Evolution1403833751.751101.jpg
ID:	160143Click image for larger version
Name:	ImageUploadedByMustang Evolution1403833784.404641.jpg
UPDATE: Bringing car to dealer Monday. Meanwhile, it's down pouring. The 1st photo is taken above SJB and 2nd is underneath SJB. Carpet is dry but it's clearly leaking underneath carpet.
Old 06-26-2014, 08:08 PM   #15
rmb427r's Avatar
Damn, that stinks! Keep us posted and good luck getting that fixed. I too will keep an eye on mine.
Ron..
2008 Roush 427R
2014 V6 Prem
rmb427r is offline   Reply With Quote
Old 06-26-2014, 08:12 PM   #16
Yeah, it's too bad it's a 4 day old car. It's even starting to rust a little inside
Name:	ImageUploadedByMustang Evolution1403835140.631978.jpg
Old 07-04-2014, 05:58 PM   #17
Name:	ImageUploadedByMustang Evolution1404518207.610406.jpg
UPDATE: Dealer found leak. I showed them my pics of where it was coming in from. They said it was the cowl seam and so they applied sealer to cowl seam and the 10 grommets. They retested it and found no leaks. Hopefully there's no more water leak problems.
Old 07-04-2014, 11:22 PM   #18
nd4spd24's Avatar
Glad they found the leak for you. Hope it holds up.
nd4spd24 is offline   Reply With Quote
water leak 2014 GT wildwolf 2011-2014 Mustang GT 7 06-14-2014 07:07 PM
Water Leak ThatsCoolBro 2005-2010 V6 Mustang 8 11-27-2013 10:30 AM
Water Leak Kick Panel Area ThatsCoolBro 2005-2010 V6 Mustang 1 04-06-2013 11:20 PM
Anyone have a water leak? Mandy4 2011-2014 Mustang GT 48 08-25-2012 03:44 PM
Water leak! Pete08GT 2005-2010 Mustang GT 19 04-16-2011 01:50 PM
04:52 PM
