P1150 check engine code - Mustang Evolution
Old 06-28-2014, 11:56 PM   #1
wgolden30's Avatar
I just installed BBK long tube headers and Xpipe w/o cats and am getting a check engine code p0155 *title mistake.
I have two separate bama tunes with off-road Xpipe config am still getting issue.
What could be causing this?
I have a 14 with 20k miles
wgolden30 is offline   Reply With Quote
Old 06-29-2014, 04:51 PM   #2
JoeyM91's Avatar
Upstream (header located one) O2 sensor on your driver side is getting a heater short error. Went through a similar issue the other day. First check the plugs and harness to make sure everything is snug, then try removing the O2 sensor and check it for damage and reseat it, clear the DTC and run the car again to see if you get the error back up.
If none of that works, you'll likely need to replace the O2 sensor. It IS covered under the Federal Emissions warranty so you can take it to Ford. If they hassle you, call Ford customer service and they'll work with your dealer, or simply go to another dealer.
OR, if you don't want to go through all of that CJponyparts.com has Ford OEM O2 sensors for about $90.
Old 06-30-2014, 08:39 AM   #3
Site Sponsor
Sorry to hear about the trouble-Joey nailed it here and I would recommend doing what he had said before pulling the trigger on them.
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Old 06-30-2014, 05:59 PM   #4
wgolden30's Avatar
Update
Auto shop replaced o2 sensor. They said it was $215 but it was replaced free of charge.
Old 07-01-2014, 09:51 AM   #5
wgolden30's Avatar
Great now I have code p0030 what is that!?
Old 07-01-2014, 10:29 AM   #6
nhcowboy's Avatar
If you are on an iPhone.... You could probably google as easy as I did for "p0030 code". Lol.
http://www.obd-codes.com/p0030
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 07-01-2014, 10:31 AM   #7
wgolden30's Avatar
Yah I found it still not sure how this keeps happening
Old 07-01-2014, 10:38 AM   #8
wgolden30's Avatar
Is the shop causing these issues or is it my tune
Old 07-01-2014, 06:56 PM   #9
JoeyM91's Avatar
With all of these circuit issues the electrical harness may be damaged or perhaps the O2 extensions are faulty as well. As to whether the shop caused it or not, couldn't say.
Old 07-03-2014, 09:50 PM   #10
wgolden30's Avatar
the code p0030 was cleared and did not show for about 3 days then today it appeared.
i disconnected the battery for 15 minutes then retuned the vehicle from bama performance to hybrid.
hopefully that helped... dont know what to do once it comes back on any suggestions if it does?
Old 07-04-2014, 10:13 AM   #11
JoeyM91's Avatar
Check with BBK, another person that had similar issues called them up and asked about if the O2 extensions could have caused it, they said it was a possibility and sent him fresh ones.
You can try that to rule out the easy parts. Past that check out this and it should give you a better idea of what is going on if it's not the extensions:
P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
Old 07-09-2014, 10:10 PM   #12
wgolden30's Avatar
Where can I get the extension cables? I emailed BBK asking about them last week and haven't gotten a response.
Old 07-09-2014, 10:33 PM   #13
wgolden30's Avatar
nvm found them, damn they are expensive.... 50$ per extension.
BBK : 86-14 Ford 02 Wire Harness Extensions
Old 07-09-2014, 10:36 PM   #14
JoeyM91's Avatar
Call BBK before you go out and buy them, they may send you a pair for free. Also something you could try is swapping the opposite extension with the side that's having trouble to see if it follows that extension. Just make sure you use the upstream (header located ones) and not the downstream.
Old 07-11-2014, 09:17 PM   #15
wgolden30's Avatar
BBK said they are sending a free extension so that is good.
But now I have another code!!!
p2251
What's the deal, does everyone else have these issues? Getting fed up with all these codes.
Old 07-12-2014, 03:07 PM   #16
JoeyM91's Avatar
p2251
Still related and pertaining to the O2: P2251 O2 Sensor Negative Current Control Circuit/Open Bank 1 Sensor 1 OBDII Engine Light Trouble Code | Engine-Codes.com
It's electrical in nature so unless you got a bum O2 sensor when you had it replaced it's likely going to be the extension or perhaps the harness the extension connects to if it's somehow damaged.
check engine
Check engine code- p1443 embecker Pre-2005 V6 Mustang 7 05-12-2014 12:22 AM
having trouble help check engine light keeps coming on for the same code mustangsally696 General Car Discussion 2 08-18-2011 07:02 AM
2002 V.6 codes p0175 p1150 or p1151 LittleSue Pre-2005 V6 Mustang 1 05-12-2011 10:34 AM
check engine light misfire code 98stang460 1996-2004 Mustang GT 6 07-27-2010 08:27 AM
check engine light code help p0102 HELP! slow98gt 1996-2004 Mustang GT 1 05-21-2009 01:52 PM
09:22 PM
