8.8 gear swap mechanic questions - Mustang Evolution
Old 06-30-2014, 10:00 PM   #1
borteg227's Avatar
I went to my mechanic to get a quote for the gear swap (2.73-3.73) on my 2011 v6.
He of course was telling me about the difficulties on the job but he suggested me just buying the new spline to make his install easier? He thinks you can buy the slip with the new gears already so he wont have to do the shim adjusting. Just wanted to ask since I wasn't to sure if the was gona make the job "easier". Or even if thats how it works. Please thank you!
I initially was gona get the gears with the install kit for him to do job.
borteg227 is offline   Reply With Quote
Old 07-01-2014, 09:58 AM   #2
Sanguin's Avatar
I would find someone else. That throws all kinds of red flags at me.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 07-01-2014, 10:46 AM   #3
FastFord13's Avatar
+1
2013 3.7 Candy apple red metallic,
GT 500 stripes, painted side mirror covers, GT 500 spoiler, 2010 GT premium wheels with Pirelli P-zero tires, upper and lower front billet grille, Barton shifter bracket, Airaid Cold air intake, S.R lowering springs, J&M adjustable panhard bar, Boss 302 strut tower brace, 3.73 ford racing gears, Bama tuned, BBK shorty headers, Roush Axel backs.
Old 07-01-2014, 11:32 AM   #4
Cise's Avatar
+1 on find someone else
Cise is offline   Reply With Quote
Old 07-01-2014, 12:16 PM   #5
MustangDawg's Avatar
Yeah, you want a mechanic with some confidence about what he's doing. You want to hear: "Yeah, we can do that, do them all the time, piece a cake." Look for a mechanic that has done a lot of Mustang work. In your case, specifically the gears. You gotta get this one right the first time, no F'n aground
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 07-02-2014, 06:21 AM   #6
Abominable Mustang
WhoDat's Avatar
Region: Alaska
This "mechanic" knows nothing. Even if you buy the diff with the ring gear pre-installed, he would still have to shim the pinion gear and carrier, as well as properly set your preload and backlash. Definitely find a different shop to do your gear swap because that guy sounds sketchy as hell.
2012 Kona Blue 3.7L V6:
Old 07-02-2014, 07:41 AM   #7
I have a 2014 V6 six speed Manual Shift. I see some of you did a gear swap on your V6 going from a 2.73 to a 3.73.
What did you have to do to recalibrate the speedometer?
How big of a difference in acceleration and the "Fun Factor" did you feel after the gear swap?
How much did the gas mileage go down to in city driving, and in highway MPG?
Thanks!
GT 1 is offline   Reply With Quote
Old 09-15-2014, 06:48 PM   #8
Can the speedo be recalibrated after installing 3.55 or 3.73 gears without using an aftermarket tuner??
Old 09-15-2014, 11:16 PM   #9
Socal Stangman's Avatar
I'm pretty sure this question has been answered for you already...no you will need to have it recalibrated or use 3.31's so the dealer can do it.
Ford Mechanic or Your Mechanic 02_Mustang General Mustang Discussion 16 02-01-2013 04:53 PM
S197 mechanic / speed shop marietta, ga for HPDE car? PayDay General Mustang Discussion 0 06-08-2008 01:19 PM
Gear and axle swap questions. DarkShadow Pre-2005 V6 Mustang 15 09-07-2005 02:18 AM
*Attention Marylanders*ISO Good Mechanic Neptuno Regional Mustang Discussion 1 09-05-2004 07:30 PM
03:29 AM
