Best Replacement Front & Rear Speakers for 2014 Base Coupe base stereo - Mustang Evolution
Old 07-02-2014, 11:28 AM   #1
Exclamation Best Replacement Front & Rear Speakers for 2014 Base Coupe base stereo
For those of you who have actually changed out your speakers in your 2013 - 2014, what are the Best sounding speakers for a Base Coupe stock base stereo?
I only want to change out the speakers only, nothing else, no amps, no subs, no head units... simply replace the stock speakers with the Best sounding speakers for the stock base stereo.
Thanks!
GT 1 is offline   Reply With Quote
Old 07-02-2014, 11:37 AM   #2
willmorg19's Avatar
Depends on what type of music you listen to. The apline type-s 6x8 are great if your not going to use an amp.
willmorg19 is offline   Reply With Quote
Old 07-02-2014, 12:31 PM   #3
I Just had Infinity REF8602's put in the doors and the rear deck. I do have the Shaker 500 system, but have been told the only speakers that are actually amplified are the door subs. The Infinity's are very efficient speakers for no amp or low amp.
As the previous poster stated though, it is what you like, style of music, etc. I thought I wanted to replace with Kickers, until I went and listened to various speakers at an audio store. Even then, it was a while before I narrowed it down listening to my music. In fact, I liked the 8602's more than the more expensive Infinity Kappas. It comes down to personal preference.
Steve
'14 Deep Impact Blue V-6 Coupe
MCA Package
V-6 Performance Package
Premium Package
SRE TUS is offline   Reply With Quote
Old 07-02-2014, 04:37 PM   #4
NewMtang's Avatar
Depends on what you can afford. Also, you want the "Best Replacement Front & Rear Speakers for 2014 Base Coupe base stereo."
Did you think anyone on here was going to recommend the "WORST Replacement Front & Rear Speakers" for your car?
It doesn't matter whether you have a base model coupe.
Old 07-02-2014, 08:24 PM   #5
Ummmmm.....Good information.
texaskilowatt is offline   Reply With Quote
Old 07-03-2014, 10:34 AM   #6
Strange Mud's Avatar
I put entry level Focals in mine and am happy. From the systems I've heard unless you put in a Sub bass will be lacking (I prefer accuracy most) but anything is an improvement over the OEM kazoos. I suggest Crutchfield for great service and decent prices. Google Crutchfield coupon code too! I've had infinitys/clarion plates both are good speakers.
Old 07-04-2014, 09:34 AM   #7
I replaced front & rear with Hertz. Don't waste money on the rears as these don't get a full spectrum feed from headunit. Big improvement in midrange sound. But too bright at high end. I stream music from an Android device, so I adjust the highs with music player equalizer
2014 MCA convertible w/ Shaker 500
MapmanKC is offline   Reply With Quote
Old 07-04-2014, 04:48 PM   #8
Axe
I use an FM transmitter with my mp3 player in my work truck, an 03 Chevy 3500, and that sounds better then the stereo in my 2013 base v6. That's kind of pathetic, Ford.
Axe is offline   Reply With Quote
Old 07-05-2014, 10:42 AM   #9
Get a 4ch amp, a set of component speakers for the front door, or a good set of coaxial speakers and a 10" or 12" sub in the trunk, use 2 channels of the amp for the front speakers and bridge the other 2 for he sub.
symon_say is offline   Reply With Quote
removing mach460 amps/speakers, running new amp to door speakers with stock wiring? paradigm 1996-2004 Mustang GT 0 07-31-2013 04:04 AM
Need help with stereo and speakers. 94 GT 5.0 SVT Mustang 2 06-24-2013 04:00 PM
What size speakers fit in the front doors of a 1997 Ford Mustang Coupe? aodha Mustang Audio & Video 2 03-10-2010 01:15 AM
I am looking for Mach 460 front speakers and rear amp a3705872 Mustang Audio & Video 9 11-07-2009 05:10 PM
2002 Ford Mustang 3.8L base (not the mach audio setup) need to know the size of DOOR speakers? duck-young Mustang Audio & Video 3 08-20-2009 04:24 PM
10:05 AM
