Strange Noise - Mustang Evolution
Old 07-05-2014, 12:27 PM   #1
Strange Noise
Hi all,
So I have a 2014 V6 automatic with a 91MPT tune, 3.55's, aluminum drive shaft, and cold air intake. About a month after having the gears and drive shaft replaced and switching to the 91 tune there is a strange noise that occurs sometimes when I press the throttle to accelerate. From under the front of the car there is a raspy scratching.....it is really hard to describe but it only happens when pressing the throttle. It can be heard alongside the regular engine noise. I am waiting for a response from MPT and I won't be able to re program the car to stock for a couple days. Any ideas? Can a tune change engine noise? It doesn't sound too alarming but it doesn't sound normal either.
motorcity87 is offline   Reply With Quote
Old 07-06-2014, 12:18 AM   #2
iantrusive's Avatar
Maybe there's a raccoon living down there and it doesn't like when you move the car because it can't sleep. It scratches the car hoping the large mechanical creature will change it's mind about moving. Trust me I'm a car expert.
iantrusive is offline   Reply With Quote
Old 07-06-2014, 12:20 AM   #3
wgolden30's Avatar
I hear this type of noise also does it sound like a rattle?
wgolden30 is offline   Reply With Quote
Old 07-06-2014, 04:24 AM   #4
blackhawk 1's Avatar
some thing wrong w/ the drive shaft
blackhawk 1 is offline   Reply With Quote
Old 07-06-2014, 10:18 AM   #5
Great....I wonder how they screwed up a drive shaft swap.
Old 07-06-2014, 08:02 PM   #6
Getn off's Avatar
More likely the cai. Exacerbated by the tune...adding more air because of the demand for more fuel. That is the indication that u need a louder exhaust!
Troy
---------- Post added at 10:02 PM ---------- Previous post was at 10:02 PM ----------
Troy
Getn off is offline   Reply With Quote
Old 07-06-2014, 08:35 PM   #7
JoeyM91's Avatar
With the stock driveshaft I have a bit of that on DECELERATION but not on acceleration. I would agree, they may not have torqued the driveshaft correctly.
The CAI would be more of a rumbling and then a slight whistle than a raspy scratching.
Old 07-07-2014, 04:46 PM   #8
Getn off's Avatar
If it was ds related, it would be heard both under accel, and coasting...
Betting it's the cai.
Troy
Strange sound at engine startup? 3.7 also a steering noise. alludc 2011-2014 V6 Mustang 12 08-13-2012 08:48 AM
Strange noise Ryan7racin 1996-2004 Mustang GT 12 04-15-2012 06:24 PM
strange clutch noise R1CK3R Pre-2005 V6 Mustang 10 10-02-2009 10:47 PM
Strange Noise HELP 19ClearCobra96 1996-2004 Mustang GT 10 09-26-2005 01:29 AM
Strange noise....fuel pump? Ghostbuster Pre-2005 V6 Mustang 12 06-17-2005 11:01 AM
09:56 AM
