Preparing for the Autobahn - Mustang Evolution
Old 07-05-2014, 09:14 PM   #1
rotors's Avatar
There is a possibility that I may move over to Germany depending on what my options are reenlisting and I had some questions about making my V6 Autobahn ready. I am installing a one piece drive shaft however what else needs to be done if I plan on driving it at high speeds? What tires should I switch to? Do I need to change the brake system? Anything else I should do? I will be taking the governor off which is why I got the one piece drive shaft. Thanks!
rotors is offline   Reply With Quote
Old 07-05-2014, 09:36 PM   #2
JoeyM91's Avatar
Well the first thing you should look into is how much is actually costs to ship a car overseas the right way. The answer is A LOT. Not sure if the military helps you with that or not. It's also a very slow process.
Now to your actual question: Yes to the driveshaft and yes to brakes. The stock brakes, especially if you have the non-Brembo Performance package suck. Now you don't have to go out and get the $2000-3000 big brake kits, a good rotor and pad swap will give you a nice boost in bite. I recommend the Powerstop Street Warrior kit. ~$400 for all four rotors, pads and hardware.
As for tires, look for something with high speed ratings (google tire speed ratings so you know what to look for.) You'll want something grippy, especially if you take it around the mountain roads/hairpins up there. Look through some reviews.
But if you do plan for mountain roads, you'll also need to look at some suspension work. Struts/shocks, springs, panhard bar, sway bars and a good strut tower brace should firm it up.
Old 07-05-2014, 09:50 PM   #3
rotors's Avatar
Awesome! Thanks for the info, yes the military will ship cars for free.
Old 07-05-2014, 09:50 PM   #4
Just remember the Autobahn isn't open speed everywhere, there are lots of parts of it with limits, so don't expect that you will be going 160 all the time.
Old 07-05-2014, 10:03 PM   #5
AJcruz1's Avatar
I've lived there and I'm also in the military. While I didn't have a 11-14 mustang while I was stationed in Germany, I did have my 06 GT vert. So a lot of the same principles will apply. You will need a driveshaft and better brake pads and rotors. I would change out the brake lines to stainless steel ones but not a must. You might also feel you need suspension upgrades as I did but its not necessary. I just felt like the car was more floaty at high speeds with the stock suspension.
AJcruz1 is offline   Reply With Quote
Preparing for a Procharger... Missxalii General Mustang Discussion 0 06-05-2013 08:24 AM
2012 Shelby GT500 Masters the Autobahn M3hunter 2011-2014 Mustang GT 6 02-03-2013 08:02 AM
preparing for a kenne bell 2.1 supercharger allen1998gt SVT Mustang 0 08-20-2012 11:54 AM
06:02 PM
