New axlebacks, and horrible mpg - Mustang Evolution
Old 07-06-2014, 11:44 AM   #1
StolenSinner09's Avatar
The most recent mod I've done to my car was install a set of Pypes Pype-bomb axlebacks, and now I'm literally watching my fuel gage needle go down when I drive, and I'm driving ever so lightly. I can't figure it out. I just got an alignment so my wheels are straight. I checked my pressure today and it's good. Even threw in a new filter recently. Oil is still good, the only thing that should lower my mileage is the use of the HVAC since it's summer, but not this drastically. If I'm correct, in theory, a less restrictive exhaust system should make for better fuel economy. So why does my car drink like a Shelby?
StolenSinner09 is offline   Reply With Quote
Old 07-06-2014, 11:56 AM   #2
Modern cars are very tweaked right from the factory for great fuel economy. I have always got worse economy whenever I removed the stock mufflers. Some of it is you driving harder to hear your mufflers some is lost power in the lower RPMs where the motor used to be most efficient.
chitownpete is offline   Reply With Quote
Old 07-06-2014, 12:15 PM   #3
Socal Stangman's Avatar
I do t believe there is any correlation between gas mileage and a muffler. A muffler has absolutely nothing to do with mileage. The only way is that you really like the sound so you get on it more often. In modern cars running the AC also has very little to do with gas mileage. Now they are so efficient that most of the time you wont notice much with the AC on or off.
Old 07-06-2014, 12:34 PM   #4
Siber Express's Avatar
There actually is a correlation between Exhaust and MPG, on my 2010 taking off the Stock Muffler and putting on a single GT muffler increased it by 2 MPG. I also lost Mileage when I put the Magnaflow Competitions on my 2013, the motor has to work harder to get up into the much higher power band thus using more gas. Putting the Shorties on I gained about .5 per gallon which I think is from the motor working less in the lower RPM's.
To the OP, cruising RPM is well below the Powerband so I think it is from just working harder. After I tried the Magnaflows and lost so much on the lower end everything I have done to my exhaust was to keep or increase the low to midrange, and my car gets better Mileage now than it ever has.
Old 07-06-2014, 12:56 PM   #5
I'm no engineer or anything but what are we talking about here anyway? Were you getting 23 and now you're getting 15? Or did you go from 20 to 18? I've done a lot of cat backs on vehicles and to say that it changed my milage, I don't think I can. If it does have any affect I'm guessing it's very minor.
Old 07-06-2014, 01:01 PM   #6
I reset my Avg. Mpg calculator, reads normal, but I burned a quarter of a tank yesterday from only 30 miles. Just casual driving, not pushing the engine or anything.
Old 07-06-2014, 01:02 PM   #7
So where is your avg mpg at now? I installed my pype bombs about 3 weeks ago and I haven't noticed a change in mpg, unless I'm really stepping on them, then I can see a drop or two.
Dcansmack is offline   Reply With Quote
Old 07-06-2014, 01:11 PM   #8
curtin1991's Avatar
Send a message via ICQ to curtin1991
Our motors use depend on some back pressure. Pype bombs are pretty free flowing if I remember correctly .
My mpg seemed to drop 1 or 2 mpg when I got the Roush ab. It may have been from giving it a little more to hear it more. But I did see a small change after I got them a year ago. I also noticed after adding the CAI that the sweet spot for shifting was just a tad bit higher. Maybe it's just me watching to closely but it's what iv noticed.
Corey
curtin1991 is offline   Reply With Quote
Old 07-06-2014, 01:12 PM   #9
I lost 3 MPG with the Magnaflows over 2 tanks of gas, that was even after disconnecting the battery to relearn the idle and extra flow.
What I have figured out on my 3.7 is it is sensitive to small changes and really sensitive to large ones. It is probably the most sensitive to change over any motor I have had in my 35 years of driving.
Old 07-06-2014, 01:44 PM   #10
UltArc's Avatar
I didn't see any loss in MPG from AB, but getting on the noise is much more appealing...aka, I do it more. AC will definitely influence it. Our system kind of pulses and slows, but it still hits pretty hard. I'd have to check from the testing I did when I first for the car.
Sent from my XT1049 using Mustang Evolution mobile app
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline   Reply With Quote
Old 07-06-2014, 01:59 PM   #11
FastFord13's Avatar
Might be your right foot causing the mpg loss.
2013 3.7 Candy apple red metallic,
GT 500 stripes, painted side mirror covers, GT 500 spoiler, 2010 GT premium wheels with Pirelli P-zero tires, upper and lower front billet grille, Barton shifter bracket, Airaid Cold air intake, S.R lowering springs, J&M adjustable panhard bar, Boss 302 strut tower brace, 3.73 ford racing gears, Bama tuned, BBK shorty headers, Roush Axel backs.
Old 07-06-2014, 02:09 PM   #12
JoeyM91's Avatar
I would go with this one. The mufflers aren't going to give any semblance of a noticeable power increase. You're talking MAYBE 1-2 HP. What that means is the engine isn't working so hard that it's drinking that much gas. The 3.7 is already a fairly efficient V6 for it's class.
The loss in back pressure will also be tiny going from stock to free-flow. The only way I could see a real MPG drop is if you were silly and straight-piped.
When I did my catback I noticed a change in my MPG, but that was simply because I wanted to hear it more. Driving it like a granny, I saw no difference. I saw some difference when I installed my LTs, but that was positive. (~1-2 mpg) just from a better flowing exhaust.
Old 07-06-2014, 02:19 PM   #13
I'm not driving aggressively. That's the thing.
Old 07-06-2014, 02:22 PM   #14
FastFord13's Avatar
It won't be your AB causing that much of a mpg drop. If your not driving it harder than usual I'm not sure what could cause that much of a mpg drop.
Old 07-06-2014, 02:29 PM   #15
I don't know either man. It's just aggravating...
Old 07-06-2014, 02:32 PM   #16
JoeyM91's Avatar
Did you get gas at a different station than usual? Or get a different Octane level than you normally do?
Past that, you can pull Fuse 47 and leave it out for about 10 minutes and then replace it. It will let your Adaptive Learning system re-calibrate when you start it up again and drive it.
Also, double check your work on the ABs and make sure everything is snug down and there are no exhaust leaks.
Old 07-06-2014, 02:33 PM   #17
sunnytan06's Avatar
Maybe you got a bad tank of gas?
Maybe the temperature change due to the season?
sunnytan06 is offline   Reply With Quote
Old 07-06-2014, 02:42 PM   #18
Old 07-06-2014, 02:46 PM   #19
Hah! I had exhaust leaks with the stock mufflers, but better mileage, not saying the ABs are the cause but knowing just makes it more bizarre.
Last place I filled at was Valero, 87 octane, like normal. Oh. And I used Lucas Fuel system cleaner couple weeks ago too
Old 07-06-2014, 06:07 PM   #20
JoeyM91's Avatar
That can be part of it, the fuel cleaner also boosts the octane temporarily. Might have ran better during the period you had that in the tank.
Old 07-06-2014, 06:31 PM   #21
rmb427r's Avatar
Gonna watch this thread. Interesting topic. Please post up if you find the problem, if there is a problem.
Ron..
2008 Roush 427R
2014 V6 Prem
rmb427r is offline   Reply With Quote
Old 07-07-2014, 09:57 AM   #22
Combination of :::::::
Summer formulated gas ( CRAP) and the Air Conditioner on all the time. You live in Texas where it is really hot. They do change the additives in the gas in the summer. I live in Florida and they do the same thing here. Actually they do it all over America.
Plus the air conditioner take more power to run.
PS: Check this out>http://auto.howstuffworks.com/fuel-e...ummer-fuel.htm
Old 07-07-2014, 10:07 AM   #23
Strange Mud's Avatar
I would bet against AB's causinng any significant mpg change. do a couple of tanks using math and get back to us.
Old 07-07-2014, 10:12 AM   #24
Just topped her off. I'm gonna stretch her legs and take a drive down to Austin, cruise control 75mph all the way and reset my avg mpg. If all is good, I should be able to make that drive to Austin and back using just a little over half a tank.
Old 07-07-2014, 10:34 AM   #25
Loc: Austin,TX
A/C sucking gas is a myth busted .
Old 07-07-2014, 10:39 AM   #26
Old 07-11-2014, 02:34 AM   #27
Sakib's Avatar
Update?
Sent from my HTCONE using Mustang Evolution mobile app
Sakib is offline   Reply With Quote
Old 07-11-2014, 02:55 AM   #28
bucko's Avatar
It would be some work, but if you really thought the performance axle backs are the cause, put the stock ones back on and run it for a tank full. That will eliminate or prove your theory (or thought) that the new ones are the culprit of your recent poor fuel mileage.
Even with the summer blends of gas, and the more usage of the AC (in which I agree with DDTCM that the new ones do not draw a significant amount of power off of the engine anymore), your lower fuel mileage symptom is baffling.
By chance did you install a tune at or around the same time? The stock tune will do some minor tweaking to the fuel/air mapping, but not to the point where you'd be seeing a 5 to 8 MPG loss I'd think.
I have a 2011, with a set of GT500's, some suspension mods, and a 91 MPT tune; my MPG average is sitting at 22 MPG. That's with a lot of afternoon 5:00 PM rush our stop and go traffic. If I get it on the highway cruising, I have seen averages of 26 MPG.
I also have a 3:31 rear gear setup. What's your rear gearing?
Old 07-11-2014, 02:55 AM   #29
bucko's Avatar
I have a 2011, with a set of GT500's, some suspension mods, and a 91 MPT tune; my MPG average is sitting at 22 MPG. That's with a lot of afternoon 5:00 PM rush hour stop and go traffic. If I get it on the highway and cruise, I have seen averages of 26 MPG.
Old 07-11-2014, 07:36 AM   #30
I thought my results posted but I guess the app dorked out...
Anyway, at 75mph on cruise control, I got an average of 25.6mpg. It burned a little under half a tank. 87 octane from Chevron.
To Bucko, I didn't get a tune and my gearing is still stock.
Since I took that drive, driving around town I've been getting 19.2mpg, but I'm not burning as much gas as before. So it was either poor fuel quality from Valero or maybe she just needed to stretch the legs out. I dunno. I'm still stupefied about it.
Old 07-11-2014, 12:52 PM   #31
Sakib's Avatar
UltArc is the fuel economy guru on this forum. He gets like 40-50 mpg and is an active member of some eco-modding group. He has Roush axle backs. I don't know whether the type of axle back is going to make much difference. But the fact that he has an after market axle back and is the biggest stickler for fuel economy here gives me confidence that the muffler is not the source of your problem.
Old 07-13-2014, 12:03 PM   #32
mrcronin04's Avatar
I still say it's running the A/C. When I got mine in April didn't need the A/C and was getting 26.5-27 mpg. Come May and started to use the A/C I noticed it drop into the low 25s.
Stopped using my A/C and it went back up. Now just always have the windows down. Lol
2012 Performance Package V6
Airaid CAI
93R BAMA tune
14.432 @ 103.34 mph
First time ever running a 1/4 this was my second pass. 60' times were pretty high. Will only get better with practice!
mrcronin04 is offline   Reply With Quote
Old 07-13-2014, 07:30 PM   #33
Valero gas has always caused any car I've owned to run pretty poorly.
CUBuffalo is offline   Reply With Quote
Old 07-13-2014, 11:41 PM   #34
I have the Roush axle-back and I notice no difference in gas mileage.
mkashew is offline   Reply With Quote
Old 07-14-2014, 12:00 AM   #35
DaBluedude's Avatar
Waow there is a lot of bull**** in this thread... Your mileage did not appreciably change by changing or removing a muffler. It could have gone down because you get into it deeper. My guess is you swapped the mufflers on a tight budget and now that you're strapped for cash, you're feeling it at the pumps and that's making you look for an answer as to why your wallet is so empty. Guaranteed, your new mufflers did not change your fuel economy.
2003 Mach 1
Mustang misses, smoking and, getting horrible mpg tdye369 Pre-2005 V6 Mustang 19 06-28-2014 08:39 PM
05-09 GT mpg vs 99-04 GT mpg GP3GT 2005-2010 Mustang GT 10 05-03-2013 03:08 PM
v6 horrible mpg and preformance tommygrubb2001 Pre-2005 V6 Mustang 31 02-22-2013 04:19 PM
MPG-MPG insidious_ruin 2011-2014 Mustang GT 26 07-19-2012 07:18 AM
LOL!!! this is horrible but funny at the same time... Zim The Bar 3 01-06-2004 04:42 PM
01:07 PM
