Mt-82 GOING OUT? - Mustang Evolution
Old 07-06-2014, 10:57 PM   #1
G3racing's Avatar
Mt-82 GOING OUT?
Okay so when i shift from 2-3 over 6k it wont go into gear it just grinds it if i double clutch it goes in.
under 6k it shifts fine! what do i do i have a 2014 stang no warranty
2014 Mustang V6 Manual
AMR Charcoal Wheel & NITTO Tire Kit - 20x8.5
G3racing is offline   Reply With Quote
Old 07-07-2014, 02:18 AM   #2
Region: West Virgina
The shifter is junk from what I hear. I have experienced that a couple times with mine, but I usually don't go all that high in rpms because I can shift earlier and bark the tires all the way to 4th so I think I am putting down the power better shifting quicker than 6k but maybe the mgw shifter would solve that? why do you not have a warranty?
2013 Gotta Have It Green Gt, stock with American thunder axle backs, 6-speed
Green5.0 is offline   Reply With Quote
Old 07-07-2014, 03:17 AM   #3
iantrusive's Avatar
This might help.
http://www.whiteline.com.au/product_..._number=KDT928
iantrusive is offline   Reply With Quote
Old 07-07-2014, 04:29 AM   #4
Strange Mud's Avatar
I wpuld try swapping out fluid either Redline MTL or BG SS....good luck
Old 07-07-2014, 10:50 AM   #5
G3racing's Avatar
because turbo
Old 07-07-2014, 05:39 PM   #6
JoeyM91's Avatar
Sounds like you haven't disabled Skip-Shift. Goes from 2nd to 4th I believe, someone with a manual can verify.
Old 07-07-2014, 05:58 PM   #7
FastFord13's Avatar
^^I have a 13 manual and have no idea what this is nor have I ever experienced it. I can red line through the gears with deactivating anything, I just 99.9% turn of the advance track, that's it, that being said its not the first time I've heard of this. Op sounds like your getting "lock out" which will happen with that factory pos of a shifter bracket. It used to happen to me from second to third under load. A simple Barton shifter bracket fixed my issue 99.9%. I'll post a video of how crap this factory bracket is.
2013 3.7 Candy apple red metallic,
GT 500 stripes, painted side mirror covers, GT 500 spoiler, 2010 GT premium wheels with Pirelli P-zero tires, upper and lower front billet grille, Barton shifter bracket, Airaid Cold air intake, S.R lowering springs, J&M adjustable panhard bar, Boss 302 strut tower brace, 3.73 ford racing gears, Bama tuned, BBK shorty headers, Roush Axel backs.
Old 07-07-2014, 06:03 PM   #8
FastFord13's Avatar
Why the 2011-13 Mustang GT shifter is worthless: http://youtu.be/XynDGixQNhs
Old 07-07-2014, 06:06 PM   #9
FastFord13's Avatar
I'd started with just the bracket and would have done the mgw as well if the issue persisted, but the bracket cleaned it up real nice, I still will do the mgw in time but the bracket is definitely worth it! Hope this helps.
Old 07-07-2014, 07:04 PM   #10
G3racing's Avatar
i have a manual.....
---------- Post added at 08:04 PM ---------- Previous post was at 08:03 PM ----------
I have the barton two post bracket it helps alot but i think its the synchro
Old 07-07-2014, 07:08 PM   #11
FastFord13's Avatar
I also went with Royal purple but I'd have to agree, if you've done the bracket already, it might just be the synchro. : (
Old 07-07-2014, 07:19 PM   #12
G3racing's Avatar
FORD DEALERSHIP said they would have to replace the entire tranny just because synchro went out wtfffff
Old 07-07-2014, 07:55 PM   #13
Sanguin's Avatar
It's easier to drop a trans out and throw a new one in, than wait on someone to remove it, tear it down, and fix the synchro, then reinstall. Why complain?
I'd prefer a new trans over a rebuild anyway.
---------- Post added at 09:55 PM ---------- Previous post was at 09:55 PM ----------
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 07-07-2014, 08:01 PM   #14
somedopebeats's Avatar
Name:	ImageUploadedByMustang Evolution1404784787.717793.jpg
Stock bracket(left) vs sr performance bracket(right)
As you can see theres quite a difference. Look close, see those?.. Yup ZIP TIES!
somedopebeats is offline   Reply With Quote
Old 07-07-2014, 08:02 PM   #15
****ty buzz, but ultimately its a score for you. Brand new tranny, who can complain about that?
Old 07-07-2014, 08:08 PM   #16
FastFord13's Avatar
You said no warranty because of turbo!? Are they willing to replace it free of charge?
Old 07-08-2014, 01:13 AM   #17
Hey G3, it would help a lot if you would put your mods in your sig. Like turbo, shifter bracket or anything else you have done so you wont get so many comments like you need a bracket, since you already have one.
Old 07-08-2014, 09:28 AM   #18
G3, that sux (as if you didn't know) time to unload it?
side note: brackets/shifters/motor mounts help with blocking NOT grinding. Fluid MAY help with that.
Old 07-08-2014, 11:39 AM   #19
13BKV6's Avatar
i have the same issue in my 13 V6 manual.... will be trying bracket.... how hard is it to replace?
Current: 2015 GT Premium Performance Package-stock for now
Past: 13 V6, 11 MCA V6, 89 GT, 88 GT, 04 V6
13BKV6 is offline   Reply With Quote
Old 07-08-2014, 01:32 PM   #20
Its not too bad, just a pain in the *** cuz theres minimal room to work. You shoulf check these out, re-uses stock bracket http://www.energysuspensionparts.com...4.1134#reviews
Old 07-08-2014, 04:27 PM   #21
13BKV6's Avatar
Originally Posted by somedopebeats View Post
Its not too bad, just a pain in the *** cuz theres minimal room to work. You shoulf check these out, re-uses stock bracket Energy Suspension 4.1134 Shifter Stabilizer Bushings - Mustang Made by Energy Suspension
will look into it! thanks!
Old 07-08-2014, 06:14 PM   #22
I was thinkin about gettin one myself and ditching my aftermarket bracket. The reviews are really good
Old 07-08-2014, 10:59 PM   #23
Black12's Avatar
Your not shifting correctly. Leave the line by hitting the resume button on the cruise control previously set at max speed. Then, use your foot to jam it in gear!
Black12 is offline   Reply With Quote
Old 07-09-2014, 02:01 PM   #24
Getn off's Avatar
There is no skip shift on 14s.
A mgw, or equivilant, will fix this.
Suggest a mgw and a fluid change. Almost guarantee this will cure it.
Troy
Getn off is offline   Reply With Quote
Old 07-09-2014, 02:23 PM   #25
G3racing's Avatar
IDK how to change it ive tried
Old 07-15-2014, 07:06 AM   #26
ebgonzalez1's Avatar
It's the synchro that is going out I have the same thing happen with mine... it was probably loose from the factory and after some time of hard shifts it'll wear out prematurely...
"Just a lil Sixxer...."
ebgonzalez1 is offline   Reply With Quote
Rearend going finally going in tomorrow! 86gt 1979-1995 Mustang GT 5 08-31-2011 05:25 PM
Going to check out a Mustang today! n8r The Bar 36 06-20-2004 02:41 PM
Going to Check out a 94 Cobra Black95GT The Bar 22 12-02-2003 09:31 PM
I am going to get thrown out of one of my classes..... Brent The Bar 30 08-07-2003 08:35 PM
01:42 PM
