Oil Change - Mustang Evolution
Old 07-07-2014, 04:20 PM   #1
Apas717's Avatar
Oil Change
Guys should I trust the Oil Life reading from the car or change every 5k miles? Dealer has told me the oil life reading is best way to go
Apas717 is offline   Reply With Quote
Old 07-07-2014, 04:35 PM   #2
Ish416's Avatar
I changed my oil at 1,500 miles, reset the oil monitor, racked up over 10,000 miles and it was around 15%. I changed the oil again, it looked great for having that many miles on it, it was a gold/amber color. I won't change my oil again until the monitor says it's at 15%. I plan on doing this until I get rid of the car or it falls apart, whichever comes first.
Also, the oil monitor doesn't actually monitor your oil. It's based on an algorithm that takes into account rpm, load, fuel consumption, stop and go, etc ..
It's pretty accurate, assuming you reset it and you the appropriate oil when changing it.
Old 07-07-2014, 04:37 PM   #3
Apas717's Avatar
Thanks Ish.
Old 07-07-2014, 05:03 PM   #4
TedG's Avatar
Oil is relatively cheap. I do mine every time I rotate the tires....... at 5000 mile intervals.
Become an Organ Donor today: http://donatelife.net/register-now/
Save as many as 50 lives. Thanks.
TedG is offline   Reply With Quote
Old 07-08-2014, 12:57 PM   #5
smurf stang's Avatar
On another forum someone had tested the oil at 5,000 miles and the analysis came back saying it could go another 5,000 with no problems. He also tested it again and they said the same thing.
Like Ish said the car calculated various factors to give ya a guestimate on the oil life. It doesn't actually test the oil.
2016 VW GTI 2.0 Turbo
Old 07-09-2014, 08:51 AM   #6
rmb427r's Avatar
If you're using Synthetic, you don't need to go every 5,000. 10,000 would be the time to change. I change the oil in all of my cars twice a year, whether they need it or not. Been doing that for many years and have never had an issue. Grant you, I don't put more than 20k a year on any vechicle.
Also, I don't go by the maintence reminders, or whatever they are called.
Ron..
2008 Roush 427R
2014 V6 Prem
rmb427r is offline   Reply With Quote
Old 07-09-2014, 08:57 AM   #7
Strange Mud's Avatar
the OLM is fine. old school and do my 6K year by time instaed of mileage. I go 9 months instaed of up to 12 allowed. I figure that is 4 changes in 3 yrs or 1 more than needed. I also did one early...as I said old school. I would do it more often if I beat on it often or short trips were the norm.
full syn after 3k miles & FL-820 filter (larger than the FL500)
First oil change what oil sinister 2011-2014 Mustang GT 48 08-18-2014 07:57 AM
To change or not to change? Djulin 2011-2014 Mustang GT 13 04-03-2013 10:20 AM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 11:37 AM
Oil change....... cagedthought Pre-2005 V6 Mustang 24 10-04-2003 12:35 PM
Oil Change problems 94sexystang Pre-2005 V6 Mustang 20 09-30-2003 10:14 PM
11:45 AM
