Why the heck did the factory crush the mid pipe on driver side??? - Mustang Evolution
Old 07-10-2014, 04:10 PM   #1
Wow, installing mufflers today and looking up underneath a car behind the factory X pipe the driver side exhaust pipe is flat and big time for about 2 feet. What the heck is that about? And is there any reason to go ahead and replace that section of pipe with a round pipe instead of this silly crushed flat pipe???
I do not see any clearance issues whatsoever! What the heck is it all this all about, why is it flattened out? Any reasonable gain replacing that section of pipe??
GT 1 is offline   Reply With Quote
Old 07-10-2014, 04:32 PM   #2
Tyoung68's Avatar
Picture?
Old 07-10-2014, 04:38 PM   #3
mikeygaga's Avatar
Might be causing some airflow restriction if it's really that bad.
2016 GT- Lund tune, jlt intake, mbrp catback.
2014 3.7 - SOLD
mikeygaga is offline   Reply With Quote
Old 07-10-2014, 04:45 PM   #4
jacobdlaw's Avatar
Same thing on the gt's pipe smashed and resonators smashed. I replaced with borla ota's
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
jacobdlaw is offline   Reply With Quote
Old 07-10-2014, 05:08 PM   #5
It's not me, it's you.
primer2tone's Avatar
I've asked myself the same question.
Old 07-10-2014, 05:23 PM   #6
ArtU's Avatar
I cant find the answer yet, but it was answered last year here and it was a reason behind it.
This is not the answer but could be one, "look at your long term fuel trims and they should balance. This is due to air flow on left and right banks from intake to heads to exhaust. If the drivers side is flowing more then the passenger side due to an engineering design, then smash the pipe on the drivers side to make the match and keep the engine banks in balance"
Now replace that with a round pipe and now bank 1 and bank 2 long term fuel trims could really be far out like 20 points or more. Look up long term and short term fuel trims, you need to know about them if you mod and tune.
SO this was all just imagined theory not the answer.
Old 07-10-2014, 05:33 PM   #7
Fords got their hands in the aftermarket world. They know what to do to make us spend money. Bad shifter bracket, crimped exhaust, big factory mufflers, tiny manifolds, 2:73 gears, mild tune, etc
Bigshow14 is offline   Reply With Quote
Old 07-10-2014, 05:36 PM   #8
paintmann111's Avatar
The must get kick backs. LOL
I wouldn't be surprised if flowmaster was their muffler supplier.
paintmann111 is offline   Reply With Quote
Old 07-10-2014, 06:32 PM   #9
FastFord13's Avatar
Hmmmmm, got a hypothetical question for you then, I had resonators installed and then removed and that section of pipe was replaced and now is straight like the passenger side and not crimped anymore, any thoughts on potential long term problems because of it?
2013 3.7 Manual Candy apple red metallic,
GT 500 stripes, painted side mirror covers, GT 500 spoiler, 2010 GT premium wheels with Pirelli P-zero tires, upper and lower front billet grille, Barton shifter bracket, Airaid Cold air intake, S.R lowering springs, J&M adjustable panhard bar, Boss 302 strut tower brace, 3.73 ford racing gears, Bama tuned, BBK shorty headers, Roush Axel backs.
Old 07-10-2014, 06:49 PM   #10
ArtU's Avatar
Naaaa, look at it this way, BORLA is the maker of the GT500 muffs and makes the Ford Racing Touring and Sport Axle back Muffs.....
Old 07-10-2014, 06:57 PM   #11
ArtU's Avatar
Anyone doing mods should get a bluetooth OBDII dongle from Amazon ~$20 and Torque $5 for your smartfone to view and log data and give you real time display what your game box of a car is doing for less than $30
If you make mods and don't have tunes changed, stuff can happen, not always but if you look to see ,you can make sure stuff dont happen. Learn how the motors work and how the real tuners can help you, learn to see what your motor is doing for you.
Are you logging your data now in any way?
Art
Old 07-10-2014, 07:30 PM   #12
GrabberBlue1993's Avatar
Art
Which dongle do you recommend? Ive been looking into doing that but I couldn't find the info on which to get and what app to use with it
"At least it isn't a Honda"
GrabberBlue1993 is offline   Reply With Quote
Old 07-10-2014, 07:33 PM   #13
FastFord13's Avatar
Art
No I'm actually not. Should I start?
Old 07-10-2014, 07:36 PM   #14
Loc: Austin,TX
I feel like I have stepped back into 2011 with this question.
Old 07-10-2014, 07:43 PM   #15
ArtU's Avatar
I really cant recommend one, but I have tried 4 out and this one give me the less trouble. Issue is the BlueTooth serial number is the same on all of them, and so you cant have a few of them close together all working at the same time.
Perfect versions cost about $99 , these are cheap Chinese knock offs. That in mind, if they work and log,they wont change your data, all they are is the same as a cable between your TV and computer, they either work or not.
On Amazon:
Vgate ELM327 v1.5 Bluetooth Mini Small Interface OBD2 Scanner Adapter Torque Android
You use the "Torque" app with them. Others on this forum might have better suggestions for the Blue Tooth dongles, I have used 3 of them so far in my 2 mustangs, and Truck. (Yes I left the OBDII dongle in the port when I traded it, I just forgot)
Ok now you say 4 units but 3 of the Vgates, The first unit OBDII dongle I tried: ELM327 Bluetooth OBD-II Wireless Transceiver Dongle Scanning Equipment...Had new serial numbers for each unit, but it was flaky and required me to reset it almost every time I started the car, sometimes 2 or 3 times before it would work and got to be a real buzz kill fast.
Art
Old 07-10-2014, 07:50 PM   #16
I did not modify the mid pipe, but did install mufflers only today, and new tips.
Wow it sounds good! Not raspy like so many systems out there, nice and deep, definitely close enough to pass for V8 sound in most anybody's book, unless a total motorhead geek like most of us are, LOL, but would definitely fool 98% of most any crowd.
Magnaflow Competition Mufflers part number 14415 that are 14 inch round body, 2.25 in and out, along with with Different Trend 24113c Polished Stainless 4 inch double wall slant beveled cut tips that just could not look any better.
I could not be happier with how looks, how it sounds, and how it all turned out!
Thanks to all who pitched in with great info, many thanks!
Old 07-10-2014, 08:01 PM   #17
ArtU's Avatar
Kewl, that is what counts, sounding very good. My past V6 I put Borla Stingers on it, on one grass car show I pull into a new GT guy asked how to make his GT sound as good as mine. First I tell him, you have to look at this, and he asks how did you fill in the hood vents? I say I didn't open the hood and he says that sound is from a V6?? Yes a V6 with good muffs sounds better then a stock GT.
BUT, next month the GT guy had Borlas and he was really rad sounding!
So when I got my 2013 GT/MT82 , I put Borla ATAKs on it, I didn't want those ATAKs on the V6 as they would be "too" V6 sounding. If you get the Ford tuned V6 exhaust too open and free flowing... it sounds like F1 V6 sounds...Ford did computer work to get the V6 to sound as good as it does....HUmm..Yea..is that why????
Art
Old 07-11-2014, 04:50 AM   #18
Siber Express's Avatar
BTW since someone said they were back in the 2011 discussion but still did not give the reason, it is flattened out to change the pipe so the left and right sides are different to change resonance and not get drone.
Old 07-11-2014, 08:10 AM   #19
Strange Mud's Avatar
idk why they did but it was for a reason...crushing a piece of pipe is an extra step. I would guess resonance is the correct answer though.
Old 07-11-2014, 08:11 AM   #20
Should I crush a piece of my Borla/FR x pipe? Lol
Old 07-11-2014, 09:50 AM   #21
bucko's Avatar
And what answer did you give yourself?
Old 07-11-2014, 10:04 AM   #22
Sterlingbeast5.0's Avatar
I have a 2013 GT and my resonators are the same way. the guy who installed my exhaust called me over to show me them before he proceeded so I would know it wasn't on him. They are evenly done, it has to be that way factory. Not sure why though.
Old 07-11-2014, 12:21 PM   #23
RJ13GT's Avatar
This is a good explanation.
Sent from my SCH-S720C using Tapatalk 2
2013 5.0, Black, Auto, Procharger P1SC stg 2, 4.13'' pulley(8 psi), JMS bap, 3'' x pipe, Circle D 3c, Kooks axleback, BMR control arms. 593rwhp
RJ13GT is offline   Reply With Quote
Old 07-11-2014, 04:55 PM   #24
Check it out
If the smashed pipe is the same inside diameter as the round pipe. There will not be any difference in flow.
They probably did it for the assembly line or transportation.
Old 07-11-2014, 09:11 PM   #25
Loc: Austin,TX
Really?
Old 07-11-2014, 11:13 PM   #26
ArtU's Avatar
Ohh Come on Dan, you know the farkin' reason as you were the one last year tellin' us, Fark it Over Now
Art
Old 07-12-2014, 08:25 AM   #27
Hey Dan
Cool dog,
Did the Dog take that "SELFIE"????
It is a known fact that if the inside dimensions of the pipe are the same at the flattened or square part of a pipe that the round pipe has it will flow the same.
It seems that Ford needed to do that to clear something on the assembly line.
PS:
Whats the dogs name? Boy or Girl? You probably know i like dogs a lot.
Old 07-12-2014, 04:46 PM   #28
ArtU's Avatar
Yes Ronnie, you have a very Cool Corgi
Old 07-13-2014, 03:13 PM   #29
Loc: Austin,TX
I meant really as in are we really having this convo again.
Driver Side Mid Pipe? Fax22 2011-2014 V6 Mustang 12 02-05-2013 06:21 PM
Ricer Hell, Crush Em! primer2tone Pictures and Videos 38 01-03-2013 03:51 AM
Crush sleeve?!?! pringle9666 Pre-2005 V6 Mustang 6 08-03-2010 07:41 PM
Mid pipe with mid mufflers? Tompkins 2005-2010 Mustang GT 5 03-27-2010 12:26 PM
La County law says you race, we crush your cars Seph The Bar 19 10-18-2004 12:01 AM
01:26 AM
