Back Up Camera - Mustang Evolution
Old 07-11-2014, 12:39 PM   #1
Socal Stangman's Avatar
Back Up Camera
Im installing a back up camera with my new Alpine HU. What wire do I tap into for the reverse lead?
Old 07-11-2014, 01:04 PM   #2
elkoritaNAY's Avatar
How much did uget it for? How was the screen installation?
elkoritaNAY is offline   Reply With Quote
Old 07-11-2014, 01:10 PM   #3
I got the HU for 1100.00. With the Maestro and the dash kit its around 1300.00. Very easy install.
Old 07-11-2014, 08:08 PM   #4
JoeyM91's Avatar
Any reason you went with the Alpine over the Raxiom unit AM has? I know the Raxiom has built in support specifically for the back up camera and is ~$650.
Do you already have the premium package with the camera in the spoiler?
Here's a good article about someone trying to do it from scratch:
Adding OEM reverse camera after purchase - The Mustang Source - Ford Mustang Forums
This might have what you need specifically, it's about SYNC Lockpick, but it mentions wiring up the camera if you scroll a bit down:
SYNC Lockpick Install - Add a backup camera to your SYNC system
Old 07-11-2014, 09:17 PM   #5
Thanks for the links Joey, I'll have to check them out.
I'm sure the Raxiom is a good unit but it's really only a GPS unit. You still have the crappy stock HU. I tried swapping out the speakers but it really didn't do much. Then I swapped it out, first with a Kenwood, the difference was amazing. The stock HU really does suck. I'm more of an audio guy so bass and treble adjustments aren't good enough for me...
The Alpine has an awesome audio section. Great EQ 'ing and the DAC's are way better than a stock unit. I also needed the pre outs for the sub and front channels...I'm going to be using a different amp for the front speakers. Having the 7" screen is also very nice.
For the price the Raxiom unit will be more than sufficient for most people, I just wanted and needed more.
Old 07-14-2014, 01:22 PM   #6
12V Guy's Avatar
The Maestro RR T-Harness provides and Violet/White wire that is reverse trigger for your new HU. Connect to the orange/white (I think) reverse input.
Do not try to power your camera off this output though. It cannot drive a camera.
Cheers,
12V Guy
Automotive Data Solutions, Inc.
Montreal, Canada
maestro.idatalink.com
12V Guy is offline   Reply With Quote
Old 07-14-2014, 01:23 PM   #7
12V Guy's Avatar
Haven't seen pics of Alpine with Maestro dash kit in the wild yet. Can you post some?
12V Guy
Montreal, Canada
Old 07-14-2014, 02:12 PM   #8
I have some pics but posting them here is a pain in the ***. Every time I try to post a pic its upside down. Ive tried every thing..
Old 07-14-2014, 02:56 PM   #9
bucko's Avatar
Did you get your answer as to what wire to tap the reverse lead to? Should be the reverse lamp/led of the tailllights. Might find it closer to the transmission though under the car. I can look up the harness location and color code in my factory wiring manual if you still need it.
Old 07-14-2014, 03:15 PM   #10
I believe I did get the answer I needed. 12V Guy said there is a wire in the Maestro harness I could tap. Thanks though.
Old 08-01-2015, 04:25 PM   #11
rob.james.arias
Guest
Posts: n/a
I need the answer to this question. Getting ready to cut wires one at a time until the reverse light goes out to figure it out. There are 6 wires from the taillight harness. Just hoping you might be able to chime in.
Thinking of Adding a Back Up Camera lilredgt 2011-2014 Mustang GT 26 02-20-2014 12:12 PM
Brand new Alpine head unit and back up camera! MachMan1017 Mustang Audio & Video 10 10-24-2012 07:11 PM
Added a back up camera Tec_ Mustang Audio & Video 3 07-31-2012 05:52 PM
Just got my camera back uploaded photos Dark02Pony Pictures and Videos 4 04-19-2005 03:10 PM
03:16 PM
