Am i gonna f up my stang!? - Mustang Evolution
Old 07-15-2014, 11:34 AM   #1
I have a 2013 v6 manual, love it and wouldn't be happier with anything else! I love revving it up and listening to the flowmasters i put, im wondering if its bad to drive hard or will my pistons blow up or something like that!?
memo_soy1 is offline   Reply With Quote
Old 07-15-2014, 12:04 PM   #2
Voltwings's Avatar
really... really.
Old 07-15-2014, 12:10 PM   #3
TorchRed6's Avatar
unless you try to rev it past redline and be 100% stupid while shifting, no. its gonna survive just about anything
TorchRed6 is offline   Reply With Quote
Old 07-15-2014, 12:11 PM   #4
mikeygaga's Avatar
Originally Posted by memo_soy1 View Post
i have a 2013 v6 manual, love it and wouldn't be happier with anything else! I love revving it up and listening to the flowmasters i put, im wondering if its bad to drive hard or will my pistons blow up or something like that!?
yes it will.. Do not accellerate over 70mph or your engine will explode.
2016 GT- Lund tune, jlt intake, mbrp catback.
2014 3.7 - SOLD
mikeygaga is offline   Reply With Quote
Old 07-15-2014, 12:44 PM   #5
GrabberBlue1993's Avatar
If you go over 70 MPH consistently you WILL blow your engine after a few weeks. If you rev it past 5,000 RMPs in your driveway your pistons will combust. If you hit 100 MPH your wheels will come lose and your muffler could backfire causing your engine to explode. If you have the windows open over 55 MPH you run the risk of your vehicle flipping due to air-drag. If your radio is too loud while you are going fast you could cause a wavelength-gasm and create a black hole inside your car causing it to turn into a Honda FIT.
"At least it isn't a Honda"
GrabberBlue1993 is offline   Reply With Quote
Old 07-15-2014, 12:45 PM   #6
Voltwings's Avatar
The pistons don't actually blow up, but the concussive kinetic force from the accelerated RPMS will actually cause them to separate from the crank and lift your cylinder head. This Is why you hear people say excessive cylinder pressure is bad, and most high HP cars go with a lower 9:1 or 9.5:1 compression ratio. However, since your cyclone 3.7 engine is a 14:1 static dynamic compression ratio, it really is possible to lift the head from excessive acceleration. I wouldn't do it.
Old 07-15-2014, 12:52 PM   #7
Best explanation you can find, OP. It really is just too risky, especially with those flowmasters, they widen up the exhaust so much you're adding A LOT of horsepower and it will really put that engine at risk at any speed over 60+ In my honest opinion.
Old 07-15-2014, 01:19 PM   #8
mikeygaga's Avatar
2014 3.7 - SOLD
Old 07-15-2014, 01:22 PM   #9
Voltwings's Avatar
C'mon guys. This guy asks a serious question, I give him a serious response and then you come in here with that nonsense... very unprofessional. This whole thread is just turning into a kerfuffle of trolling, and I for one wont have it.
Old 07-15-2014, 01:43 PM   #10
MustangDawg's Avatar
Dang! I'm tradin' my stang in for a Fit
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 07-15-2014, 02:01 PM   #11
Ummm... might have been a serious response but it was an inaccurate one...
The 3.7 has a compression ratio of 10.5:1. Not sure what the heck a "static dynamic compression ratio"... either you are static or you are dynamic... you can't e both... so no idea where the heck you are getting 14:1....
If you want a serious answer.. the biggest threat to the motor is running really bad guess and getting engine knock that you ignore and still hammer on the car... the weak point of the engine is going to be the hypertheuretic piston and the thin ring landing... the ring landing won't like much pre-detonation (pinging) and will have a tendency to have piece crack off causing all kind of havoc...
As for the pistons separating from the crank? Really? who's not being serious now? Not going to stretch the rods unless you add some type of FI...
Other thing might be if you over rev it, you might float a valve...
___
John - The V6 Apologist
2014 Ingot Silver Vert - MCA Edition
MPT Tuned - MRT Axle Back - MRT Catted H-Pipe - FRPP 3.55
scrming is offline   Reply With Quote
Old 07-15-2014, 02:03 PM   #12
LOL. I think that went way over your head... Like. Way up in the sky over your head.
Old 07-15-2014, 02:06 PM   #13
hey.. i seriously thought you wanted a serious answer... but obviously you just wanted to have fun like everyone else...
___
Old 07-15-2014, 02:07 PM   #14
NewMtang's Avatar
Anyone know who died and left Voltwings in charge?
Old 07-15-2014, 02:20 PM   #15
Voltwings's Avatar
lol I think this guy's too ^^
Seriously ... I said Kerfuffle ... you think I'm being serious?
Old 07-15-2014, 02:26 PM   #16
Alright well thanks guys I suppose I'm really not doing anything bad and I was wondering if anything has happened to people who do drive it hard, but thanks for the serious responses really helped and I guess there's really not much I should worry about!! 👌
Old 07-15-2014, 02:26 PM   #17
hey, yes, the op question is very juvenile to all of us... however, i think back to my first car... i had no idea about cars, except turn the key and put in gas! My Dad, while a great Dad, was very mechanically uninclined... So yeah, we view it as a ridiculous question, however, when I was young and uninformed, i might have asked the very same thing....
___
Old 07-15-2014, 02:31 PM   #18
Au contraire, young padawan, do watch that redline when revving. Also, the magical box that contains Google can answer mostly all of your questions, it is better to search there before coming to a forum where people may take your question and return it with a little jest. However, it is all in good fun. The only way to learn is to ask.
Old 07-15-2014, 02:41 PM   #19
yea well thank you all but yes im 18 and this is my first car so i just don't want to mess it up and was kind of worried, but thank you all and i will research alot more and keep learning!!
Old 07-15-2014, 02:49 PM   #20
Voltwings's Avatar
Type your question into google followed by forum names, its MUCH easier than using most forums built in search functions.
For example:
3.7 mustang max horsepower mustangevolution
or
3.7 mustang max rpm svtperformance
you get the idea. Learning to search google is your biggest help to modding your car. The platform has been out for years now... chances are the questions have already been asked and answered.
Old 07-15-2014, 02:54 PM   #21
alrefire's Avatar
The real... boss 227
Old 07-15-2014, 04:12 PM   #22
FastFord13's Avatar
Lmao! Good one.
2013 3.7 Manual Candy apple red metallic,
GT 500 stripes, painted side mirror covers, GT 500 spoiler, 2010 GT premium wheels with Pirelli P-zero tires, upper and lower front billet grille, Barton shifter bracket, Airaid Cold air intake, S.R lowering springs, J&M adjustable panhard bar, Boss 302 strut tower brace, 3.73 ford racing gears, Bama tuned, BBK shorty headers, Roush Axel backs.
Old 07-16-2014, 09:39 AM   #23
Site Sponsor
Hey Memo-You're going to be just fine! As long as you're following your regularly scheduled maintenance schedule you're going to be fine! Revving every now and then wont harm the motor. Let us know if you have any other questions, we're here to help out!
Alex
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Gonna have to sell my 97 stang jesbowcur General Mustang Discussion 2 01-30-2014 09:09 PM
GONNA LOSE MY STANG 00STANG00 The Bar 29 02-21-2010 10:52 AM
I'm gonna sue you -- Ken The Bar 24 01-09-2004 08:06 PM
Well, im gonna claybar and wax the beast again tomorrow. greenflash00 Mustang Audio & Video 12 10-15-2003 06:10 PM
Wow.. tonight is gonna be fun .:DarkEntity:. The Bar 2 07-14-2003 07:34 PM
10:39 PM
