Brake squeal - Mustang Evolution
Old 07-15-2014, 10:26 PM   #1
Brake squeal
I have the performance package and i think they come with better brakes but mine squeak pretty bad and sometimes it's an almost grinding sound is it something that would be easy to fix or am I replacing the brakes
Does anyone else have this problem?
Brandneutral is offline   Reply With Quote
Old 07-15-2014, 11:07 PM   #2
DarkhorseV6's Avatar
Region: Nevada
I also have the performance package and have been hearing a grinding sound when I brake going over speed bumps. And today I also heard a slight squeaking sound while breaking. It doesn't even have 1,000 miles on it yet.
DarkhorseV6 is offline   Reply With Quote
Old 07-15-2014, 11:14 PM   #3
Well at least I'm not the only one hope someone knows more about it because I don't wanna have to go digging through my brake system
Old 07-15-2014, 11:22 PM   #4
Region: Nevada
I'm thinking about going to my dealership and seeing what's up. Did you get all the extended warranties? I was told that the breaks are better with the performance package as well. I just know I paid cash and only have 900 miles on it and it shouldn't have squeaky breaks.
Old 07-15-2014, 11:28 PM   #5
I do have the extended warranty and if I take it in to the dealership I'm having them replace the clutch too cuz that sticks and your right a brand new car shouldn't have noisy brakes but I think that there is a brake pad that offers better stopping power at the cost of squeaking while they are cold have you noticed it goes away when the brakes are hot? Mine squeak regardless but I was just wondering
Old 07-15-2014, 11:36 PM   #6
Region: Nevada
Mine are also squeaking hot or cold. I was coming out of in&out drive threw when I noticed it. I had to turn down my stereo to make sure it was my car because it was a faint squeak but still, it's bran new.
Old 07-16-2014, 08:00 PM   #7
I was reading online and one guy with the gt500 brakes said he used brake cleaner on the pads and the rotors and it helped
Old 07-16-2014, 09:22 PM   #8
JoeyM91's Avatar
Brake cleaner, or they possibly aren't lubricated properly. Ideally you want to get the back of the pads, the slide pin and the notches where the pad slides across the shims.
I had a squeal like that when I swapped out my rotors and pads because I forgot to lubricate it
Old 07-17-2014, 07:22 AM   #9
I thought that you should put anti squeal on the back of the pads. What would you use to lubricate the other places
Old 07-17-2014, 10:56 AM   #10
Strange Mud's Avatar
my 2012 PP has had a speed sensative squeek that comes from drivers rear. Low mileage toy it showed up maybe 6 months in....very faint. I ignored it till I went in for the LCA tsb. They lubed that caliper. 6 months later (3-4K) it came back I lubed the caliper...I noticed a little wobble in the axle flange on the drivers side (measured at .011 / .013) but after lubing it got quiet again. It started again recently and is in being diagnoised as we speak (hopefully). I think I have a bent axle which the service advisor said will be an uphill fight to get wtty covered. I do have the advantage of every time I went to pick up oil filters I made it a point to say "hi" to my salesperson. I talked with her and hopefully she'll help with wtty if that is needed.
Old 07-17-2014, 07:02 PM   #11
JoeyM91's Avatar
Anti squeal is pretty much just another name for it. Syl-Glyde. It comes in many shapes, sizes and brands but it's the same stuff.
Use that on the back of the pads, NOT the front OR the rotors. Slide pin (the pin with the little rubber bushing on it), and the all 4 notches where the pad slides on the metal shims.
Do NOT use oil-based lubricant like WD-40. Bad things happen, at best it will swell and lock up the bushing on the slide pin.
Brake Squeal Help Rawly General Mustang Discussion 1 01-31-2014 10:15 PM
Brake Squeal! afree05 2005-2010 V6 Mustang 6 08-30-2011 09:45 PM
95 cobra squeal jhagan1980 1979-1995 Mustang GT 23 08-18-2011 09:15 PM
Brake squeal DarkShadow Pre-2005 V6 Mustang 32 06-17-2006 12:43 AM
brakes squeal charkelly9 Pre-2005 V6 Mustang 6 02-08-2006 11:04 PM
10:29 PM
