WOT BOX - Mustang Evolution
Old 07-20-2014, 04:50 PM   #1
_nathannnn's Avatar
WOT BOX
Name:	ImageUploadedByMustang Evolution1405896554.840870.jpg
Has anybody used this in their Stang!? I'm thinking about purchasing it, but would like some feedback about it first
2013 Black 3.7 V6
_nathannnn is offline   Reply With Quote
Old 07-20-2014, 06:33 PM   #2
_nathannnn's Avatar
It's supposed to make power shifting safer for your transmission. It allows you to shift without taking your foot off the gas.
2013 Black 3.7 V6
Old 07-20-2014, 06:44 PM   #3
JoeyM91's Avatar
I'd have to call BS. That little box will not make power shifting safer. You will still beat the hell out of your transmission doing that.
Old 07-20-2014, 07:15 PM   #4
Socal Stangman's Avatar
I agree. It seems to gimmicky to me.
Old 07-20-2014, 07:27 PM   #5
_nathannnn's Avatar
Yeah that was my concern. too good to be true 😕
2013 Black 3.7 V6
Old 07-20-2014, 10:22 PM   #6
GrabberBlue1993's Avatar
The description on that should read "give us your money and we will give you a blue piece of plastic that will magically save your transmission from harm.... We swear.... No you can't have that in writing and there is no warranty.... "
"At least it isn't a Honda"
GrabberBlue1993 is offline   Reply With Quote
Old 07-20-2014, 10:32 PM   #7
ericp16's Avatar
I wouldn't put it in mine. If it worked though it could be a cool idea.
2014 v6 conv, black, manual
ericp16 is offline   Reply With Quote
Old 07-21-2014, 09:25 AM   #8
MadGenius's Avatar
Unless your Mustang is turbo'd than the WOT box is a waste of money. The main purpose of the box is the two-step, which spools your turbo up from a dead stop so that you have maximum boost and no turbo lag when you launch. The other purpose, no-lift shifting, helps keep the car in the power band more often, which again is only advantageous if you're running a turbo setup.
MadGenius is offline   Reply With Quote
Old 07-21-2014, 09:58 AM   #9
somedopebeats's Avatar
Why wouldnt it work? Our clutches are electronic, seems do-able. All it would take is programming to tell the computer to cut the throttle when the clutch is pressed. Im sure its more complicated cuz you need throttle to start in first or reverse.
somedopebeats is offline   Reply With Quote
Old 07-21-2014, 06:00 PM   #10
JoeyM91's Avatar
Cutting the throttle electronically with the clutch depressed defeats the entire purpose of power-shifting while STILL grinding your transmission.
Old 07-21-2014, 07:24 PM   #11
Ish416's Avatar
NLS in an NA car is just for people who can't power shift.
That said, the factory MT82 hydraulics and clutch will not allow for it anyways.
WOT box? 08mustanggt 2005-2010 Mustang GT 10 04-17-2015 08:28 PM
WOT Box Reid Shelby Mustang 1 02-09-2014 04:16 AM
N2mb wot box/2step Southern stang 2005-2010 Mustang GT 5 12-06-2011 12:28 PM
WOT with an automatic...need advice Ghostbuster Pre-2005 V6 Mustang 14 04-09-2005 07:15 PM
When a good Nitrous WOT Switch Goes Bad... BOOM!! michael.konor Pre-2005 V6 Mustang 13 11-17-2004 02:39 PM
01:03 PM
