4.10 gears - Mustang Evolution
Old 07-22-2014, 10:53 AM   #1
4.10 gears
Quick one:
If I am going to order 4.10 gears, do I have to order the installation kit as well?
Thanks in advance...
ID:	161972   Click image for larger version
2014 6 banger premium (girls' mustang)
Performance: Roush CAI, LT headers, off road x pipe, 73mm TB, Ford racing 4.10 gears, H&R LS, DSS aluminum driveshaft, Magnaflow exhaust, Nitto NT05,SCT X4, Lund Racing tune
Exterior: Real carbon quarter panel window louvers+Side scoops+Side diffusers, Polished billet retro grill, 20' AR rims
Soon: Procharger & NOS
dubaighost is offline   Reply With Quote
Old 07-22-2014, 10:58 AM   #2
Voltwings's Avatar
I would, you don't want to reuse the stock stuff, or worse, if it gets damaged during uninstall you're SOL. Aside from the install kit you will need a new pinion bearing as well, I think mine was like $40-$60 from Ford Racing, or something like that. You're also going to need Gear oil and the Ford friction modifier.. you're almost better off just getting this, trust me:
Ford Racing Mustang 4.10 Gears and Install Kit 100574 (10-14 V8; 11-14 V6) - Free Shipping
Old 07-22-2014, 11:04 AM   #3
bigmac3's Avatar
Originally Posted by dubaighost View Post
Quick one:
It depends on how old your current gears are. Under 15K miles, not really necessary. If you are really going to a Procharger, I wouldn't go any lower than 3.73s, especially if you have a manual tranny. You'll spend all your time spinning tires.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 07-22-2014, 11:18 AM   #4
FastFord13's Avatar
+1, IMO 3.73s would be the limit on a manual dd, I also did just the gear and pinion, my car at the time had only 15k. Its as quiet as the OEM 2.73s that were replaced. But if you have the extra coin the whole kit isn't a bad idea either. Like you mentioned it depends on what type and how much milage is on it.
2013 3.7 Manual Candy apple red metallic,
GT 500 stripes, painted side mirror covers, GT 500 spoiler, 2010 GT premium wheels with Pirelli P-zero tires, upper and lower front billet grille, Barton shifter bracket, Airaid Cold air intake, S.R lowering springs, J&M adjustable panhard bar, Boss 302 strut tower brace, 3.73 ford racing gears, Bama tuned, BBK shorty headers, Roush Axel backs.
Old 07-22-2014, 12:00 PM   #5
Socal Stangman's Avatar
I talked to a place that does gear installs and what he said makes sense. Once youre in there you might as well replace every thing. He didnt charge any more to do the extra parts since its already taken apart. Personally, I would buy a complete install kit and do it all.
Old 07-22-2014, 12:16 PM   #6
Voltwings's Avatar
The bearings will mate to the wear surface, kinda like new brake pads and rotors. It is best to do it all at once. The monta with modding cars is that the cheap man pays twice. You dont want to have to pay someone to take this all off again, just do it while you're in there.
Old 07-22-2014, 12:37 PM   #7
bigmac3's Avatar
Not exactly correct. No moving part of the bearing touches the pinion. The bearing race does and that does not move relative to the pinion shaft. The only parts that actually touch are the ring and pinion, both of which will be new.
While that mantra about the cheap man may indeed be true, under normal wear and tear, especially in low mileage situations it is extremely rare for differential bearings to wear. Blackstone Labs Blackstone Labs will do a metal content analysis for less than $20. That can save you some bucks.
I replaced the gears in both of my cars. I bought the bearing set with my first ring and pinion and was told by my mechanic that the originals were perfect and did not require replacement. With plans of changing the gears in my older car also I decided to change the bearings in it. When torn apart I was told the same thing. I now have a spare set of diff bearings. That was 10K miles ago for one car and 30K for the other. Neither have any indications of wear to date.
Good luck, whatever you decide.
Frank
Old 07-22-2014, 12:51 PM   #8
Voltwings's Avatar
Derp about the bearing race. Point remains the same though.
Old 07-22-2014, 02:06 PM   #9
@voltwings Full Kit in AM is out of stock... need to find a site that is easy for international orders. So far amazon works for me
Sent from my SM-N9005 using Mustang Evolution mobile app
Old 07-22-2014, 02:07 PM   #10
I'm running on AT tranny. So is the 4.10 okay?
Old 07-22-2014, 02:26 PM   #11
Thanks guys!
Old 07-22-2014, 02:28 PM   #12
FastFord13's Avatar
Well said, my analogy exactly. Sometimes it just takes a little common sense, if the car is a dd and relatively new (15k and under) your pretty much replacing new parts....with new parts. If the car has some miles and wear and tear on her, 50k +, better to do all at once and avoid any headaches down the line. Its the car owners decision.
Old 07-22-2014, 10:58 PM   #13
ttran's Avatar
Also remember to get 3 bottles of gears oil and some friction modifier. I got my changed at a local shop. Sam 4.10 gears
ttran is offline   Reply With Quote
Old 07-23-2014, 03:26 AM   #14
Thanks Man!
Old 07-23-2014, 03:28 AM   #15
The car is having roughly 14k miles so i assume internals are still good...
Thanks Frank!
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
4:10 gears vs 4:30 gears SwatKatz901 1996-2004 Mustang GT 5 03-24-2012 03:17 PM
3:55 Gears vs 3:73 gears 06Blue 2005-2010 Mustang GT 19 01-04-2012 06:57 PM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
08:56 AM
