Tremec TKO 600 5 speed manual gearbox - Mustang Evolution
Old 07-22-2014, 02:47 PM   #1
Hey guys...
Found a reasonably priced Tremec TKO 600 5 speed manual gearbox (from MMR) in dubai. Planning to put it in my 67 Camaro but I'm thinking of putting it in my mustang (A/T) for the time being.
- will it fit?
- what are the parts that I need to order to fit it in?
- do I need a custom driveshaft?
Thanks in advance!
Sent from my SM-N9005 using Mustang Evolution mobile app
2014 6 banger premium (girls' mustang)
Performance: Roush CAI, LT headers, off road x pipe, 73mm TB, Ford racing 4.10 gears, H&R LS, DSS aluminum driveshaft, Magnaflow exhaust, Nitto NT05,SCT X4, Lund Racing tune
Exterior: Real carbon quarter panel window louvers+Side scoops+Side diffusers, Polished billet retro grill, 20' AR rims
Soon: Procharger & NOS
dubaighost is offline   Reply With Quote
Old 07-22-2014, 06:06 PM   #2
Voltwings's Avatar
If you have to ask whats needed to do a custom transmission swap... you probably shouldn't.
you should assume the bellhousings are different, so look to source a mustang Tremec T-56 bell housing (assuming the gear cases are the same).
You should also assume it will not bolt into the stock cross member, so look into a new trans mount and other chassis options.
you can get under the car and measure the bell housing / gear case / drive shaft, and compare them to specs that have to be out there for this transmission. That will give you a good idea on where to start with your drive shaft.
you'll also need to check if your ECU will even accept a manual transmission, Its likely it wont be happy. You'll also need to check the spline count to source a clutch that's compatible with the mustang.
You'll also need to source a master cylinder from a Standard mustang because the clutch fluid and brake fluid share a reservoir. That's assuming the slave cylinder will work with this Transmission, but most transmission now do use hydraulic clutches.
You'll also want to pull up a gear calculator and see if this transmission will even work well with those 4.10s you're trying to put in. A TR6060 in the GT500 with 4.10s is about the same as an MT-82 with 3.31's, so you can see that's a massive difference.
Quite honestly I don't see why you want this transmission?
Old 07-23-2014, 03:32 AM   #3
Thanks for the detailed response Voltwings. Very helpful..
Looks like a complicated stuff to do... Perhaps i'll just install it in my 67 to avoid unnecessary headaches.
Thanks again!
Old 07-23-2014, 06:11 PM   #4
Black12's Avatar
Better call Modern Driveline and get the proper info on this deal. Bell housing might be an issue among other things. I wouldn't.
Black12 is offline   Reply With Quote
Old 07-23-2014, 09:39 PM   #5
Thanks black12!
Help with Tremec TKO 600 Transmission Mount Rev0351 1996-2004 Mustang GT 2 12-31-2012 07:29 AM
TKO 600 or manual valve body? zeltik 1979-1995 Mustang GT 34 02-28-2012 04:31 PM
1990 mustang 5.0 transmission upgrade question? T-5 or Tremec TKO 600 extra HD? bitten 1979-1995 Mustang GT 1 12-23-2011 03:16 AM
I have a 2001 ford mustang cobra with a tremec tr 3650 ,and thinking to upgrade to a tko 600.? merlow26 1996-2004 Mustang GT 1 03-02-2010 03:53 PM
Tremec Tko-600 Forsale!!!! johnpittbull Mustang Parts for Sale and Wanted 18 03-27-2007 03:52 PM
11:10 AM
