Abnormal clutch clicking noises - is there a way to fix/lubricate it? - Mustang Evolution
Old 07-23-2014, 09:36 PM   #1
To start, this isn't the one faint click that you hear when you depress or the clutch, about halfway down which is normal. My clutch is making clicking noises when I release it very slowly (like when I'm in the engagement zone shifting). It also does it in neutral when the car is off and no load. If I release it just a little bit at a time it clicks with every movement.
My guess is that it's just one of the moving parts the needs to be lubricated, either one of the joints or springs or something. I looked and felt around up under the dash but I can't figure out where it's coming from.
Before I start spraying wd-40 on everything up there, does anyone have any ideas of what could be causing this, or a possible solution.
Car is a 2014 v6 manual, 12,000 miles, never raced. The clutch operates just fine it's just a bit annoying. Thanks!
CUBuffalo is offline   Reply With Quote
Old 07-23-2014, 09:50 PM   #2
Funny my 14 has 12k on it and my clutch pedal sounds like an old creaking door.
Bigshow14 is offline   Reply With Quote
Old 07-24-2014, 06:57 PM   #3
I used lithium spray grease on all the springs and moving parts on the clutch pedal assembly up under the dash, but that didn't help it's still making a creaking noise whenever i move the pedal slowly.
I did notice that if I push the clutch pedal straight in or apply some pressure to the left it creaks, but if I apply pressure towards the right it doesn't.
Any ideas?
Abnormal wear on cloth seat dacm99 General Mustang Discussion 45 11-21-2014 03:45 AM
Clutch noises Wanted 1996-2004 Mustang GT 4 01-18-2013 08:31 AM
Abnormal noise with my 5.0 tmag 2011-2014 Mustang GT 12 11-09-2011 11:52 AM
Best way to fix a slow leaking power steering fluid mykal302 1979-1995 Mustang GT 13 06-21-2011 10:32 PM
How do I fix the clicking sound? twentyis1 Pre-2005 V6 Mustang 1 04-30-2007 01:21 AM
06:35 AM
