2014 3.7 performance upgrades - Mustang Evolution
Old 07-25-2014, 06:51 AM   #1
Hey guys! Got the 4.10 gears and it will be installed in the coming week. Need your suggestions on what can be installed next to add power to my 6 banger.
Current mods
- in my signature below
Planning to get:
- aluminum drive shaft
- Procharger - might take a little more time
- frhp - not that keen
- torque converters - anyone with experience on this? Will this help with performance?
- is there a launch control for v6?
- has anyone tried the nitrous kit? This is perhaps the cheapest way to make our babies run faster but I honestly chickened out after seeing exploding videos of 'professional' drag racers in youtube while they are on nitrous
- is there anyone who builds a custom intake manifold for 2014 models so we can bolt on a grassroots supercharger?
- (cosmetics) - any idea where we can get custom valve covers for our 3.7?
I was in touch with supersix motorsports sometime back... but my wallet is not yet ready for the recommended mods:
Ported cylinder heads: $3750.
Ported upper intake manifold: $300.
Ported lower intake manifold: $400.
4.0L stroker kit: $2995
Rings: $95
Bearings: $175
Anti-friction coating of pistons: $175
Balancing: $250
ARP head studs: $425
ARP main studs: $245
ARP girdle studs: $295
ARP main cap side bolts: $125
BBK 73mm throttle body: $400
Appreciate your comments / suggestions in advance!
Thanks guys!
2014 6 banger premium (girls' mustang)
Performance: Roush CAI, LT headers, off road x pipe, 73mm TB, Ford racing 4.10 gears, H&R LS, DSS aluminum driveshaft, Magnaflow exhaust, Nitto NT05,SCT X4, Lund Racing tune
Exterior: Real carbon quarter panel window louvers+Side scoops+Side diffusers, Polished billet retro grill, 20' AR rims
Soon: Procharger & NOS
dubaighost is offline   Reply With Quote
Old 07-25-2014, 07:12 AM   #2
Voltwings's Avatar
If by grassroots you mean twin screw supercharger, it physically wont fit. The 3.7 is a 60* crank, where as the 5.0 is 90*, meaning theres just physically not enough room in the valley of the 3.7 for a roots / twinscrew blower.
Old 07-25-2014, 02:02 PM   #3
air_commando88's Avatar
Double post?
Sent from my HTC6435LVW using Mustang Evolution mobile app
air_commando88 is offline   Reply With Quote
Old 07-25-2014, 07:03 PM   #4
Black12's Avatar
The gear will require a tuner. Then do the ADS. It's a 10th @ the track and a few mpg on the road. Smart $$.
Black12 is offline   Reply With Quote
Old 07-25-2014, 10:40 PM   #5
That looks like it would be a really solid build. And lots of $$$$$$$ haha
cameron43 is offline   Reply With Quote
Old 07-26-2014, 11:50 PM   #6
Fintile's Avatar
Nothing so far as far as Intake manifolds for Any year 3.7 from 2011-2014 ( they all use the same motor). Tune, gears and headers will give you the best power increase. Next get your intake ported. I hear it will get you an extra 10 hp if you port both lower and upper manifolds but I think if you do the upper you will see a small gain as well.
“anybody driving slower than you is an idiot, and anyone going faster than you is a maniac”
-George Carlin
Fintile is offline   Reply With Quote
Old 07-27-2014, 01:22 AM   #7
Got the 4.10 gears but the tune is pending from mpt. Wondering what will happen if I install the 4.10 gear and load the tune after a day or two.
Sent from my SM-N9005 using Mustang Evolution mobile app
Old 07-27-2014, 01:37 AM   #8
Fintile's Avatar
Your speed readings won't be accurate. It'll read a much higher speed than you are really traveling.
-George Carlin
Old 07-27-2014, 01:54 AM   #9
How about the shift points?
Old 07-27-2014, 05:25 AM   #10
Any thoughts on this?
Old 07-28-2014, 09:54 AM   #11
ponie1992's Avatar
As long as you a/f ratio is right, nitrous is very safe to use. I've had it on many cars and the instant power is extremely addictive!
Jeremy
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 07-28-2014, 11:31 AM   #12
Voltwings's Avatar
1. Your cars shift schedule will be very out of whack until the tune is updated for the gears. It will drive, but it wont be happy, and I certainly don't suggest flooring it until the proper tune is one there.
2. The stock converter in the 6 is extremely lazy, I imagine there are gains to be had with a nicer one. I drive a stick however, so as far as which one, that's beyond me, but circle D seems to be the brand everyone chooses.
3. I don't know if theres launch control since its an auto. Your options are basically footbrake or Transbrake. I launch my GF's car off the foot brake (left foot on brake, right foot on gas...) at about 1500 rpms, and it launches well. Its not rocket science.
4. Nitrous all comes down to the tune. As far as things blowing up, you likely wont be running a 250+ shot like those guys are, at 50-100 I wouldn't sweat it. Also, the V6 manifold design is set up nicely for nitrous. The plenum for the intake manifold sits over the runners, promoting flow down into the cylinders, and (hopefully) not allowing any excess fuel and/or nitrous to pool in the plenum and backfire. You'll also have less of a chance of back firing since you're an auto, keeps you off the rev limiter.
Old 08-01-2014, 02:30 PM   #13
Thanks voltwings.
Old 09-18-2014, 11:30 AM   #14
Good read about torque converters >>> http://www.badasscars.com/index.cfm/...d=78/prd78.htm
Old 09-18-2014, 04:33 PM   #15
SouthernCyclone's Avatar
MPT has adjustments that you can change the gear ratio in the tuner yourself before loading your tune, among other things.
SouthernCyclone is offline   Reply With Quote
Exterior upgrades and maybe performance upgrades RedToplessPony 2011-2014 V6 Mustang 34 12-26-2011 05:09 PM
Performance upgrades for 06 V6 JBlanton 2005-2010 V6 Mustang 15 10-16-2011 02:31 AM
Performance Upgrades NYBigMac Pre-2005 V6 Mustang 7 02-23-2010 10:10 PM
01:50 AM
