Turbo or supercharger - Mustang Evolution
Old 07-28-2014, 08:05 PM   #1
elkoritaNAY's Avatar
I don't know the difference, but is there a turbo kit for 2014 v6 out yet?
elkoritaNAY is offline   Reply With Quote
Old 07-28-2014, 08:06 PM   #2
Rapinator126's Avatar
Yes, lpfbuilt.com.
Old 07-28-2014, 08:11 PM   #3
To put it extremely basic both a supercharger and turbo create 'boost' by forcing air into the engine. The difference is a supercharger creates boost by a pulley and is belt driven off the engine. While a turbo is essentially a double sided fan. One side is in the exhaust the other in the intake. As the exhaust passes through it spins to create boost and force air into the engine.
If you youtube 'how a turbo works' and 'how a supercharger' works it should provide some good visuals that should better see the concept of each. As far as which is better there really isn't an 'better' choice as both have advantages and disadvantages, although generally turbos are more efficient.
StarzTA17 is offline   Reply With Quote
Old 07-28-2014, 08:13 PM   #4
smurf stang's Avatar
There really isn't a good proven turbo kit on the market yet.
2016 VW GTI 2.0 Turbo
Old 07-28-2014, 08:16 PM   #5
True but I have confidence in justin and his shop. He built a really good friend's coyote, and his lightning b4 that.
He may not be the 100% on customer service, but that will come with time.
---------- Post added at 09:16 PM ---------- Previous post was at 09:15 PM ----------
Give it a little time and you will see
Old 07-28-2014, 08:18 PM   #6
alrefire's Avatar
He said it ships tomorrow
We will see!
The real... boss 227
Old 07-28-2014, 08:18 PM   #7
JoeyM91's Avatar
In time I think LPF will be the frontrunner, but personally I want to let them have some more R&D time before I look at it as a serious option. Granted, it's already worlds better than Hellion's failed attempt lol
Old 07-28-2014, 08:19 PM   #8
Jaja thanks guys... But what will "hurt" my car less?
Old 07-28-2014, 08:21 PM   #9
JoeyM91's Avatar
A Supercharger has a small parasitic effect, meaning it WILL cause more wear than the turbos, but if installed incorrectly the turbos can be dangerous.
Moral of the story: Don't be cheap. Get them set up by people who know what they're doing and you'll be fine.
Old 07-28-2014, 08:39 PM   #10
Anything cause damage to your motor. More homework will help lessen the blow
Old 07-28-2014, 09:34 PM   #11
2011 Kona Blue's Avatar
If I'm not mistaken, the procharger kit does not create boost when operating normal driving. No wear is on the engine when driving normal and not in the mid to upper RPM's.
Unless I'm missing something, the boost goes right out the vacuum so no stress on engine at all.
Sent from my SCH-I535 using Mustang Evolution mobile app
Old 07-28-2014, 09:38 PM   #12
JoeyM91's Avatar
A supercharger taps into the crank (thus why you have to drill a whole for the small dowel to your crankshaft during the installation). A centrifugal supercharger ( like the Procharger) doesn't ramp up until the higher RPMs, however the parasitic effect is still there, it's just less than a traditional twin-screw style that allows boost right out of the gate,
Old 07-28-2014, 09:44 PM   #13
Oh, I see. Thanks sir. Great info.
Old 07-29-2014, 06:09 AM   #14
OX1
Smaller turbos can many times reach full boost much sooner than superchargers (roots type excluded), which are limited to a set boost vs RPM curve .
I wish more of the turbo kits concentrated on low end boost. These 6's really lack low end, but have plenty of power for me up top, even bone stock. Would love to see something around 250 ft-lbs to the wheels @ 1500-1800 RPM.
86 Capri, turbo, 3.27's-12.66 @ 107.75
14 GT-Roush Phs 3, VMP 93 tune, Whiteline Sway Bars, Roush U/L Rear Control Arms, Street 18 X 9/10 Bullits with 295/255 NT05/555's-Track 18 X 8/10 Bullit's on 305/35R18 MT ET STR SS and 235/50ZR-18 Michelin PSS
OX1 is offline   Reply With Quote
Old 07-29-2014, 06:13 AM   #15
somedopebeats's Avatar
If you dont know the difference, you dont need one lol.
Do some engine research and decide which fits your needs. I believe a supercharger will put less stress on your motor for daily driving, but a turbo would be just badass
somedopebeats is offline   Reply With Quote
Old 07-30-2014, 11:33 PM   #16
Black_out's Avatar
From what I've learned and read superchargers are more for street fun and pulling toward off the line and turbos are more for 1/4 mile racing
Black_out is offline   Reply With Quote
Old 07-31-2014, 10:08 AM   #17
Voltwings's Avatar
depends on SOOOO many factors. What size compressor are you using, what size AR housing, billit or cast wheels, journal or ball bearings.
You can have a turbo build blistering low end torque, but fall completely on its face by 5000 rpms because its way too small. You can also have a turbo that doesnt even spool until 5000 rpms, but gives a MASSIVE top end punch. It depends on how the car is built / prepped / tuned / and matched to the turbo.
The complexity of these cams really help this motor though, you can tune a very large turbo to act like a smaller one through tricky cam tuning. Retarding the ingition advance moves the flame front closer to the exhaust valve opening (read, more exhaust energy), at the loss of natural engine torque. Well, advance the intake cam (increases dynamic compression) to regain that natural engine torque, and you now have more exhaust energy at the same amount of natural engine torque = better spool.
A supercharger is nice because its just simple, it just is what it is, you put it on and you go. There is a lot more involved when buying / tuning a turbo set up.
Old 07-31-2014, 10:17 AM   #18
Ssssooooo wrong.
There is so much more to that.
Old 07-31-2014, 10:19 AM   #19
Voltwings's Avatar
turbo 3.8 v6 or swap to (turbo??) 4v dohc 4.6 v8??? morthis32 Pre-2005 V6 Mustang 95 09-07-2012 03:27 PM
Can I get a twin turbo kit to work on a newer model a mustang than what the turbo kit was made for? warrane General Mustang Discussion 4 04-08-2010 11:09 AM
turbo or supercharger TexaStang Pre-2005 V6 Mustang 6 07-20-2005 09:26 PM
4.2 versus supercharger/turbo wiarumas Pre-2005 V6 Mustang 9 03-21-2005 09:12 PM
Supercharger -- turbo -- boost drmac Pre-2005 V6 Mustang 2 02-10-2004 05:24 PM
09:58 PM
