HELP! - 4.10 gears - Mustang Evolution
Old 07-30-2014, 11:00 PM   #1
Unhappy HELP! - 4.10 gears
Hey guys!
Got the 4.10 gears installed yesterday. Yes, i noticed the power difference. Feels like the car is always on Sport mode / overdrive. on the down side >>> bad gas mileage.. but this is something that i can take.
My problem now >>> vibration in the differential...
Scenario 1
- normal city driving 60-100kph - NO PROBLEM at all
Scenario 2
- normal highway driving up to 140kph - NO PROBLEM at all
Scenario3:
- Cruising @ 140kph @3000rpm (Diff still okay)
- Full throttle, tranny shifts 2 gears down (@5000rpm), then vibration in the differential starts (then i take my foot off the gas)
- the vibration feels deep
Scenario 4
- Cruising at 80-100kph (2100rpm)
- Then Full throttle, same vibration starts after passing 140kph
Scenario 5
- Driving @120kph
- Shifts to sports mode, then full throttle, same vibration starts after passing 140kph
In my stock 2.73, if i'm driving @ 140 kph then down shifts to 3rd gear, i dont notice any issues. I mean there is no vibration or whatsoever from the differential
Basically the vibration starts when there is a sudden down shift at high speed.
Help guys!
2014 6 banger premium (girls' mustang)
Performance: Roush CAI, LT headers, off road x pipe, 73mm TB, Ford racing 4.10 gears, H&R LS, DSS aluminum driveshaft, Magnaflow exhaust, Nitto NT05,SCT X4, Lund Racing tune
Exterior: Real carbon quarter panel window louvers+Side scoops+Side diffusers, Polished billet retro grill, 20' AR rims
Soon: Procharger & NOS
dubaighost is offline   Reply With Quote
Old 07-31-2014, 12:14 AM   #2
14mustang v6's Avatar
If u just got them in and u think there is something wrong I wouldn't keep beating them up because if there not set in right and u keep beating them then they will set in and u will be stuck with it like that.. U should just go back to the mechanic who put them in and tell him and let him adjust the shims
2014 v6 blacked out with dark yellow super snake. airaid cai, bbk tb, bama tunes, 3.73, and magnaflow competition exhaust.
2014 v6 blacked out.. the only way to do it. Airaid cai, bbk tb, 93htune, 3.73 gears, and magnaflow competition exhaust
14mustang v6 is offline   Reply With Quote
Old 07-31-2014, 12:38 AM   #3
3.7L's Avatar
Aren't you supposed to drive a few hundred miles to let the gears break in before you drive high speeds?
3.7L is offline   Reply With Quote
Old 07-31-2014, 12:56 AM   #4
@14mustangv6 I'm at the garage now...
Sent from my SM-N9005 using Mustang Evolution mobile app
Old 07-31-2014, 04:56 AM   #5
iantrusive's Avatar
There's a break in period for gears, not sure if that's the problem but sounds like you need to go easy on them.
iantrusive is offline   Reply With Quote
Old 07-31-2014, 07:52 AM   #6
Socal Stangman's Avatar
Even before full break in there shouldn't be any vibrations. Some thing is wrong.
Old 07-31-2014, 08:08 AM   #7
GrabberBlue1993's Avatar
You should NOT be giving your car full throttle or put it in sports mode or drive it hard for a few hundred miles after you just get new gears installed.... that could destroy them.....
"At least it isn't a Honda"
GrabberBlue1993 is offline   Reply With Quote
Old 07-31-2014, 08:27 AM   #8
Went to the garage to have it checked.
Surprisingly, after several attempts to re-enact the driving scenario earlier to show the problem with the mechanic and lead engineer inside the car, there was no sign of the vibration at all! I event went crazy with the throttle to show the vibration during gear changes but it was zero!
Weird...
Their comments:
- perhaps the gears are still adjusting
- if there's a problem with the installation, there should have been vibrations and weird sounds even during low speed
Old 07-31-2014, 10:01 AM   #9
blackstang1's Avatar
When i first read this post, it made me think of the video that i watched on youtube of the driveshaft failing after 130MPH. It got me thinking, does having a bigger gear ratio stress the driveshaft more than a smaller one? In my mind, if the rpm's on the highway are spinning faster with 4.10 gears than 2.73, wouldn't that almost be like driving at 130MPH? Also, that vibration that the OP was talking about sounds a lot like the buzzing in the video.
Is there any truth to my thinking or am i just an idiot
2014 Mustang V6 w/Technology package, 6MT
Mods: Airaid CAI w/ Synthamax filter, 18" black AMR wheels
blackstang1 is offline   Reply With Quote
Old 07-31-2014, 10:15 AM   #10
YES-YES-YES
The vibration is more then likely coming from the drive shaft. With the 4.10 gears installed it would be a good idea to get the aluminum one piece drive shaft as soon as possible.
The one on your car is spinning like a tornado at speed.
Old 07-31-2014, 11:43 AM   #11
Aluminum drive shaft is next on my list. Just to be on the safe side...
Old 07-31-2014, 11:27 PM   #12
JOberlander's Avatar
If you calculate the speeds that the driveshafts fail at, and then factor in the new gears, you're looking at a a failure speed at now a bit over 100mph. It will start to buzz at around 100mph normally - just a tiny amount, mind you. so you should be feeling something around 85-90mph now that gets worse as you get closer to 100mph.
One piece driveshaft also allows you to remove the limiter and push the whole thing to around 150mph or so if you really were that crazy.
JOberlander is offline   Reply With Quote
Old 08-01-2014, 10:17 AM   #13
Prezona's Avatar
So what are your guys's thoughts on replacing the factory drive shaft if it is my DD and I rarely go over 85 on the free way. I do city driving majority of the time, and I typically drive 65-70 on the highway.
Would 4.10 gears not be for me?
Prezona is offline   Reply With Quote
Old 08-01-2014, 01:24 PM   #14
@prezona I would highly recommend this specially if you want to drive crazy sometimes or u want to overtake a v8. I cannot comment on the other gears as I haven't used any aside from stock and the 4.10.
For me, city driving still feels okay.
Old 08-01-2014, 01:30 PM   #15
Prezona's Avatar
GAHH. I just don't really want to drop another $700 on top of the $900 total I'm spending on gears and labor.
I mean if anything, the only "crazy" driving I do is a quick launch from stop light to stop light. I am a pretty conservative free way driver in the sense that I don't push my car over 100mph.
I guess I am just an occasional spirited daily driver.
So would 3.73's be a better/ safer pick if I was to not upgrade my driveshaft any time soon?
Old 08-01-2014, 02:48 PM   #16
4.1 gears are not going to make you overtake a GT.....
Old 08-01-2014, 03:06 PM   #17
powerwhee's Avatar
To 60 mph it will. With 4.10s 2nd end right @60 mph. It rips through those two gears hard. Not a 3.73 Gt, but a 3.15 auto gt yes.
Sent from my HTC6500LVW using Mustang Evolution mobile app
powerwhee is offline   Reply With Quote
Old 08-01-2014, 03:19 PM   #18
Sakib's Avatar
Gears aren't going to change your power, period. They will improve your acceleration, but the impact is mainly right off the line, not in the long run. The difference over a long distance 3.73s and 4.10s is very little. In fact even between 3.55 and 3.73 is very little. Steeper gear ratio will give you that kick-in-the-pants, press-your-butt-into-the-seat feeling off the line. It's not going to make your car a whole faster.
Read this sticky post by Ish416 from the DIY forum before you respond:
The truth about gears..
And here is the data table for our 3.7Ls.
Sakib is offline   Reply With Quote
Old 08-01-2014, 03:23 PM   #19
A 0-60 launch is not "overtaking a GT". "Overtaking a GT" is going past it over a distance, such as a 1/4. Show me a video where a stock 3.7 with 4.1's beats a stock GT in a 1/4. 0-60 times are useless they mean nothing comparing one vehicle to another, especially a GT where their power is in the upper band....
Old 08-01-2014, 03:24 PM   #20
+1
I remembered this and was just looking for it to post it! So happy we have that
Old 08-01-2014, 03:53 PM   #21
powerwhee's Avatar
I never said it will beat it over long distances. I said it would to 60 mph... that was my point lol. And by the way, I do have a video of my v6 beating my friends 5.0 at the strip lol. he got a bad launch and 60" 2.4 to my 2.1...but he redlighted and i didn't. he has stock 3.31 gears i'm on 4.10s. not really what you asked for...but the 4.10s definitely help the car pull ahead and stay ahead for a while. on an auto they are the perfect gear.
the 5.0 ran a 14.01@110 to my 13.64@106. i dont know what the annoncer was talking about lol the 5.0 redlighted but technically "lost" obviously the trap speed shows that he would pull ahead but the 4.10s help the car pull forward quickly. there was a auto 2013 performance package v6 w/ tune/intake running 14+@98 mph.
it was hot out and the track is inclined.
i know gears don't add any power. if anything it would read a little less on a dyno.
Old 08-01-2014, 04:02 PM   #22
Sakib's Avatar
Agreed, and I get you about the 0-60. I wasn't replying to you in particular when I made my post, just making a public service announcement. I didn't know about this topic much until I read Ish's sticky like a month ago.
I would disagree with you about 4.10 being the perfect gear for autos, because I read that it's a harsh ride, and I read about one guy on here who even got suspension damage from them for the harshness (can't remember who, please chime in if you remember). So with that data about the minimal performance improvement, I'd rather have a smoother ride and better fuel economy with 3.55s. This is totally personal opinion, of course, as is yours that 4.10s are best. When my warranty goes in 7K miles, I'm getting 3.55s.
Old 08-01-2014, 04:06 PM   #23
Not arguing with you that it'll be quicker to 60mph, but the OP said "a stock v6 with 4.1s will ***OVERTAKE*** a GT" I'm disagreeing with him saying that it would not. "Overtake" implies that the
V6 would pull ahead of the GT in a race, when really they would be dead even almost until the GT blows it out of the water.
Old 08-01-2014, 04:07 PM   #24
powerwhee's Avatar
Harsh ride? lol what? gears have nothing to do with suspension.
yea fuel economy isn't the best. i still get about 27-28 MPG @ 65 MPH though. I didn't buy a mustang for mpg anyway
Old 08-01-2014, 04:09 PM   #25
powerwhee's Avatar
Yea I agree with you lol v6 will never overtake and pull a 5.0 unless it is supercharged or turbo charged. otherwise it's a game of catch up for the 5.0 until he blows by you around 100 mph.
Old 08-01-2014, 04:34 PM   #26
Sakib's Avatar
Harsh wasn't the right word, I meant jerkier shifts. Yes I know gears have nothing to do with suspension. It was an indirect cause... like the jerky shifts over and over caused a control arm to break or something.... I'm trying to search for it. Someone else has gotta remember, this was like 6 months ago on ME.
Old 08-01-2014, 05:26 PM   #27
The GT will blow by a stock v6 with 4.1 gears at 65mph lol. 4.1 gears don't make a difference (so negligible it's basically not a difference) over the 3.73s or even 3.55s over distance
Old 08-01-2014, 05:32 PM   #28
Grabber Blue5.0's Avatar
My car has the stock 3.15's. You think you could out 60' me?
Old 08-08-2014, 04:46 AM   #29
After days of testing, i can still feel the vibration underneath after high speed automatic down shifts on WOT. Bear in mind, this only happen on full throttle and when the tranny down shifts and hit speed of 140kph up.
Again, there is no vibration during normal driving at ANY speed and only happens on WOT at high speed.
I guess the only way to solve the problem is by upgrading to an aluminum driveshaft.
Old 08-08-2014, 05:54 AM   #30
Yes
Aluminum drive shaft should do it and also make you feel a lot less stressful.
Old 08-08-2014, 09:59 AM   #31
It's only available through AM. But I stopped using AM after a bad experience. Amazon seems to be much easier for international orders.
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
4:10 gears vs 4:30 gears SwatKatz901 1996-2004 Mustang GT 5 03-24-2012 03:17 PM
3:55 Gears vs 3:73 gears 06Blue 2005-2010 Mustang GT 19 01-04-2012 06:57 PM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
06:03 PM
