Twin turbos - Mustang Evolution
Old 08-04-2014, 10:04 PM   #1
Black_out's Avatar
Twin turbos
Can a 2014 v6 handle twin turbos?
Black_out is offline   Reply With Quote
Old 08-05-2014, 03:35 AM   #2
ponie1992's Avatar
I would say it depends on the amount of boost.
Jeremy
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 08-05-2014, 03:37 AM   #3
Short answer, no.. Since you won't be running 10 pounds or less of boost with twins.
Old 08-05-2014, 04:24 AM   #4
iantrusive's Avatar
Follow up question. What would one need to upgrade in order for twin turbos to be possible?
iantrusive is offline   Reply With Quote
Old 08-05-2014, 05:44 AM   #5
Frozen Yettie's Avatar
I'll just leave this here.
LINK to the thread.
2013 V6 Mustang: Twin Turbo Build - Houston-Imports.com
2014 Black Mustang 3.7L V6 Premium | 93Race MPT Tuned | Too many mods to list just check out my garage.
Frozen Yettie is offline   Reply With Quote
Old 08-05-2014, 06:03 AM   #6
2011 Kona Blue's Avatar
Shorter answer, yes. Depending if engine is forged. Ha ha ha ha
Sent from my naked Johnson. The thrid real non Boss 227
Old 08-05-2014, 06:07 AM   #7
mikeygaga's Avatar
Prepare to spend a LOT of money.
2016 GT- Lund tune, jlt intake, mbrp catback.
2014 3.7 - SOLD
mikeygaga is offline   Reply With Quote
Old 08-05-2014, 06:08 AM   #8
JimC's Avatar
Why wouldn't you? All you have to do is set up the system properly. The number of turbos won't increase the boost by themselves. And with twins you would typically use a smaller turbo than a single and they spool up quicker.
JimC is offline   Reply With Quote
Old 08-05-2014, 06:46 AM   #9
Voltwings's Avatar
This is very subjective, because it depends on a lot of factors, but "boost" is not one of them.
What boost is, is a measurement of restriction between your compressor and cylinder head, typically measured in the intake manifold and it is NOT a direct representation of horsepower. Imagine a stock Focus ST turbo at 20 psi. Ok, now imagine a GT40r at 20 psi. Boost is the same, but is airflow? No. CFM is what is more important, because THAT is what determines power.
The answer is yes, your 3.7 can handle twins. The real question, is what kind of twins can it handle, and on what kind of tune.
Two small turbos will have blistering response and awesome low end torque, but may fall off on the top end before they really make serious horsepower. Well, torque is what has a tendancy to break things, not horsepower, so lets shift gears a little here.
Two larger turbos will have the potential to flow very well on the top end, and give you a horsepower figure that would justify spending the amount of money Twins would need. However, they would likely incur a large amount of lag, so you would either have to learn how to drive a BT car, or just accept your car will lag. The good news here, is they would avoid that blistering low end torque that we talked about above.
The best option I feel is a small / medium sized turbo with a large AR. It is easy to get a small turbo to spool slow, it is harder to get a big turbo to spool fast. The larger AR will also artificially increase the top end capability of the smaller turbo, and make it breathe like a turbo slightly larger than it actually is.
So, a quick recap: Boost is irrelevent, CFM and spool are what you are concerned with. What rpms the power band starts, and how far out you want to carry that power band.
Voltwings is online now   Reply With Quote
Old 08-05-2014, 07:11 AM   #10
Very informative voltwings! The next question >>> is there a twin turbo KIT for a 2014 v6?
Sent from my SM-N9005 using Mustang Evolution mobile app
2014 6 banger premium (girls' mustang)
Performance: Roush CAI, LT headers, off road x pipe, 73mm TB, Ford racing 4.10 gears, H&R LS, DSS aluminum driveshaft, Magnaflow exhaust, Nitto NT05,SCT X4, Lund Racing tune
Exterior: Real carbon quarter panel window louvers+Side scoops+Side diffusers, Polished billet retro grill, 20' AR rims
Soon: Procharger & NOS
dubaighost is offline   Reply With Quote
Old 08-05-2014, 07:13 AM   #11
Black_out's Avatar
Name:	ImageUploadedByMustang Evolution1407244381.552963.jpg
This is the only one I have seen for the 2014
Old 08-05-2014, 07:51 AM   #12
I hear ya on that. Lol
Old 08-05-2014, 09:29 AM   #13
Voltwings's Avatar
Personally i'm partial to a single vs twins, but thats just opinion. The hellion kits are not the best from what i understand. The exhaust sides tend to get choked up on the GT's, not sure if the V6 is any better, but even still it will likely make enough power to blow up a stock engine, so it should be enough to keep you happy.
Old 08-05-2014, 09:30 AM   #14
Rapinator126's Avatar
The single hellion makes enough to blow up a built 5.0 also. Lol I seeent it
Rapinator126 is online now   Reply With Quote
Old 08-05-2014, 09:36 AM   #15
Twin turbos
If you are running low boost like that then it is a complete waste of money for twins. And having 2 there doesn't mean it spools quicker. If you want a very quick spool you want a ball bearing, self-lubricating turbo. Much more efficient than having a twin turbo or even bi-turbo set up.
With twins you pretty much double the cost of what a single would be, so if you aren't running super high boost then a single is all that's needed.
Old 08-05-2014, 10:23 AM   #16
Black_out's Avatar
Then what would you suggest for me to get
Old 08-05-2014, 10:24 AM   #17
Big single for the track
Twins for a roll car.
Old 08-05-2014, 10:31 AM   #18
Voltwings's Avatar
well your only options are a single unless you get it custom made lol. ^^ either can be made to work in either case, but it takes a very good understanding of the turbos you are using, the engine they will be going on, operating range, tune, fueling ... There is a LOT to consider to maximize bang for your buck.
Old 08-05-2014, 11:44 AM   #19
Black_out's Avatar
Would you suggest a supercharger or single turbo for the track
Old 08-05-2014, 11:47 AM   #20
Depends on your goals.
Old 08-05-2014, 11:50 AM   #21
Black_out's Avatar
To win haha no I would like to be able to pull up to an SS and not even give them a chance
Old 08-05-2014, 11:51 AM   #22
What year ss?
Old 08-05-2014, 11:55 AM   #23
Black_out's Avatar
Any year if they're stock hopefully if they're not I know I probably won't have a chance just because of the fact that a v6 will be racing a v8
Old 08-05-2014, 12:04 PM   #24
Just for clarification. You mean the Camaro SS right? Because there is a Chevy Cobalt SS also
Old 08-05-2014, 12:05 PM   #25
Go turbo man. Or nitrous
Old 08-05-2014, 12:06 PM   #26
Black_out's Avatar
Do you know where I can find good single turbos any you would suggest or would even use in your own car
---------- Post added at 12:06 PM ---------- Previous post was at 12:05 PM ----------
Yes I mean the camaro
---------- Post added at 12:06 PM ---------- Previous post was at 12:06 PM ----------
Alright thanks! now time to look for one
Old 08-05-2014, 12:09 PM   #27
Twin turbos
If you go against the old LT1 Camaro then you may have a chance. If you go against anything newer with an LS motor you will need work done to win.
Old 08-05-2014, 12:25 PM   #28
Ish416's Avatar
A 3.7 with a tune and a good driver stands a very good chance against an LS Fbody .. assuming the Fbody is stock and the driver sucks.
If either of these aren't true, then the 3.7 has no chance.
If it's an SS LT1, it's the same scenario as the LS1 cars.
Old 08-05-2014, 12:36 PM   #29
smurf stang's Avatar
Plus Hellion has ceased production of this 3.7 kits and is not making them any more.
2016 VW GTI 2.0 Turbo
Old 08-05-2014, 12:40 PM   #30
Black_out's Avatar
I have a .070 reaction time and if that says anything
---------- Post added at 12:40 PM ---------- Previous post was at 12:39 PM ----------
Either way I want to put work time to either go turbo or supercharger I just need to find some I know I can find superchargers easily I just can't find any turbos
Old 08-05-2014, 12:45 PM   #31
Ish416's Avatar
Reaction time means nothing, unless your running heads up. Even then, if you can react fast but suck at getting off the line, you are still going to get beat to the 60' and probably the rest of the way down the track.
What's your 60' time?
Old 08-05-2014, 12:47 PM   #32
Reaction time is only good if heads up like stated.
You can sit at the tree for 2 minutes after the light goes, and still run 9's 10's etc.
Old 08-05-2014, 12:48 PM   #33
Black_out's Avatar
0-60 on a bad day is 5.9 my fastest ever was a 5.4 closer to a 5.5
Old 08-05-2014, 12:49 PM   #34
I think they meant 60 foot time. If you ever raced at a 1/4 mile track it will be on the time slip.
Old 08-05-2014, 12:54 PM   #35
Black_out's Avatar
2.28 60' time
Twin turbos Rexxy03 SVT Mustang 17 01-12-2013 09:49 AM
Twin turbos Blackcat 2011-2014 Mustang GT 54 12-01-2011 08:17 AM
? about twin turbos Z-EATER 1979-1995 Mustang GT 5 08-22-2007 08:58 PM
Ford Bringing Twin Turbos into the Lineup in 08 bluemustang General Car Discussion 31 07-19-2007 10:35 AM
Great Oppurtunity...I think. Twin T3 Turbos. Dom Pre-2005 V6 Mustang 7 01-14-2004 04:01 PM
07:42 PM
