Metal shavings in the exhaust - Mustang Evolution
Old 08-05-2014, 06:46 PM   #1
Cory bradley's Avatar
Hey guys I need help trying to figure out a way to get the metal shavings out of my exhaust. without taking off the exhaust system. any help would definitely be appreciated!
Cory bradley is offline   Reply With Quote
Old 08-05-2014, 06:48 PM   #2
ponie1992's Avatar
Why do you have metal shavings in your exhaust?
Jeremy
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 08-05-2014, 06:54 PM   #3
Welded in a new X pipe
Old 08-05-2014, 07:11 PM   #4
GrabberMeBlue's Avatar
They should just blow out over time. Can't be that much in there.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 08-05-2014, 07:12 PM   #5
smurf stang's Avatar
Why would there be shavings still?
2016 VW GTI 2.0 Turbo
Old 08-05-2014, 07:13 PM   #6
It's been about 4000 miles since I Put it in
Old 08-05-2014, 07:27 PM   #7
NewMtang's Avatar
Magnet on a long stick.
Old 08-05-2014, 07:36 PM   #8
BlackPonyIHave's Avatar
If you drag a strong magnet on the outside of the tube, shouldn't the metal shavings follow?
4.6 engine,Ford Racing torque bar, diablo performance 93 octane tune, cold air intake with a K&N filter, SLP exhaust from axle back, 3.73 ford racing gears
BlackPonyIHave is offline   Reply With Quote
Old 08-05-2014, 07:56 PM   #9
Drop the mufflers and take it for a fun drive. Then shake out the mufflers while their on the ground then reinstall
Bigshow14 is offline   Reply With Quote
Old 08-05-2014, 10:02 PM   #10
Socal Stangman's Avatar
Put you mouth around the tip and suck them out...
Old 08-05-2014, 10:52 PM   #11
That's what she said...
Old 08-06-2014, 07:55 AM   #12
ponie1992's Avatar
Did you have a shop fab one?
Old 08-06-2014, 08:52 AM   #13
Did you have a shop fab one? Yes
Old 08-06-2014, 10:20 AM   #14
Strange Mud's Avatar
take off your intake filter and run the engine backwards.....
I will say I doubt you'll get them out...they are either in the cat or mufflers if they exist at all.
Old 08-06-2014, 10:35 AM   #15
ponie1992's Avatar
I've been thinking of contacting some friends of mine that own a muffler shop and pricing a custom x-pipe, but I'm wondering if it would be cheaper to just buy a bolt on. I assume for you it was cheaper?
Old 08-06-2014, 12:41 PM   #16
Yes it was cheaper to have one made. It was like 150$
Old 08-06-2014, 12:45 PM   #17
Old 08-06-2014, 05:24 PM   #18
ponie1992's Avatar
That's a pretty good deal. I may check into that myself.
Jeremy
Jeremy
2016 Ruby Red PP GT
exhaust
Metal shavings in the exhaust Cory bradley 2005-2010 V6 Mustang 14 08-07-2014 11:19 AM
Metal shavings while tightening my lugs? Mustang81596 Pre-2005 V6 Mustang 23 06-13-2013 06:54 AM
One tire fire problem, plus some metal shavings found in rear.. 93_347foxbody 1979-1995 Mustang GT 14 11-08-2012 08:51 PM
Metal shavings on oil pump screen southernstang00 1996-2004 Mustang GT 9 08-28-2012 11:27 AM
Convertible Top Pump with Metal Shavings Xexyz General Mustang Discussion 1 08-12-2011 06:26 AM
03:47 AM
