Strange noise in the rear - Mustang Evolution
Old 08-06-2014, 09:42 AM   #1
2013's Avatar
When I go over a bump I hear a kind of rattling noise. If I get out and push down on the car I don't hear anything and nothing in my trunk is moving around what could it be?
2013 is offline   Reply With Quote
Old 08-06-2014, 10:34 AM   #2
GrabberBlue1993's Avatar
I had the same thing happening happening a few months ago and I "believe" that they said it was the rear sway bar making the noise. Bring it in to your dealer they'll know what it is and fix it for free (woohoo warranty)
---------- Post added at 12:34 PM ---------- Previous post was at 12:33 PM ----------
Also check your mufflers to make sure they're not vibrating around at all
"At least it isn't a Honda"
GrabberBlue1993 is offline   Reply With Quote
Old 08-06-2014, 01:54 PM   #3
2013's Avatar
I'm at 38k so my warranty is gone any idea how much it would be
Old 08-06-2014, 02:06 PM   #4
If you need a new one just get an after market one . Probably a few hundred bucks
Old 08-06-2014, 02:29 PM   #5
MustangDawg's Avatar
That seems like a lot of miles for a 2013, but I don't think you would need to replace the sway bar. Get it on a lift and have a mechanic check if anything is loose. Could be a bushing or something minor. Could be a loose pan hard bar or brace. There's a lot going on in the rear end. Have it checked out somewhere. Ask someone you know if they have a trusty mechanic.
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 08-06-2014, 02:37 PM   #6
2013's Avatar
I've actually went to the dealership and the said it could possibly be a sway bar link but I wanted to know if anyone else had this problem
Old 08-06-2014, 03:26 PM   #7
Yeah that's what it was for me sway bar link. Knew it was sway bar something.
Old 08-06-2014, 03:28 PM   #8
2013's Avatar
Any idea how much I'm going to be out of?
Old 08-06-2014, 03:51 PM   #9
Here's the prices for the rear end suspension parts:
Suspension Stabilizer Bar in Suspension/Suspension, Springs and Related Components for 2013 Ford Mustang
Old 08-06-2014, 03:55 PM   #10
elkoritaNAY's Avatar
It is ur rear sway bar. I had the same exact issue after installing stiffer bars. They have to put grease wax or something along those lines. After that it worked fine.
elkoritaNAY is offline   Reply With Quote
Old 08-06-2014, 03:56 PM   #11
2013's Avatar
So they just out grease on them and I'll be fine or do they replace parts?
Old 08-06-2014, 04:05 PM   #12
In my case I had upgraded to eibach bars. But I guess the grease or whatever it comes with wasn't "strong" enough. The mechanic uninstalled them, put grease wax, and now no more noise.
Old 08-06-2014, 05:41 PM   #13
2013's Avatar
Did you go to the dealership
Old 08-12-2014, 09:14 PM   #14
curtin1991's Avatar
Send a message via ICQ to curtin1991
I have the same thing and can't Stand it
Corey
curtin1991 is offline   Reply With Quote
Old 08-13-2014, 06:00 AM   #15
No I just went to a local mechanic by where I work. You have to put grease wax instead of the lubricant it came with. I used to push my trunk up and down and could hear this screeching sound or whenever I went over a bump. But now it's gone.
Strange sound at engine startup? 3.7 also a steering noise. alludc 2011-2014 V6 Mustang 12 08-13-2012 08:48 AM
Strange noise Ryan7racin 1996-2004 Mustang GT 12 04-15-2012 06:24 PM
strange clutch noise R1CK3R Pre-2005 V6 Mustang 10 10-02-2009 10:47 PM
Strange Noise HELP 19ClearCobra96 1996-2004 Mustang GT 10 09-26-2005 01:29 AM
Strange noise....fuel pump? Ghostbuster Pre-2005 V6 Mustang 12 06-17-2005 11:01 AM
03:07 PM
