Engine bay problem? - Mustang Evolution
Old 08-07-2014, 12:52 AM   #1
sunnytan06's Avatar
Engine bay problem?
Name:	ImageUploadedByMustang Evolution1407394132.654701.jpg
Name:	ImageUploadedByMustang Evolution1407394146.371283.jpg
Swiped it on top of the engine and it looks like oil. It's been like it since I got the car. It's now 12k miles. Is there anyone has the same issue? Thanks
Also. Sometimes when I start my engine it whine when it's under 1k rpm. If you rev, the noise goes along with it and kinda go away after it went higher than 1k rpm. Took it to the dealership a couple of times and they said they can't hear it.
sunnytan06 is offline   Reply With Quote
Old 08-07-2014, 01:44 AM   #2
mpachal's Avatar
I would not worry about the dirt. Someone put some kind of dressing on the plastic and it attracts dirt. The sound is probably the idler arm... I have had mine int three times...it's intermittent and only seems to happen when it's NOT at the dealer. There is a tsb on it.
mpachal is offline   Reply With Quote
Old 08-07-2014, 04:09 AM   #3
sunnytan06's Avatar
Thank you for the reply.
I'm not worry about the dirt but the fact is it seems oily to me. I'm just afraid that there is a leakage of something else.
As for the noise. Can you please explain to me a little bit more? FYI it only happens when I idle.
Old 08-07-2014, 04:11 AM   #4
sunnytan06's Avatar
Sorry but what is a tsb?
Old 08-07-2014, 04:27 AM   #5
LuisBlackGT's Avatar
Technical service bulletin
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 08-07-2014, 05:15 AM   #6
bucko's Avatar
If the smudge on your finger came from when you swipped it across the black intake manifold, its most likely from when it was detailed by the dealer. Did you just buy it, or is this a recent inspection/discovery?
Armor All and simular products are greasy/oily by nature, and for this reason, I don't like to use them on my vehicles, as they attract dust and dirt.
Old 08-07-2014, 06:18 AM   #7
sunnytan06's Avatar
Engine bay problem?
It was not on the intake manfold. It is on the engine directly. it's probably from the dealer detail. To confirm it I am going to wipe it clean and see if it occurs again. Thank you.
Old 08-07-2014, 10:18 AM   #8
Strange Mud's Avatar
spray a cool stopped engine with a 30% simple green then light mist with hose. Avoid electrical give it 30 minutes before starting. Engines are water-resistant (think rain/puddles)
Old 08-07-2014, 07:36 PM   #9
mpachal's Avatar
Thank you everyone for explaining the questions to my post! I guess we call armour all ....dressing....in Canada for some reason. And I thought the grease was on the plastic air intake as that was what was showing in the pic.
To continue with the squeak. There is a tsb that gives a range of manufacture date instructing the dealer to replace the belt and idler pulley if the customer complains of a noise. I had mine replaced but it still occasionally does it. If you blip the throttle when at idle so the rpms go up to about 1.9k and then back down to 550. It seems to start the noise. Keep doing it a few times. Anyway. I have done it at the dealership a few times and they shake their head and say....yes I hear it. Last time I came back to pick it up and they said......we changed your dirty air filter and fixed the issue! Anyway.....obviously that did not fix the issue and I am taking it back next week....AGAIN!
I will keep you posted if they fix the issue. There are only about 4 or 5 things connected to the belt so it shouldn't be that hard to narrow things down!
I also called ford customer service and their wonderful suggestion was......if this dealer can't fix it, try another dealer.....
Thanks ford. CUSTOMER SERVICE HELP! Lol.
Old 08-07-2014, 07:41 PM   #10
mpachal's Avatar
Tsb for the engine squeak is. Tsb 12-7-11
---------- Post added at 06:41 PM ---------- Previous post was at 06:40 PM ----------
Would a 1998 mustang gt engine fit in a 1998 v6 engine bay? imported_Buster 1996-2004 Mustang GT 1 12-14-2011 06:19 PM
got some shinny stuff for the engine bay SpectorV Pictures and Videos 9 10-03-2004 01:53 PM
Engine bay or interior? Dom Mustang Audio & Video 8 08-27-2004 03:07 PM
Clean/Dressed Up Engine Bay? Dom Pre-2005 V6 Mustang 39 02-06-2004 08:26 AM
New pics of engine bay and fog lights Danger Dude Mustang Audio & Video 50 09-11-2003 10:16 PM
01:40 AM
