2012 3.7 Standard Launching (2.73s) - Mustang Evolution
Old 08-09-2014, 05:14 AM   #1
UltArc's Avatar
I just got my underbody off, and am seriously considering going to the drag strip this Wednesday. I have searched the forum on a few occasions, but have not found anyone's advise for launching with a standard 3.7.
GT rim/tire
2.73 gearing
I know it will vary, but I was hoping someone would have figured out what works best for their similar setup, and I could go from there. On a sad note, I have noticed my MPG drop without my underbody by the butt wind tunnel- and gauges from the usual readings.
Can't wait to get it done and take it up there, hopefully I get some good runs and can compare the two. Any and all advice is welcome, have read a lot of previous threads in it, but will take your wisdom into consideration.
Luke 11:9-10 “So I say to you ...*search and you will find; knock and the door will be opened to you.
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline   Reply With Quote
Old 08-09-2014, 10:13 AM   #2
Start at 2k and work up until you blow the tires off then down a notch and go.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 08-09-2014, 10:32 AM   #3
Ish416's Avatar
I feathered the clutch from around 3500 rpm and managed a 1.96 60'. On stock tires and 2.73's.
Old 08-09-2014, 12:08 PM   #4
3.7batmobile's Avatar
What did you end up running in the 1/4 with that 1.96 60' ?
2012 3.7 Mustang; GT500 Axlebacks, 401A GT Shift Knob
3.7batmobile is offline   Reply With Quote
Old 08-09-2014, 02:05 PM   #5
Ish416's Avatar
I made two passes at the strip. My first was a 14.1 @ 102.4 with a 2.3 60' - track was wet.
The next pass I went 13.6 @ 105.2 with a 1.96 60'- Mods are Steeda CAI and 93 octane tune. Everything else is 100% stock.
Also manual trans if you didn't already know.
Old 08-09-2014, 02:24 PM   #6
UltArc's Avatar
Appreciate the feedback. Will start with 3500. Getting pretty excited lol, except I'll have a full tank for the strip, which won't help.
Old 08-09-2014, 04:09 PM   #7
Impressive time for 2.73s. Did the steeda CAI and tune make a big difference?
Old 08-09-2014, 08:22 PM   #8
BigIsland3.7's Avatar
Region: Hawaii
Damn Good Times!
-WMR0629
-Not sponsored By Mom or Dad
BigIsland3.7 is offline   Reply With Quote
Old 08-09-2014, 08:53 PM   #9
3800 for me no track time yet
Bigshow14 is offline   Reply With Quote
Old 08-10-2014, 10:27 AM   #10
Black12's Avatar
I
When I had the 2.73 I always turned the traction control off, then leave on the last yellow at about 2500 to prevent a bogg and feather the throttle to avoid spin. If you go 2.1 in the 60' your there. Street tires don't do well on the Drag Strip. Be aware of wheel hop issues. Good luck.
Black12 is offline   Reply With Quote
Old 08-10-2014, 01:17 PM   #11
Ish416's Avatar
Originally Posted by BigIsland3.7 View Post
Damn Good Times!
In a 3rd gear pull from 40 - 100 the Steeda CAI and 93 octane tune dropped over 2 seconds from stock. That is pretty good.
Here is a video comparison I made between stock and CAI/Tune -
Old 08-10-2014, 01:36 PM   #12
2 Stangz's Avatar
Region: Nevada
Would say you say the Steeda CAI is worth the price tag?
Old 08-10-2014, 01:40 PM   #13
Ish416's Avatar
I picked mine up when it was 20% off.
If you already have a CAI, I wouldn't waste money on one. If you don't however, I would say go for it .. when it's on sale.
It does require a tune .. so make sure you have one for their CAI.
Old 08-10-2014, 01:50 PM   #14
UltArc's Avatar
Traction control off, 3500 RPMs. I will be there REAL early, but hopefully I will see some runs before me. I have never even been to a dragstrip in person.
Old 08-10-2014, 02:09 PM   #15
Ish416's Avatar
You may want to grab some shoe polish or something. Most tracks will have you write a number on the window of your car.
Old 08-10-2014, 02:11 PM   #16
2 Stangz's Avatar
Region: Nevada
I've been eyeballing their CAI for a while, its just low on the list.
I have the factory 2010+ GT cold air induction. I'm not sure if you class that as a 'CAI' or not.
Old 08-10-2014, 02:25 PM   #17
Ish416's Avatar
I can't vouch for anything on the 4.6 but my 3.7 had the factory "CAI" and the Steeda is easily the better performing of the two.
Old 08-10-2014, 03:08 PM   #18
UltArc's Avatar
I called a while back when I finished my underbody (before it was unsafe for high speed), and they talked about all their rules and what would be needed, but suggested to come down and do some runs- don't invest in gear unless I need it for the times I run. I know that is different, but I figured they would have mentioned something then about it.
This is Summit Raceway, in Norwalk, Ohio.
Old 08-10-2014, 06:50 PM   #19
2 Stangz's Avatar
Region: Nevada
That answers my question.
I have the same intake you replaced with the Steeda CAI. The 2010 GT's was the first year to receive the new intake found on all 2011's+.
Old 08-13-2014, 03:59 PM   #20
UltArc's Avatar
Two runs down, waiting for three. Blew the wheels off (figuratively) at 3400, again at 2000, but it was much easier to control. Going to do a little burnout and go again at 2000.
Old 08-13-2014, 04:20 PM   #21
Sakib's Avatar
Nice, hope you're having fun. Let's see your slip when you're done! You ought to show it off to your eco-mod forum buddies, too.
Sakib is offline   Reply With Quote
Old 08-13-2014, 05:22 PM   #22
UltArc's Avatar
Heck yeah! So on my final run I finally broke 15 and hit 14.689. Four runs in for 7 bucks, can't complain. Heck of a time, met some cool people.
Old 08-13-2014, 05:28 PM   #23
UltArc's Avatar
First run was 16 and change against a G8 GT. Second run was 15 and change with TC on/windows down (both accidentally), against a drag built car. Third run was lower 16. So final run with windows up but TC left on gave me this.
Nothing special, but glad I went out! Was a blast. Might go next week, but WILL be going when my underbody is done. More images to follow, wanted to post my poor results first lol.
ID:	163404   Click image for larger version
ID:	163406   Click image for larger version
Old 08-13-2014, 05:36 PM   #24
UltArc's Avatar
Lol, I am the slower one each time by a LOT. My issue was spinning my tires. 3400 just blew em off, and I was sideways spinning first into second. Third run had the same issue, but wasn't as drastic even though I launched at 2000.
Mileage at the end was 20.1 down from 36+ getting there. I will be checking my gas and reducing that from my fill up lol, I won't be including this in my lifetime average. Just sitting in line getting there took me down to 33 and change. I used 1.68 gallons before getting there. So 14+ gallons of fuel, over 112+ extra pounds. Dinner nice Stang's there, photos attached. A real nice Porsche, too, but the guy looked like a DB so I didn't take a picture of his car. He sat in it the whole time.
If anyone sees anything from my results, would love to learn!
ID:	163409   Click image for larger version
ID:	163411   Click image for larger version
ID:	163415   Click image for larger version
Old 08-14-2014, 01:20 PM   #25
UltArc's Avatar
So in replaying the events yesterday, I realized something. Should the PSI in your tires be 55 for running on the strip?
I think that was an issue. Suggestions on drag PSI for the base GT rim/tire combo? I hear as low as 20, but that doesn't even seen safe with the heat. Would love to hear feedback.
Old 08-14-2014, 01:43 PM   #26
Well 55 psi will heavily contribute to no traction... I know lots of people who go down to 20 psi but I leave mine at 35 for daily duty and track.
2011 Mustang 3.7: 13.2 @ 105
BBK Shorty, MRT H, Borla S, 3.55 Gear, MPT Tuned.
LiveWire003 is offline   Reply With Quote
Old 08-14-2014, 02:15 PM   #27
Ish416's Avatar
I left my at 35 psi.
Old 08-14-2014, 02:22 PM   #28
Oh2freshstang's Avatar
First run was 16 and change against a G8 GT. Second run was 15 and change with TC on/windows down (both accidentally), against a drag built car. Third run was lower 16. So final run with windows up but TC left on gave me this. Nothing special, but glad I went out! Was a blast. Might go next week, but WILL be going when my underbody is done. More images to follow, wanted to post my poor results first lol. Luke 11:9-10 “So I say to you ...*search and you will find; knock and the door will be opened to you.
Work on the launch & get the 60' down. When ur leaving are u dumping the clutch or slipping it? I found it better to slip the clutch. & yea def drop that tire pressure..I've heard of 20psi but idk about that on street tires I usually run around 25-26psi. Seat time is gonna be ur best friend tho..learn what ur car likes!
Old 08-14-2014, 05:53 PM   #29
UltArc's Avatar
I really appreciate the support, guys. I was slipping it, but slipping quickly, so might as well been dumping it. I will drop it down to 30ish PSI and start at 3k slipping. I couldn't believe I was so much faster with TC on lol. Anything else you guys notice from the slips?
Old 08-14-2014, 11:38 PM   #30
I really appreciate the support, guys. I was slipping it, but slipping quickly, so might as well been dumping it. I will drop it down to 30ish PSI and start at 3k slipping. I couldn't believe I was so much faster with TC on lol. Anything else you guys notice from the slips? Luke 11:9-10 “So I say to you ...*search and you will find; knock and the door will be opened to you.
Yea it's crazy I ran better times with TC on in my 5.0 with it off I would completely blow the tires off! Another tip is to focus on the launch & not so much on reaction time..RT doesn't count against ur ETs so take ur time till u get a good launch down!
2012 Mustang V6 Standard Underbody Build Sheet UltArc 2011-2014 V6 Mustang 46 01-05-2013 09:16 PM
Launching my 2012 5.0 gt JJB82 At the Track 4 11-27-2012 04:11 PM
Launching RPM ttpancakes Pre-2005 V6 Mustang 37 07-26-2004 11:11 PM
anyone in FL want a rear end with 3.73s and tlok? Stylin97V6 Regional Mustang Discussion 1 12-07-2003 09:48 AM
Used factory Ford 7.5 3.73s & T-loc --- Any Good? Stang01 Pre-2005 V6 Mustang 24 07-18-2003 04:40 PM
11:24 AM
