Possible Automatic Transmission Teardown - Mustang Evolution
Old 08-09-2014, 10:59 PM   #1
Abominable Mustang
WhoDat's Avatar
Region: Alaska
So a while back, I replaced my stock driveshaft with the axle exchange one piece. Since then there has been this rattle and whine that has progressively gotten louder over time. It sounds like it's coming from under my center console. When I get under the vehicle, I do the usually check to see if either end of the driveshaft has any play in it. Where the driveshaft meets the transmission, there was more lateral and vertical play than I'm comfortable with. I believe that's were my sound is coming from. I really hope it's just the u-joint, but the way it moved, I feel like it's something internal to the transmission. I believe the transmission output shaft has both a bearing and a bushing. I'm going to reinstall the stock driveshaft sometime this coming week. If the sound goes away, I'll know it's the u-joint. If not, fun times ahead. My pinion angle was within spec, so I feel like I may have done something during the one piece driveshaft install to cause this. I'll keep you guys updated
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 08-09-2014, 11:41 PM   #2
Tyoung68's Avatar
If your talking about the DS sliding in and put of the transmission its suppose to do that
Old 08-09-2014, 11:56 PM   #3
Abominable Mustang
WhoDat's Avatar
Region: Alaska
No. I mean up/down/left/right movement
Old 08-10-2014, 12:00 AM   #4
Tyoung68's Avatar
Does the yoke move or just DS ?
Old 08-10-2014, 12:05 AM   #5
Abominable Mustang
WhoDat's Avatar
Region: Alaska
The yoke, which is why I feel like it's not the u-joint but something internal to the transmission
Old 08-10-2014, 12:08 AM   #6
Tyoung68's Avatar
Yeah that sounds internal
Old 08-10-2014, 09:31 AM   #7
ponie1992's Avatar
Sounds like a bad output shaft bearing.
Jeremy
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 08-17-2014, 08:12 PM   #8
Abominable Mustang
WhoDat's Avatar
Region: Alaska
UPDATE: So I got back under the car and the amount of play at the transmission side was less than I had previously thought. Guess I was being paranoid. Decided to reinstall the stock driveshaft as planned. After I had done that, I took it for a test drive and the rattle and whine were still there. Threw it back on the lift to swap the driveshaft back. This is when I look over at my rear LCAs and remember that they have spherical bushings on the axle end. I think, what the hell, and drop that side to inspect the bushings. Sure enough, both are shot. I throw the stock LCAs on and now both the rattle and whine are gone. I have heard that the S197 chassis amplifies sound quite a bit and makes noises sound as if they're coming from somewhere else, but that was just crazy. Glad I didn't start tearing apart the transmission.
5.0 First Time Teardown Billymich 1979-1995 Mustang GT 24 10-19-2012 05:40 PM
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 03:09 AM
no longer a member of ME 5.0 club... (car teardown update) Bane- The Bar 14 09-20-2005 05:30 AM
Pics of my Teardown Kiljosh Pictures and Videos 4 06-02-2005 01:42 PM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
04:18 AM
