Motorcraft filter #??? - Mustang Evolution
Old 08-11-2014, 06:04 AM   #1
I just did my first oil change. I went and got the correct Motorcraft filter. But when I took off the factory filter it is about 3/4 of an inch longer than the one I bought. So I double checked and I have the right MC filter. So what is the MC # of the longer factory filter????
bodon is offline   Reply With Quote
Old 08-11-2014, 07:44 AM   #2
Where did you buy the filter ?????????????????
I'm sure you will be fine because Ford does not actually make the Filters. They probably have two or three manufactures making them. That is the reason for the slight difference. The filter you bought is fine.
Old 08-11-2014, 08:11 AM   #3
Strange Mud's Avatar
Mine came with the FL-500, 1st time I went to my local dealer I got FL-820 the 820's are slightly larger. As you all know bigger is better. From what I remember the specs are close enough I kept running the 820.
mobil 1 full syntethic with motorcraft oil filter?? Andy714 2005-2010 V6 Mustang 13 11-22-2012 11:38 PM
Motorcraft FL-910S Oil Filter on Mustang Lapida 1979-1995 Mustang GT 3 04-10-2012 05:05 AM
Motorcraft FL-820s vs Ford Racing CM-6731-FL820 Oil Filters SaleenFiend General Mustang Discussion 12 04-19-2009 04:39 PM
Motorcraft plugs SonikBlueStang Pre-2005 V6 Mustang 2 03-27-2006 05:37 AM
cold air k&n filter PN/filter size tire Pre-2005 V6 Mustang 0 12-05-2003 05:37 PM
11:05 AM
