launch control / 2 step rev limiter - Mustang Evolution
Old 08-14-2014, 07:32 AM   #1
Hey guys! Since our v6 doesn't come up with a launch control, what's our option to achieve the same effect?
Has anyone tried Msd Launch Control 2 Step Rev Limiter? any other options?
Will it work on our v6?
just thought that this will help us a lot on our 0-60 runs...
(apologies if this has been discussed in the past)
2014 6 banger premium (girls' mustang)
Performance: Roush CAI, LT headers, off road x pipe, 73mm TB, Ford racing 4.10 gears, H&R LS, DSS aluminum driveshaft, Magnaflow exhaust, Nitto NT05,SCT X4, Lund Racing tune
Exterior: Real carbon quarter panel window louvers+Side scoops+Side diffusers, Polished billet retro grill, 20' AR rims
Soon: Procharger & NOS
dubaighost is offline   Reply With Quote
Old 08-14-2014, 08:25 AM   #2
ponie1992's Avatar
2 step will only work if you have some sticky tires. Stock tires, don't bother.
Jeremy
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 08-14-2014, 08:34 AM   #3
Ish416's Avatar
Launch control is for people who can't drive.
If your car is a manual, you already have launch control, if it's an auto, put an appropriate stall in it.
Old 08-14-2014, 08:35 AM   #4
NT05 soon...
But is there a specific model for a 2014 v6? Or is it generic?
Sent from my SM-N9005 using Mustang Evolution mobile app
Old 08-14-2014, 08:38 AM   #5
made for people who can't drive?
Ooohhh, that's why the shelby, boss and even the gtr has one... made for those kind of people perhaps?
Old 08-14-2014, 09:19 AM   #6
Ish416's Avatar
The Shelby's launch control doesn't do much. It softens the rear suspension, holds a constant RPM (manually adjustable) until the clutch is released and then uses track mode traction control. I've driven one and I can generally get the car off the line better than the launch control can. However, the launch control generally makes for consistent times as the 13/14 Shelby loves to smoke the tires.
If you read timed tests or talk to people who actually own them and know how to drive a car with that kind of power, they are faster doing it all themselves vs using the launch control.
Launch control on the GTR is something entirely different. It allows for the car to be launched on boost, while actively changing the stiffness on the suspension while it detects wheel slip on each tire and adjusts power output to each wheel independently. That system is what makes the GTR one of the fastest cars to come off the line. No human would ever be able to defeat it, simply because the car does all the work for you.
Old 08-14-2014, 10:16 AM   #7
Sakib's Avatar
Originally Posted by Ish416 View Post
...while actively changing the stiffness on the suspension while it detects wheel slip on each tire and adjusts power output to each wheel independently.
Whoa. That is cool.
Sakib is offline   Reply With Quote
Old 08-14-2014, 10:22 AM   #8
Rapinator126's Avatar
It's a selling point. Also makes the car slower 0-60 vs someone who actually knows how to drive.
Old 08-23-2014, 01:28 PM   #9
willb2305's Avatar
2 step is generally better for people that have a supercharger or turbo. I have seen a youtube video of a 12 or 13+ GT500 with an actual 2 step his launches off the line were consistent and he took off like a bat out of hell. He also got crowned Street King for the track event that day. The second fastest car of that event was a Honda CRX that had a mean turbo i think the crx had around 550 or 650hp. Those crx's are super light maybe 2000-2300lbs or less??
2012 V6
AirRaid CAI, BBK Ceramic LT Headers, BBK Catted X Pipe, Borla ATAK, MPT 93/97 Tune, Steeda LCA's and UCA, Steeda Relocation Brackets, 373 gears, WaveTrac LSD, Dynotech Driveshaft. Prothane Motor Mounts, Whiteline adjustable panhard bar & brace.Ground Control Coilovers with Koni's custom valved. Coming soon Circle D 3800 Stall and Lone Wolf Intake Manifold.
willb2305 is offline   Reply With Quote
Old 08-23-2014, 01:42 PM   #10
So basically it can't be used in a v6 w/o turbo?
Old 08-23-2014, 05:49 PM   #11
alrefire's Avatar
You can, you just wouldn't see as much benefit...
The real... boss 227
Old 08-23-2014, 08:09 PM   #12
ponie1992's Avatar
If you want consistant launches and have sticky tires, a 2 step works well.
Jeremy
Jeremy
2016 Ruby Red PP GT
Old 08-24-2014, 03:50 AM   #13
@ponie online sites (even AM) only mentions 5.0 in the description / compatibility?
Old 08-24-2014, 09:56 AM   #14
2 Step Rev Limiter
I got my tuner unlocked, and set a rev limiter in neutral to 2500 RPM. Launched it a couple times last night to ensure it worked, and I love it. Sounds pretty dope too, but probably isnt good to be used on the car frequently (I cant figure out if it gas or ignition cutting).
Whole process took only a couple of seconds, just changed the setting on my live wire and done.
2014 Oxford tri-pedal 3.7L- Airaid CAI, BBK 73mm TB, MGW Shifter, DSS Driveshaft, Whiteline Bracket, BBK Shorties, Lethal O/R H-pipe with HighFlow Cats Installed, Vibrant Resonators, Pypes Axlebacks. Track Pack Wheels!
Georgie is offline   Reply With Quote
Old 08-24-2014, 06:12 PM   #15
ponie1992's Avatar
I honestly don't know. I was commenting about 2 steps in general.
Jeremy
Jeremy
2016 Ruby Red PP GT
Old 08-24-2014, 06:13 PM   #16
ponie1992's Avatar
Typically a 2 step cuts the ignition not fuel.
Jeremy
Jeremy
2016 Ruby Red PP GT
launch control or two step? Silversky545 2005-2010 Mustang GT 4 10-02-2012 04:09 PM
2 step launch control installation and programming? 88gt209 1979-1995 Mustang GT 1 08-29-2012 05:34 AM
Dual-Stage Rev Limiter blue-saleen Pre-2005 V6 Mustang 5 12-10-2009 07:00 PM
nitrous and rev limiter 02whitestang Pre-2005 V6 Mustang 2 02-12-2004 08:04 PM
Rev. Limiter Cut Off Donny B Pre-2005 V6 Mustang 10 12-25-2003 11:25 AM
05:53 AM
