Perfect RPM shift points: automatic - Mustang Evolution
Old 08-18-2014, 01:32 AM   #1
What could be the perfect RPM shift points for an automatic?
Objective is to maximize speed on full throttle and get the best 0-60 time.
My lund racing tune gives me (based on a wobling video that I took):
1st gear: xxx rpm to 5100
2nd gear: 4500 to 5900
3rd gear: 4600 to xxx
My MPT- haven't received my revised tune
I've asked both tuners to make the shift points to 7000rpm.
is it right to assume that it will go faster if all shift points will be set at 7000rpm specially on 1st- 3rd gear (on full throttle)?
Can we set it over 7000rpm?
Got a 5.6 (0-60) best time on my MPT tune while using manual shifting on S mode.
Lund racing is SURPRISINGLY slower on D and S mode (and manual shifting) with the best time of 6.1. No complaints on normal driving though....
What are your thoughts on this?
2014 6 banger premium (girls' mustang)
Performance: Roush CAI, LT headers, off road x pipe, 73mm TB, Ford racing 4.10 gears, H&R LS, DSS aluminum driveshaft, Magnaflow exhaust, Nitto NT05,SCT X4, Lund Racing tune
Exterior: Real carbon quarter panel window louvers+Side scoops+Side diffusers, Polished billet retro grill, 20' AR rims
Soon: Procharger & NOS
dubaighost is offline   Reply With Quote
Old 08-18-2014, 06:46 AM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
My Bama and MPT tunes definitely shift around 6.8k rpm at WOT, so it's possible for them to set the shift points at higher rpms. And yes, I'm sure they can set them even higher, but no reputable tuner would set an automatic car's WOT shift points at anything above redline.
On a side note, I thought that aftermarket tunes only affected Drive, not Sport (S mode). I could be wrong though.
2012 Kona Blue 3.7L V6:
Old 08-18-2014, 07:13 AM   #3
Voltwings's Avatar
Your perfect shift point depends on a lot, namely your gearing and powerband. Just shifting higher does not mean you will go faster if your powerband starts falling off. This is something i would assume your tuner knows best for you mods, seeing as how they have had expose to many different set ups to confirm the shift points they use.
That being said, your quickest times / shifts will likely come from not trying to manually shift it.
Old 08-18-2014, 07:33 AM   #4
The tuners can NOT access Sport mode in the transmission, the tunes only work on D.
Old 08-18-2014, 12:42 PM   #5
@voltwings the revised tune from jon lund. Hopefully it's better. ..
Yes, this only works on Drive...
Sent from my SM-N9005 using Mustang Evolution mobile app
4.10 - automatic - shifting points - problem on WOT dubaighost 2011-2014 V6 Mustang 25 08-23-2014 09:40 PM
Mustang sport shift (shift at 3000 rpm's ?) Charlesph55 2011-2014 V6 Mustang 5 07-24-2014 09:58 AM
Shift points Fordhartbreaker Pre-2005 V6 Mustang 14 01-08-2012 05:06 PM
1997 MUSTANG IDLING AT 500 RPM?! help please! 10 points!!!? macray33 Pre-2005 V6 Mustang 4 12-21-2011 12:11 PM
shift points for saving gas eddie1 1996-2004 Mustang GT 4 06-03-2009 10:23 AM
03:57 PM
