Header Stud help - Mustang Evolution
Old 08-20-2014, 11:22 AM   #1
Header Stud help
Hello everyone,
So i was installing my BBK long tube headers last night and lost 2 studs some where, is there any where online to order these or does anyone knows the specs on them so i can go to the auto parts store? i called the ford dealership and they do not have any.
machai9481 is offline   Reply With Quote
Old 08-20-2014, 12:35 PM   #2
Voltwings's Avatar
Thread one nut onto an existing stud backwards (flat side facing away from the engine), and then thread another one forwards (normal orientation like you were tightening it) so the flat side are touching.
Tighten both nuts against each other (you will need box wrenches for this), and then loosen the stud using the rear (backwards) nut. you can then remove the stud and take it to the auto parts store to compare.
Old 08-20-2014, 05:50 PM   #3
Siber Express's Avatar
Or use a 5mm wrench to remove a stud after removing the nut and go to the local parts store.
Old 08-21-2014, 07:56 AM   #4
Voltwings's Avatar
Is there spot on the stud for a wrench? I havent actually looked at them, thats just a trick we have always used, but your way sounds easier in this particular case haha.
Old 08-21-2014, 09:56 AM   #5
Yes, they have a 5 mm head on them
Old 08-21-2014, 02:33 PM   #6
colemaneric's Avatar
Ford sells them, that's where I bought mine only problem is they're $5 each
colemaneric is offline   Reply With Quote
Old 08-22-2014, 04:31 AM   #7
Charlie_santos's Avatar
O'Reilly has them for cheaper. You get like 6 for 15
Sent from my LG-D850 using Mustang Evolution mobile app
Old 08-22-2014, 07:30 AM   #8
thanks everyone, i ended up buying one from the ford dealership, it was 8 dollars for a 6 pack
Clutch fork/pivot stud Help please! RodgersMustang 1996-2004 Mustang GT 2 06-16-2014 09:44 PM
Header coating. Ceramic vs. Chrome/painted with header wrap wc3john The Bar 10 06-27-2011 10:20 AM
2005 main stud help! Dannyb937 2005-2010 Mustang GT 0 12-03-2010 12:46 AM
86 svo mustang header panel wanted header panel? wit 2.3 Mustang 1 08-21-2009 08:39 PM
new stud in town mc13 New Member Introductions & Greetings 19 07-14-2005 04:19 PM
05:55 PM
