Does The Diameters of Rims Affect Car Performance ? - Mustang Evolution
Old 08-29-2014, 12:17 AM   #1
ttran's Avatar
I'm getting new set of rims soon. Im debating between SVE 19x9.5 for all for wheel or some 5 spokes rims 20x8.5/ 20x10. I dont know if the diameter will affect the performance of the car. The car also sitting on a set of SR spring 1.5in drop. Any feed back will help greatly. Thanks
ttran is offline   Reply With Quote
Old 08-29-2014, 12:57 AM   #2
14mustang v6's Avatar
Bigger wheels more rotational mass/more weight.
2014 v6 blacked out.. the only way to do it. Airaid cai, bbk tb, 93htune, 3.73 gears, and magnaflow competition exhaust
14mustang v6 is offline   Reply With Quote
Old 08-29-2014, 04:34 AM   #3
14mayhem's Avatar
Since different rim size allows you to use different tires, yes it can affect performance, which can go either better or worse, depending on the tire size and type used. But not usually enough to make much of a difference.
14mayhem is offline   Reply With Quote
Old 08-29-2014, 06:19 AM   #4
Voltwings's Avatar
It will also effectively change the final drive. A shorter than stock tire would be the same as raising your ratio (>2.73) while a taller tire would make it even shorter (<2.73).
Also, larger wheels / tires are not necessarily heavier. I have 19 x 9.5 rims / tires that are .5 lbs ligther each than my factory 18 x 8 GT rims.
Old 08-29-2014, 06:22 AM   #5
Mine are 4 lbs lighter each rim and they are 19×9.5's
Old 08-29-2014, 09:55 AM   #6
Overall height will affect weight dramatically, also normally with a bigger wheel you are forced to run a lower profile tire, which means less grip.
Old 08-29-2014, 10:04 AM   #7
GrabberMeBlue's Avatar
Also, the lower the tire profile, the more all those bumps and potholes are going to hurt.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 08-29-2014, 10:38 AM   #8
alrefire's Avatar
Also depends on your goals. 15 would be great for drag racing, but all that sidewall will mess you up if you're auto x ing or road racing
The real... boss 227
Bolt-ons that affect gas mileage. LaseRedXD Pre-2005 V6 Mustang 15 10-01-2012 05:06 PM
CAI affect stang with cali emmisons 2000v6stang Pre-2005 V6 Mustang 5 09-11-2012 12:40 AM
what mods dont affect your warranty Sprintradc 2011-2014 Mustang GT 10 03-31-2012 08:47 AM
How will an incorrect aspect ratio tire affect my car? Fferyll 1979-1995 Mustang GT 4 12-11-2011 06:58 AM
does cluster gauge affect sensor?? jmpark527 2005-2010 Mustang GT 0 11-23-2011 08:32 AM
08:36 AM
