Brake System Upgrades 2012 Mustang - Mustang Evolution
Old 08-30-2014, 10:16 PM   #1
After some scary brake fade both on the track and twisty roads like US-129 "Tail of the Dragon," I felt it was time to improve my Mustang's braking system. My plan was to fabricate "brake coolers" from hi-temp rated tubing routed to the car's fog light delete panels (ala Boss 302) and install some new "take-off" Brembo brakes sourced from Roush.
So far, the Brembo calipers and their massive rotors have provided plenty of bite and with help from the brake coolers and DOT 5.1 brake fluid, no fade.
jip289 is offline   Reply With Quote
Old 09-02-2014, 11:11 AM   #2
Voltwings's Avatar
Looks good, wondering why you chose the 5.1 instead of a DOT4?
Old 09-02-2014, 11:52 AM   #3
bazinga11's Avatar
I guess comparatively higher boiling point - under wet and dry condition, of DOT 5.1 over DOT 4. There could be a few more factors which I might be unaware of.
Old 09-02-2014, 12:08 PM   #4
Voltwings's Avatar
You've got to try pretty hard to boil a quality DOT 4 ...
Old 09-02-2014, 01:17 PM   #5
bazinga11's Avatar
That's true, specially for the racing Dot4 fluids. Motuls RBF600 is one of them right?
So what's the other difference between a high temp Dot 4 and 5.1? Viscosity? Just trying to learn here.
Old 09-02-2014, 01:41 PM   #6
Voltwings's Avatar
Beats me, whats why i asked haha.
The Motul is one of the more liked DOT4 fluids. I'm partial to amsoil myself, although i have thought about using the Brembo brand DOT4 once or twice.
Old 09-03-2014, 07:05 AM   #7
I chose the 5.1 strictly for the higher boiling point. The brakes that came with my 3.7L Mustang went soft during a track day and I'd rather not repeat that experience.
I was approaching a sharp right-hander at the end of the straight at about 110 MPH when the brakes said "nope, not right now." Between what was left of the brakes and a downshift, I scrubbed off enough speed to avoid crashing but did slide through the corner sideways.
In the pit, I took at my brakes and not only could I feel the heat pouring off of them from several feet away, but the rotors were blue like they had been brazed with a torch.
At first I thought upgrading to 5.0 "GT" sized rotors would be enough to dissipate the heat but, on a four thousand mile road trip inspired by this Road and Track article A Two-Lane Owner's Manual - America's Best Roads Across the Country - Road & Track I turned those blue as well. On U.S. 129 "Tail of the Dragon" I could feel my brakes getting a little spongy and had to back off in order to avoid careening down a cliff into Deal's Gap. Time for BREMOS!
Old 09-03-2014, 07:37 AM   #8
Voltwings's Avatar
Is that 2.5" or 3" ducting? I noticed my (granted they're the stock GT calipers / rotors) brakes getting a little soft with my 3" ducting at my last track day. Granted, i was slowly losing the pedal, which means i was glazing my pads more than boiling my fluid ... took off over half the stock pads in 1 weekend lol, granted it was a very fast track, i was doing 150+ on the front straight.
I would almost prefer 2.5" though, simply because 3" does not fit very nicely, you have to cut and crimp and cram and zip tie all kinds of **** so your wheels dont rub, its a mess. The FRPP kit leaves a lot to be desired.
Old 09-03-2014, 07:49 AM   #9
Its three inch tubing and like you said, routing it was a pain. The drivers' side is pretty straight forward but getting the tubing around the windshield washer fluid reservoir on the passenger side was tough.
Old 09-03-2014, 10:59 AM   #10
bazinga11's Avatar
I have the same glazing problem as you did.. right from the beginning. My dealership guys had to machine my rotors, and change my brake pads within 2 months after I got my car.
Is glazing solely based on overheating of your rotors, or does it also depend on what brake pad you're using?
|| ~BlackOnBlack~ ||
Old 09-03-2014, 11:54 AM   #11
Voltwings's Avatar
Glazing is more times than not occuring on the pads. Same principle as when you glaze a clutch, and you lose engagement, since the materials are similar. Basically means the pad material has over heated and "melted" a bit, so to speak, and you may need a better compoud.
Real track pads can be very hard on street rotors, but street pads are often just that: pads for driving around. There are a few pads that can handle agressive street driving, but for the most part you are only going to want a dedicated track pad when actually on the track.
2012 mustang
For Sale: 2011 mustang non brembo brake upgrades 11socal50 Mustang Parts for Sale and Wanted 11 07-29-2014 09:13 PM
Exterior upgrades and maybe performance upgrades RedToplessPony 2011-2014 V6 Mustang 34 12-26-2011 04:09 PM
2012 Camaro SS, 2012 Mustang Boss 302, or 2012 Mustang Gt Premium? iseabail General Mustang Discussion 4 07-18-2011 10:12 PM
Fuel system upgrades? option2 Pre-2005 V6 Mustang 7 05-07-2005 06:24 PM
02:39 AM
