Procharger psi? - Mustang Evolution
Old 09-05-2014, 05:30 PM   #1
Daveauth21's Avatar
Procharger psi?
I've been researching the procharger kit for the 3.7 and I can't figure out what the base psi is. Procharger states 8psi but I noticed that most installed kits only put out around 6-7 psi. Is it just the aftermarket exhaust that's dropping the psi or did procharger change pulley size? Also what size pulley does the procharger come with?
Daveauth21 is offline   Reply With Quote
Old 09-05-2014, 06:04 PM   #2
RJ13GT's Avatar
The kit for the V8 stg 2 was advertised 7+ psi. I only saw 6 psi with mine. I have stock exhaust and everything.
2013 5.0, Black, Auto, Procharger P1SC stg 2, 4.13'' pulley(8 psi), JMS bap, 3'' x pipe, Circle D 3c, Kooks axleback, BMR control arms. 593rwhp
RJ13GT is offline   Reply With Quote
Old 09-05-2014, 06:05 PM   #3
Daveauth21's Avatar
I should have mentioned I'm talking about the kit for the 3.7 mustang not the v8 but thanks anyway
Old 09-05-2014, 07:01 PM   #4
RJ13GT's Avatar
Yeah I know that's why I stated for the v8. I think they overrate their boost on their kits. I was just sharing my experience.
Old 09-05-2014, 07:07 PM   #5
Daveauth21's Avatar
Thanks, I'm trying to figure out if a pulley swap is needed to get that 8psi. My goal is to hit 440-450rwhp on dyno with a procharger or LPF turbo kit just without headers
Old 09-05-2014, 07:38 PM   #6
2011fastford's Avatar
Region: New Mexico
6lbs you'll need a pulley swap to get those numbers.
2011 Mustang V6 auto/procharger p1sc kit with 3.70 pulley/circle d 3200 stall/4:10 gears/dss aluminum driveshaft/tial q bov/bbk long tubes with catted x pipe/dynomax ultra flo catback/bbk throttle body/accel super coils/cyclone ported upper and lower intake manifolds/brembo front brake kit
INSTAGRAM @2011fastford505
2011fastford is offline   Reply With Quote
Old 09-05-2014, 10:15 PM   #7
bazinga11's Avatar
I saw a thread of another forum where a procharger on base tune was dyno'd at 400/300 with basic bolt ons. I'm guessing it's at 7 psi (give or take). At the end of the day, that's like what ~60 units of torque over stock for $6k? (I'm not sure how much torque is gained under the curve). You will be much happier going with a turbo, ~450/400 at less than 10 psi. Given you have a good tune, and a consistent/reliable dyno.
Just my 2 cents.
|| ~BlackOnBlack~ ||
Old 09-06-2014, 12:36 AM   #8
Region: New Mexico
Just my 2 cents.
|| ~BlackOnBlack~ ||
how reliable is that though??? every turbo 3.7 i've seen with a stock motor has blown, kerdogg, solobusa,jimc, i'm sure someone with an LPF kit will chime in but those cars havent really been running around on a stock motor too long.
and with my procharger i made 406rwhp and 336rwtq...
Old 09-06-2014, 01:01 AM   #9
bazinga11's Avatar
I believe key point here would be 'circumstances/load' under which those engines were blown. I remember solobusa let his engine go around 515 while going TT route? I'm not too sure about his final numbers but again, if you push a procharger to let's say 15-20 psi of boost (if it's possible) where it is capable of making similar numbers to that of above mentioned turbo setups - I don't see anything else but kaboom!
Granted we don't have a proven turbo kit for your sixers out there yet, but I'm speaking from a theoretical point of view. Keeping boost and everything else the same, a turbo will yield better numbers in my opinion.. in general. It won't have a steady/flat torque graph like a SC; I'm sure its something that can be worked around with a tune.
Now again, I'm not saying turbo setup is best option out there. It all depends on what the person wants to do with it, what is his taste is like and what are his goals from a FI setup. It remains to be seen what LPF kit is capable of in the long run.
Ps: great numbers you've got there with your procharger! I've read your build thread on another forum.. job well done!
|| ~BlackOnBlack~ ||
Old 09-06-2014, 01:51 AM   #10
JoeyM91's Avatar
The biggest thing that keeps me in the turbo camp is that atrocious torque number from the procharger vs the turbo, granted I'd really need to see the power curve for both for a fair comparison.
Old 09-06-2014, 02:30 AM   #11
Daveauth21's Avatar
Procharger psi?
So it looks like 6psi with base pulley does anyone know what size that pulley is? I keep reading that 450rwhp is the sweet spot on these 3.7s and I don't want too push the motor to hard. Wouldn't push 10psi be too much for the stock bottom end?
Old 09-06-2014, 04:58 AM   #12
Region: New Mexico
you gotta remember motors dont let go at a certian horsepower number there is a lot of other factors that contribute to motor failure.. i will have to look at my procharger booklet to see what pulley is provided
Old 09-06-2014, 05:04 AM   #13
Region: New Mexico
one thing to keep in mind with these single turbo kits is emissions they get rid of the catalitic converters..
i'm not knocking the lpf turbo kit by any means they are definately great if you wanna make a lot of power but i'm gonna sit back and see how the LPF cars are doing in the future.. i think it takes a lot of R&D and good tuning with forced induction thats why CFM hasnt released there kit and thats why the single hellion kits have been dicontinued. if you followed my build you know that i originally started with the hellion kit and switched over to the procharger
Old 09-06-2014, 05:34 AM   #14
ponie1992's Avatar
Do you have a link to your build thread?
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 09-06-2014, 05:38 AM   #15
Region: New Mexico
2011FASTFORD: PROJECT CODE RED - Members Projects - FastFordMuscle.com
i have one on here to but i dont go into it as much
Old 09-06-2014, 05:50 AM   #16
ponie1992's Avatar
Thanks!
Jeremy
2016 Ruby Red PP GT
Old 09-06-2014, 06:35 AM   #17
Daveauth21's Avatar
Yes I have read your build thread it looks like your break just over 400rwhp but you have headers and a ported intake manifold. I only have 73mm throttle body and a o/r x pipe but I am a manual so I think with a little more boost on my set up I can make the power I want without installing headers. I would be happy at 430rwhp without headers, do you think it's possible?
Sent from my HTC6600LVW using Mustang Evolution mobile app
Old 09-06-2014, 07:10 AM   #18
Region: New Mexico
I'm sure it's possible but the stock exhaust is pretty restrictive for boost.. 2.25 inch piping
Old 09-06-2014, 07:50 AM   #19
Daveauth21's Avatar
So I need to ditch my axle back and get a catback I would rather not change my headers unless it absolutely is necessary. I have a x pipe and resonators welded in with a Roush axle back and I already attract to much attention. Headers would get me some tickets
Old 09-06-2014, 08:11 AM   #20
I would go with shorties, then the procharger and see where you are at. Then look at changing the catback to a larger diameter if you're not around where you want to be.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 09-06-2014, 08:20 AM   #21
alrefire's Avatar
For a fair comparrision, you want both a procharged and turbo car to run on the dyno on the same day
The real... boss 227
Old 09-06-2014, 11:54 AM   #22
JoeyM91's Avatar
Well for some people that may obviously be an issue. But thankfully in my state we aren't tested so I can happily do just about whatever. Obviously I can still get cited if I piss off a cop well enough to make him inspect the vehicle, but around here that's very rare.
Old 09-06-2014, 12:55 PM   #23
Daveauth21's Avatar
Same here no inspection but they will bust you if your exhaust is blasting to loud
Old 09-06-2014, 01:06 PM   #24
DirtyDan's Avatar
You have a Procharger? Are you happy...thinking of getting one
2012 v6 Black Performance Package MT CAI 3:73 Ford Racing Gears 91 Hybrid Bama tune Deleted Mufflers
2012 v6 Black Performance Package MT CAI bbk Shorties Ceramic Headers 3:73 Ford Racing Gears MPT 91/ 91 Hybrid Bama tune Deleted Mufflers
DirtyDan is offline   Reply With Quote
Old 09-10-2014, 03:42 PM   #25
Same here... But im a newbie to car mods. How does the procharger change the life expectancy of the other parts? In other words, what else should I expect to save up for? Thanks for the education!
Tac3 is offline   Reply With Quote
Old 09-10-2014, 03:49 PM   #26
Daveauth21's Avatar
From what I found supercharger oil change every 5k and belt change around 10-15k
Old 09-10-2014, 03:55 PM   #27
Daveauth21's Avatar
It's a good kit that makes good power just has a few turn offs. When belts break they sometimes damage the front seal of the blower, then when it's time to change the belt the head unit need removal for belt installation.
Old 09-10-2014, 06:58 PM   #28
DirtyDan's Avatar
Do you have any numbers? And any extra mods?..
Old 09-10-2014, 08:01 PM   #29
Daveauth21's Avatar
I don't have a procharger I was just researching it before I decided to get a turbo kit instead. The number I found looks like low 400rwhp and around 330rwlb-ft with stock car stock pulley. It seems that a full exhaust and a pulley swap to 10psi yields 440-460rwhp. Should be a good mid 12 second car with stock pulley though if you can find traction.
Old 09-10-2014, 08:40 PM   #30
DirtyDan's Avatar
What turbo? I'm not sure what I want do
Old 09-10-2014, 09:04 PM   #31
Daveauth21's Avatar
Look at the LPF turbo 3.7 thread all the info you need is there.
Old 09-23-2014, 12:25 PM   #32
Fintile's Avatar
I'm really not sure why people are so fixated on what they say are low trq numbers for the Procharger. Honesty if I was boosted I wouldn't want a whole bunch of trq. You can see with all these custom turbo kit builders they have a hard time with traction from 1st-3rd. I'd rather have lower trq and an easier chance for my tires to lock onto the road.
“anybody driving slower than you is an idiot, and anyone going faster than you is a maniac”
-George Carlin
Fintile is offline   Reply With Quote
Old 09-23-2014, 12:30 PM   #33
Better suspension and tires will fix that right up.
Old 09-23-2014, 12:39 PM   #34
^ This.
Yeah, We all want to go fast... But it's best to upgrade the rest of the stuff BEFORE you do that, So that you don't run into this problem.
RushGotti is offline   Reply With Quote
Old 09-23-2014, 12:41 PM   #35
Fintile's Avatar
I think a couple of them have all ready done so and still have issues. Hell my Dad's 07 Super Snake had issues in the same gears and he had a fully built suspension with wheels and tires. There's just a point on these car i think where it just doesn't matter people are going to want their cake and eat it too. More power to those doing these custom builds. It's awesome.
I know there are a lot of people out there like me who love modding their car but there's a certain point where they just won't cross and I think that being able to install a tried and true Procharger and gain over 100 hp to the wheels is more than enough for most.
-George Carlin
how much PSI mtchll50 1996-2004 Mustang GT 2 08-21-2004 02:00 PM
11 psi Pro Charger citti34 Mustang Parts for Sale and Wanted 4 07-13-2004 06:55 PM
which psi u think oaktonarcher Pre-2005 V6 Mustang 8 04-12-2004 07:04 PM
9 psi super charger oaktonarcher Pre-2005 V6 Mustang 1 02-03-2004 11:45 AM
why would modest psi and 35 shot be so bad on stock motor? tire Pre-2005 V6 Mustang 14 12-21-2003 10:41 PM
08:09 PM
