2010-2014 center console - Mustang Evolution
Old 09-09-2014, 10:28 PM   #1
Alright so i was poking around and took out my center console. I noticed that the silver trim for the shift boot looks like you can not remove it. Is there a way to remove the silver piece without messing anything up?
Dubau2 is offline   Reply With Quote
Old 09-09-2014, 10:30 PM   #2
Socal Stangman's Avatar
Pull off the whole center console and take it off from the bottom. Easy
Old 09-09-2014, 10:35 PM   #3
For the trim around the shift boot? mine looks like its got pressed plastic holding it in. or am i missing something?
Old 09-10-2014, 07:50 AM   #4
Yeah if you pull the console off you can see the tabs holding in the chrome trim ring.
Old 09-10-2014, 09:43 AM   #5
weird mine doesn't have any kinda tab it looks like it was plastic welded to the inner piece for the center console. Ive been thinking about making a mold out of the inner piece to lay down some carbon fiber and make a true carbon fiber piece for the car. Thinking something like a matte carbon fiber.
Old 09-10-2014, 09:45 AM   #6
So you took the console out?
Old 09-10-2014, 10:42 AM   #7
Yeah I removed the inner piece on the center console I can remove the shift boot but not the chrome ring. I'll probably just experiment when I can and put spots for screws on the carbon fiber piece to act like what I currently have. Its like they used vibration to melt the plastic over to hold the piece in. Damn the luck. It looks like you have the 2013-2014 in ypur avatar? Maybe they changed it between the 2010-2012 and 2013-2014
Old 09-10-2014, 11:24 AM   #8
The whole console has to come off. Look at these pics. You need to do this:
How to Install a Barton Industries Short Shifter - MT-82 on Your 2011-2012 Mustang GT or V6
Old 09-10-2014, 01:56 PM   #9
That part does come off its the chrome around the shift boot that doesn't detach from the rest of the inner console piece where the black arrow is pointing.
Name:	center console.jpg
Old 09-10-2014, 01:58 PM   #10
Yes, thats what Im trying to tell you. To access it you need to remove the whole console and then you'll see the tabs. If you try to pry it off or just pull it you'l probably break it.
Old 09-10-2014, 02:06 PM   #11
Here's another picture kinda showing the rounded plastic holding the chrome trim in.
Old 09-10-2014, 02:15 PM   #12
Ive never taken that part off so Im not sure. Just be careful and work slow so you dont crack it. It will be very fragile.
Old 09-10-2014, 02:26 PM   #13
I was thinking of probably using a dremel when i get around to it. where those are at ill probably have it threaded for small screws to secure it back. I'm not a huge fan of the "carbon fiber" stick on pieces. Currently working on getting a price up for a milled aluminum anodized piece for the cup holder. removing the top plate and replacing it with that piece kinda the same way.
Old 09-10-2014, 05:43 PM   #14
Dark_Pony's Avatar
Heck mine keeps popping out of place when I take a hard left. I bet I could just pop it off with a small screwdriver. Wish it was welded in...
Sent from my SM-N900V using Mustang Evolution mobile app
Dark_Pony is offline   Reply With Quote
Old 09-10-2014, 07:57 PM   #15
haha well hats nice maybe ill hit you up for a swap when i get the chance to get a mold ready if its that loose
Old 09-10-2014, 08:23 PM   #16
3.7batmobile's Avatar
Yeah when I replaced my shifter boot to change my shifter, I ended up breaking the old shifter boot. Not sure why they made it so hard to get off.
2012 3.7 Mustang; GT500 Axlebacks, 401A GT Shift Knob
3.7batmobile is offline   Reply With Quote
Old 09-10-2014, 08:44 PM   #17
yes they made it rather hard I was trying to earlier and its the two tabs on the side that are the most difficult to remove from the shift boot
2010 painted center console Mustang818 Mustang Paint, Appearance & Detailing 7 09-18-2013 01:55 PM
2010 center console in my 05 Mark221 2005-2010 Mustang GT 24 06-28-2013 09:25 AM
2010 or newer center console in 05-09 Kcstunna82 2005-2010 Mustang GT 15 12-22-2012 10:33 PM
Swap 02 console for 05 or above console-possible? Lucille Pre-2005 V6 Mustang 1 04-27-2012 06:50 PM
has anyone tried to cut and redo their center console? tire Mustang Audio & Video 10 02-22-2004 09:12 PM
07:27 PM
