Parts upgrade help - Mustang Evolution
Old 09-12-2014, 01:42 PM   #1
IS3
IS3's Avatar
Parts upgrade help
I finally decided to get 3 things from AM.
* 1 Piece Aluminum Driveshaft
* Barton Short Shifter with Kit
* 3.73 Ford Racing Gear with Kit
I was thinking about getting a CAI and Catback Exhaust system but here in California we do have to get a smog every 2 years and i dont want to be switching parts back to stock.
Anyway, for those 3 parts mentioned above will i get additional HP gains? Am I expecting a huge gain but maybe some? is this a good upgrade combination is there a better route in doing upgrades?
Thank you,
IS3 is offline   Reply With Quote
Old 09-12-2014, 01:46 PM   #2
natestang07's Avatar
Why would you gain horsepower with any of those? You will accelerate faster but no horsepower gain. You will however lose less horsepower between the crank and wheels though
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 09-12-2014, 01:53 PM   #3
IS3
IS3's Avatar
That's what i was thinking, the lighter the part the more horsepower will be freed up?
Old 09-12-2014, 01:58 PM   #4
The only thing that is helping is the driveshaft loses less horsepower than the stock one. Lighter means faster typically not more horsepower. You should notice a pretty good difference with that stuff combined
Old 09-12-2014, 02:08 PM   #5
IS3
IS3's Avatar
Do you know of any upgrades that would make the acceleration faster / add more hp without replacing the exhaust/headers/air intake parts? I forgot about the lightweight flywheel.
Old 09-12-2014, 02:11 PM   #6
bazinga11's Avatar
Is your car tuned or you running stock ford tune? -if not, tune is your friend here to gain HP. Also, you're gonna it to recalibrate your speedo anyway. Unless you're getting it done from dealership.
As for CAI, you dont need one unless you're going FI. Stock air box flows quite well, just swap out stock filter from air box with a K&N drop in filter and you should be golden. There's an active thread comparing this setup with a CAI, give it a read.
|| ~BlackOnBlack~ ||
Old 09-12-2014, 02:16 PM   #7
IS3
IS3's Avatar
Yes my car is running stock ford tune. The only reason why i left out the tune option is because i thought a CAI is required. Ill read the thread you mentioned and get more info about it.
Old 09-12-2014, 02:20 PM   #8
No you don't need a cai for tune. A tune would actually improve it a lot
Old 09-12-2014, 02:33 PM   #9
IS3
IS3's Avatar
Oh nice ill definitely get it once I am done with my first set of upgrades. The tuners are kind of expensive too.
Old 09-12-2014, 02:40 PM   #10
Unless you buy them unmarried and used
Old 09-12-2014, 03:43 PM   #11
forceflow2's Avatar
Should probably note that if you get the 3.73s then you might as well just go ahead and get a tuner anyways because your speedo will be off and you can use it to fix it. Unless of course you adjust your wheel size to try and compensate. Also, before your inspection you'll probably want to return to the stock tune depending on which kind of tune you are running.
2013 V6 Premium GHIG purchased 01/16/13
forceflow2 is offline   Reply With Quote
Old 09-12-2014, 03:53 PM   #12
IS3
IS3's Avatar
interesting, i didn't know that the smog place can tell if you have a custom tune. good to know!
Old 09-12-2014, 04:03 PM   #13
elkoritaNAY's Avatar
Here are my mods in the order I got them: flowmaster force ii, jlt cai, gt500 spoiler, mmd side scoops, mustang rocker stripes, mmd hood scoop, 3.7 and pony emblems, carbon fiber dash overlay kit, modern retro shift know, and bama x4 tuner been running it on 91 for two weeks and I'm at 22.5 mpg avg
elkoritaNAY is offline   Reply With Quote
Old 09-12-2014, 04:17 PM   #14
forceflow2's Avatar
It's not that they know it's a custom tune, it's what the tune does to the car. For instance, it might disable your O2 sensors or something, which would make your car fail emissions testing. The testers won't know why they aren't working on your car though.
Old 09-12-2014, 04:29 PM   #15
IS3
IS3's Avatar
22 MPG combined yeah? Cause I am currently 19.7 City Drive. I am leaning towards getting a tuner. BTW, i am filling my tank with 91 Octane does it matter if i have Ford stock tune?
Old 09-12-2014, 04:30 PM   #16
Yeah I do 45 mins early and 1hr afternoon driving... 25 mi each way... Half the time on freeway and half on street here in SoCal
Old 09-12-2014, 04:52 PM   #17
Catbacks are smog legal in CA. It's the mid pipe that can cause problems with the emissions testing.
You probably won't see much of a power gain from it but your car will sound faster...
Old 09-12-2014, 05:02 PM   #18
14mustang v6's Avatar
I'd worry about getting the tuner and gears if u want more hp/tq and acceleration those two r the best bang for ur buck
2014 v6 blacked out.. the only way to do it. Airaid cai, bbk tb, 93htune, 3.73 gears, and magnaflow competition exhaust
14mustang v6 is offline   Reply With Quote
Old 09-12-2014, 05:03 PM   #19
For the price ur paying for that stuff I'd get tuner gears and a axleback exhaust the axle back takes 20mins to put o
Old 09-12-2014, 05:32 PM   #20
somedopebeats's Avatar
I noticed a pretty decent gain with my aftermarket catback. That bottleneck in the stock over-axle pipes is killer.
But i dunno, i think i got a factory freak. My 2.73s with stock all season tires can spin on dry dustless asphalt without havin dumpin the clutch
Emissions here in toronto canada sound pretty much the same as cali New cars dont need a drive clean test for their first 5 years tho, then its every 2 years
somedopebeats is offline   Reply With Quote
Old 09-12-2014, 05:33 PM   #21
Did u do your gears? Do u know if handheld tuners can adjust the speedometer?
Old 09-12-2014, 06:28 PM   #22
IS3
IS3's Avatar
wait so it will pass inspection?
Old 09-12-2014, 06:44 PM   #23
Yes I did 3.73 gears and bama tunes and it adjusts it perfectly and the gears r a beast!
Old 09-12-2014, 06:52 PM   #24
Ballin! I was worried i'd have to get the calibrator which is like 200$ at AM
Old 09-12-2014, 06:53 PM   #25
Lol nope if u have a tuner it will correct ur Speedo for u!
Old 09-12-2014, 06:58 PM   #26
IS3
IS3's Avatar
speaking of tuners, i just read a thread here about SCT Tuner with BAMA tunes killing your car. Did you have any issues when you tuned your car?
Old 09-12-2014, 07:00 PM   #27
Killing car how? Lol I have x4 bama tuner running on 91
Old 09-12-2014, 07:07 PM   #28
Yes!
Old 09-12-2014, 07:20 PM   #29
IS3
IS3's Avatar
Sweet! thank you!
Old 09-12-2014, 07:26 PM   #30
That's was about 5.0s and that was back when 5.0s just came out
Old 09-12-2014, 08:31 PM   #31
IS3
IS3's Avatar
Oh cool thanks for clarifying
Got new upgrade parts! What is everyone's most recent mod? CrazyRS1 New Member Introductions & Greetings 1 01-17-2014 04:25 PM
Limited upgrade parts Polar Bear 1996-2004 Mustang GT 3 07-14-2013 09:20 PM
Crazy Singe Port Performance Parts/ 94-03 Parts Forged! v6stanger Mustang Parts for Sale and Wanted 4 10-27-2006 12:13 PM
4.2 split port engine parts/torque converter/steeda parts Horse Mustang Parts for Sale and Wanted 33 03-17-2006 04:03 PM
parts parts!!! whipster24 The Bar 1 04-22-2005 04:37 PM
06:16 PM
