Speedo recalibrated after installing 3.55 or 3.73 gears WITHOUT an aftermarket tuner - Mustang Evolution
Old 09-15-2014, 06:54 PM   #1
Can the speedo be recalibrated/corrected after installing 3.55 or 3.73 gears *without using an aftermarket tuner*??
Our V6 cars can be recalibrated thru the onboard computer at a Ford dealer to a 3.31, but do not have the calibration parameters in the computer to go to 3.55 or 3.73.
Has anyone here found a way to recalibrate the speedo without using an aftermarket tuner??
GT 1 is offline   Reply With Quote
Old 09-15-2014, 07:01 PM   #2
forceflow2's Avatar
Speedo adjuster, but that's probably not going to save you much off of a tuner and probably isn't what you mean. Short of changing your wheel size, you're SoL.
2013 V6 Premium GHIG purchased 01/16/13
forceflow2 is offline   Reply With Quote
Old 09-15-2014, 07:41 PM   #3
JoeyM91's Avatar
The dealer can tinker with your wheel size as Force said and get it close, but if you're getting gears, just get a tuner. It will make your life so much easier.
Old 09-15-2014, 07:43 PM   #4
Voltwings's Avatar
And better. If your car is an Auto, your entire shift schedule will be all out of whack since all the tables use an RPM x Load grid. A standard can probably get by without a "real tune", but no way in an auto.
Old 09-15-2014, 07:49 PM   #5
OP are you trying to save money or your warranty?
fission is offline   Reply With Quote
Old 09-16-2014, 12:45 AM   #6
Trying to save the warranty.
(I do not want to use an aftermarket tuner to correct the speedo, because the use of an aftermarket tuner could give Ford an excuse to deny warranty claims.)
This car is a 6 speed manual shift, so no worries that the automatic cars would have.
Old 09-16-2014, 12:52 AM   #7
Who makes a "Speedo adjuster"? Who sells them?
Please post a link to where they can be purchased.
Thanks.
Old 09-16-2014, 01:26 AM   #8
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Here's one: Speedometer Recalibrator. The problem with you wanting to retain your warranty is that the speedo calibrators still adjust parameter in your car's ECU. Not as many as a performance tune, just ones needed to adjust the speedometer, but it'll still leave a time stamp on the ECU which Ford could interpret as "tampering" with the programming. Not to mention the cost of the calibrator is outrageous lol.
2012 Kona Blue 3.7L V6:
Old 09-16-2014, 07:12 AM   #9
You may as well just get the tuner now !!!!
When you changed the gears you already may or may not have voided your drive train warranty. It would depend if changing the gears caused a problem. Just get a tuner and if you do go to your dealer for anything at all just put the stock tune back in. Not because of Warranty Worry but if they need to hook the car up to their computer to check something it may not function for them. Also they may want to update your computer for some emission stuff or something.
My mechanic at my dealer told me they could care less about a tune but having the tune in and they have to diagnose something it causes wasted time and sometimes causes problems. If a car comes in with the stock tune there is never a problem.
Old 09-16-2014, 07:15 AM   #10
JoeyM91's Avatar
Exactly. Unless you make a large warranty claim that would involve something changed frombthe tune or really piss someone off, as long as they can get the diagnostics off the car without issues from the tune, they don't care.
Old 09-16-2014, 07:36 AM   #11
Like Willie said to me.
The Mechanics are not computer wiz-kids and all they know how to do is plug the diagnostic machine into a customers car. They push a few buttons and the diagnostic computer tells them whats wrong.
If they can't do that, it s a huge problem. It wastes time and makes it easy to just tell a customer the warranty is puked and not any good anymore.
We were talking when I got my oil changed and I asked about what happens if I want to tune my car. He then filled me in on the reasons the dealers don't like tunes.
PS: He did also tell me he is happy he retired from being a mechanic to just changing oil and rotating tires now. He was a FORD mechanic for 30 years.
Old 09-16-2014, 07:59 AM   #12
No tuner for me.
The concern is if there is a catastrophic failure (engine or transmission) they would analyze the computer to attempt to find a way wiggle out of paying the claim eventhough correcting a speedometer had nothing to do with.
Old 09-16-2014, 08:02 AM   #13
Engine failures rarely happen due to tunes now. Actually, I don't think I've heard of one in over a year, doesn't mean it doesn't happen, but it's very, very rare... now.
Old 09-16-2014, 08:07 AM   #14
At my dealer (Which I think is the same as Ronnie's?) they basically told me that they try to warranty everything. They make money from Ford Motoco for warranty replacements. So they will try to work with you on getting something replaced. If you go in there with a nitrous plate and bottle hooked up there may be a problem LOL.
Call your dealer and ask about the tuner. Heck even Ford Racing makes a tuner for your car. Call and ask if they do the work and tell them you want to make sure that the warranty for your gears and rear will still be under affect.
Remember that if you replace gears and anything else goes they have to prove it was the gears that caused the issue.
Most dealers will replace gears in my experience.
Sent from my HP SlateBook 10 x2 PC using Mustang Evolution mobile app
Old 09-16-2014, 08:11 AM   #15
Same dealer "GY" at the auto Mall
Old 09-16-2014, 09:32 AM   #16
GrabberMeBlue's Avatar
GT 1 isn't saying that a tune would cause an engine failure, he is just saying that if he had an engine failure and the dealer found a tune loaded or footprint from one, they would do whatever they can to deny the claim. He doesn't want to go through the hassle.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 09-16-2014, 09:40 AM   #17
Interpreted that wrong. Yeah, that makes sense.
Old 09-16-2014, 10:27 AM   #18
Socal Stangman's Avatar
If youre worried about a warranty I wouldnt even do the gears.
Old 09-16-2014, 10:32 AM   #19
Stangman has a good point there
Socal Stangman If youre worried about a warranty I wouldnt even do the gears.
If you decide on changing the gears you really will need a tune to make everything work properly if your car has an automatic transmission.
Old 09-16-2014, 10:54 AM   #20
Best bet call your dealer and ask or even go there. Here is some reading that will help http://en.m.wikipedia.org/wiki/Magnu...s_Warranty_Act
The Magnusson law basically states its up to Ford/Dealer to prove beyond a doubt that your modification caused the issue trying to be covered under warranty.
Intake/Headers/Exhaust/Gears generally won't kill your complete warranty. After that good luck. Im at the stage where my next mods will void the engine. N20 and Pro-Charger. Which is why im driving my car around without doing it. That said I know if i blow the engine Ill be the one replacing it.
Ill take that responsibility at that time. (Been looking for backup 3.7 ecoboost LOL)
Old 09-16-2014, 04:10 PM   #21
Black12's Avatar
Use a Ford dealer that does high performance work. I used Sutton Ford in Matteson Ill. when I lived in that area. Some dealers get it, some don't. If your making payments and depend on warranty's holding up don't fool with the car. Just drive it. Leave tearing factory parts up to the rest of us that don't care about warranty's.
Black12 is offline   Reply With Quote
Old 09-16-2014, 05:14 PM   #22
VTHokiez's Avatar
I called a Ford Racing dealership who stated they'd install 3.73's, retune and maintain warranty. I called another Ford dealership who said they don't do gear swaps at all... I always get anything important in writing.
VTHokiez is offline   Reply With Quote
Old 09-16-2014, 10:00 PM   #23
The v6 computer does not have the option to go to 3.55 or 3.73 (the v8 5.0 computer has both)
It does have the 3.31 option, but I am wondering if that is even worth going to only a 3.31 instead of 3.55 or 3.73
Old 09-16-2014, 10:23 PM   #24
GrabberBlue1993's Avatar
Idk man if you're so worried about your warranty don't get the gears. Just wait til its up or 15-20k miles to make sure everything is good then do gears and a tune. The 3.31's are nice I got them from the factory. No desire for me to change to 3.73.
I stressed for months over tuning and I have never been happier I did. Did it with 25k on the car no problems and I love it. It's my DD. I just flash back to stock when I take it in . Haven't had any problems .
Sent from my 831C using Mustang Evolution mobile app
"At least it isn't a Honda"
GrabberBlue1993 is offline   Reply With Quote
Old 09-17-2014, 08:37 AM   #25
Worried... no.
Simply looking for accurate info to see what is possible.
Hoping to find someone that has actually done the recalibration - of their speedometer after a 3.55 or 3.73 gear swap in their v6 - without using an aftermarket tuner.
Old 09-17-2014, 11:57 AM   #26
JimC's Avatar
Originally Posted by GT 1 View Post
Worried... no.
I think that you are going to find that no one has done it without a tuner. Reason: the ECU controls it so unless you change the ECU with a tune you can't change the speedometer.
The dealer can only flash with a stock set up. So, no 3.73 from the factory, or 3.55, on the V6 prevents the dealer from changing the parameter to a stock set up
JimC is offline   Reply With Quote
Old 09-17-2014, 12:01 PM   #27
JimC's Avatar
Worried... no.
The dealer can only flash with a stock set up. So, no 3.73 from the factory, or 3.55, on the V6 prevents the dealer from changing the parameter to a stock set up.
Even going to 3.31 where the dealer can get a stock tune won't preserve the rear end warranty. Ford warranties the car that Ford built, not the one you built. The rear end won't match the build data so if it breaks Ford won't warranty that rear end.
Old 09-17-2014, 12:34 PM   #28
I've heard in the past that if a Ford replaces the rear end, they will give you a separate, one year warranty on that alone.
1979 Gold Trans Am
Old 09-17-2014, 02:00 PM   #29
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Most shops will warranty the work they do as well, usually for one year. That's one thing I looked for when finding a shop to install mine. And I believe Ford Racing gears have a manufacture warranty, so those combined cover product and the install.
Worried... no.
You won't find anyone who has because fixing the speedometer requires changing parameters in the ecu. If it's the performance tune you're trying to stay away from and not the use of the tuner itself, then get the speedometer calibrator. It "tunes" your vehicle for the new gears, but all it touches is what's needed to correct the speedo. Like I previously said, it'll still leave a time stamp on the ecu.
Installing GT500 Spoiler Without Drilling? (Just tape?) lisl12 Mustang DIY and Technical 7 10-19-2014 06:37 PM
Speedo and interior lights not working after new radio! calebnaasko 1996-2004 Mustang GT 9 07-01-2013 10:58 PM
Break in for new gears?? SCT tuner to change speedo?? Camaro Eater Pre-2005 V6 Mustang 3 06-25-2010 07:03 AM
dash lights out after installing aftermarket radio vblic 1996-2004 Mustang GT 3 08-10-2007 05:46 PM
12:11 PM
