Diff Leak? - Mustang Evolution
Old 09-19-2014, 10:46 PM   #1
VIG
VIG's Avatar
Region: Delaware
Diff Leak?
I was under my car tonight and noticed this.
I know the right side axle shaft is slightly bent from me being an idiot and sliding into a curb, but this is on the left side. Weird.
I'm still under warranty. Wonder what they'll say?
Name:	ImageUploadedByMustang Evolution1411188358.669848.jpg
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 09-20-2014, 12:15 AM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
That's normal due to how the little valve on top of the left axle tube is designed. I believe there is a TSB out that has them replace it with type of breather. It's supposed to make less of a mess I guess.
2012 Kona Blue 3.7L V6:
Old 09-20-2014, 01:02 AM   #3
JoeyM91's Avatar
I had mine get progressively worse before I just did my gears and rebuild.
An axle bearing and seal were starting to go. Caused a whirring scratching noise as well. Keep in mind my car has 60k miles though. That's right on the dot of when those bearings and seals should be replaced.
Old 09-20-2014, 07:15 AM   #4
VIG
VIG's Avatar
Region: Delaware
Oh sweet!
That's a relief.
I saw that valve up there, but I didn't know it was a valve when I was looking at it.
2012 Mustang GT Diff leak diego302 2011-2014 Mustang GT 4 02-14-2013 04:49 PM
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
grinding noise from diff. Horse Pre-2005 V6 Mustang 8 04-27-2004 04:47 PM
is there much diff??? v6white98 Pre-2005 V6 Mustang 13 12-25-2003 03:15 PM
open diff. you sure? oaktonarcher Pre-2005 V6 Mustang 8 09-16-2003 05:29 PM
03:27 PM
