Tire size - torque ratio - Mustang Evolution
Old 09-20-2014, 12:45 AM   #1
grom80's Avatar
Hey guys.
Was running 215/65/17 wheels on my 2013 V6 and have been thinking of Switching them out to 255/40/19...
What di you think ? Which one is batter torque/power ?
Thanks
Diego
grom80 is offline   Reply With Quote
Old 09-20-2014, 07:20 AM   #2
VIG
VIG's Avatar
Region: Delaware
The 255/40/19s are 0.97" shorter than the 215/65/17s, essentially gearing your car down.
The 255s will also have better handling and steering feel.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 09-20-2014, 07:23 AM   #3
alrefire's Avatar
Whatever you do, don't try to put wide 28" tall tires up front...
I did that, and i rubbed
The real... boss 227
Old 09-23-2014, 12:41 PM   #4
grom80's Avatar
Cool thanks, that's what I figured...smaller circumference should lead to better torque...theoretically...
Old 09-23-2014, 01:04 PM   #5
Voltwings's Avatar
it does, its just incredibly marginal, less than .1 difference in the effective gear ratio. A 28" tire on a 3.31 car is basically the same as a 27" tire on a like... 3.23 geared car.
Old 09-23-2014, 02:01 PM   #6
VIG
VIG's Avatar
Region: Delaware
Yeah, there are online calculators. I'm going from a 245/45/19 to a 255/40/19 and the difference makes it equal to going from a 2.73 gear to a 2.80.
Not much of a difference.
Old 09-23-2014, 03:02 PM   #7
14mustang v6's Avatar
So the smaller the sidewall the bigger the gear ratio?
2014 v6 blacked out.. the only way to do it. Airaid cai, bbk tb, 93htune, 3.73 gears, and magnaflow competition exhaust
14mustang v6 is offline   Reply With Quote
Old 09-23-2014, 03:33 PM   #8
Voltwings's Avatar
Just to avoid confusion, the shorter the tire, the higher the gear ratio. The sidewall is an aspect ratio, not a set length, so its possible for say a 295 35 19 to be taller than a 245 40 19. Make sense?
^^ I didnt bother pulling up a calculator so those numbers are literally just pulled out of my ***, I'm sure someone could check the math, but my point remains the same.
Old 09-23-2014, 03:35 PM   #9
VIG
VIG's Avatar
Region: Delaware
Right. It's the overall diameter of the tire. Not the sidewall.
Old 09-23-2014, 03:48 PM   #10
grom80's Avatar
And the overall smaller diameter, gives you more torque...so a 255/40/19 has more torque than a 215/65/17...
Old 09-23-2014, 03:56 PM   #11
VIG
VIG's Avatar
Region: Delaware
You got it.
The 255/40/19 is 0.97" shorter than the 215/65/17.
Old 09-23-2014, 04:10 PM   #12
Can u post what calculator ur useing
Old 09-23-2014, 04:12 PM   #13
Old 09-23-2014, 04:13 PM   #14
Originally Posted by 14mustang v6 View Post
What about going from a 235/50/18 to a 275/35/20?
---------- Post added at 05:12 PM ---------- Previous post was at 05:11 PM ----------
I have 3.73s
Old 09-23-2014, 04:16 PM   #15
Sorry app is glitching but yea I have 235/50/18 on all four tires and I want to put 255/35/20 front and 275/35/20 back.. I have 3.73s what would the gear ratio be then
Old 09-23-2014, 04:21 PM   #16
Voltwings's Avatar
Should be the exact same, your current tires are 27.25" and the 20s will be 27.5". Thats a difference of treawear. I dont have one for effective gear ratios i use, but you can just google tire height calculator, and any will do.
what size rims and what size slicks for 2005 GT? inzain Mustang Wheels & Tires 3 11-30-2013 08:37 PM
Biggest rear tire size on 18" tire ChrisMustangs Mustang Wheels & Tires 6 06-24-2013 02:46 PM
Tire size and rim size 96gt Lios 1996-2004 Mustang GT 9 04-22-2012 10:33 PM
How will an incorrect aspect ratio tire affect my car? Fferyll 1979-1995 Mustang GT 4 12-11-2011 06:58 AM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
03:26 AM
