Longtube Woes - Mustang Evolution
Old 09-20-2014, 11:24 PM   #1
cjohnson91's Avatar
Longtube Woes
After installing my longtubes and catless x-pipe tonight (about 4 hours with the help of some friends), I went to take my car for a test drive and found that I no longer have a speedometer, my airbag light is on, my gas light is on even though I have 3/4 tank of gas, there is wrench symbol on my RPM gauge, and I almost entirely lose power after about 3k rpm's. Anyone else experience these problems before? Or have any guesses as to what be causing them?
cjohnson91 is offline   Reply With Quote
Old 09-21-2014, 01:40 AM   #2
o2bav8's Avatar
Do you have a tune for no cats? That's really going to upset the ECU...
o2bav8 is offline   Reply With Quote
Old 09-21-2014, 01:49 AM   #3
Have you jacked the car up and looked under the hood to make sure nothing is unplugged? It sounds like something electrical was not hooked back or the headers could have possible burnt through a wire. Only reason I ask is that you mentioned 'friends' helped so although you plugged everything you unplugged in maybe someone else forgot something?
Not having a tune would through a CEL light and potentially mess with the power but shouldn't affect the other things you mentioned.
StarzTA17 is offline   Reply With Quote
Old 09-21-2014, 01:51 AM   #4
You need a custom tune with those mods...
Sent from my SM-N9005 using Mustang Evolution mobile app
2014 6 banger premium (girls' mustang)
Performance: Roush CAI, LT headers, off road x pipe, 73mm TB, Ford racing 4.10 gears, H&R LS, DSS aluminum driveshaft, Magnaflow exhaust, Nitto NT05,SCT X4, Lund Racing tune
Exterior: Real carbon quarter panel window louvers+Side scoops+Side diffusers, Polished billet retro grill, 20' AR rims
Soon: Procharger & NOS
dubaighost is offline   Reply With Quote
Old 09-21-2014, 07:29 AM   #5
cjohnson91's Avatar
I ordered my tune and it isn't yet, but the headers shouldn't cause things like my airbag sensor coming on and no speedo should it? I double checked to make sure everything was plugged in before dropping the car back on the ground. Everything worked fine going down my driveway (about 1/2 mile) then when I went to pull on the road it was like a total system melt down all of a sudden.
Old 09-21-2014, 07:40 AM   #6
2011fastford's Avatar
Region: New Mexico
Check your fuses in the passanger side kick panel sounds like you blew the air bag fuse putting the car in limp home mode.. that's my idea anyway
2011 Mustang V6 auto/procharger p1sc kit with 3.70 pulley/circle d 3200 stall/4:10 gears/dss aluminum driveshaft/tial q bov/bbk long tubes with catted x pipe/dynomax ultra flo catback/bbk throttle body/accel super coils/cyclone ported upper and lower intake manifolds/brembo front brake kit
INSTAGRAM @2011fastford505
2011fastford is offline   Reply With Quote
Old 09-21-2014, 07:41 AM   #7
cjohnson91's Avatar
Hmm, I didn't even think to check any fuses, thats a good thought, thanks!
Old 09-21-2014, 08:28 AM   #8
You don't NEED a custom tune. Your check engine light will come on and you may run a little lean. But nothing on the dangerous side. Check your fuses and wiring.
fission is offline   Reply With Quote
Old 09-21-2014, 09:29 AM   #9
Region: New Mexico
I'm positive it's a fuse you blew I only know because I've blown a couple triggering some of your symptoms lol
Old 09-21-2014, 10:18 AM   #10
Voltwings's Avatar
Theres a lot of wires between the transmission and exhaust, one of which is likely the speedo reading (off the transmission), so my bet is your burned up some wires.
Old 09-21-2014, 10:40 AM   #11
cjohnson91's Avatar
All fuses and connections are good. A couple relays were fried though, swapped them out and fried the new ones too, guess it's time to take it into a shop
Suspension woes charkelly9 Pre-2005 V6 Mustang 9 07-22-2008 06:56 AM
'07 Pony "earl" woes greaser Pre-2005 V6 Mustang 16 09-24-2006 08:42 PM
charging system woes Thomas91169 Mustang Audio & Video 15 08-12-2006 12:34 AM
college woes jimmy_beaner The Bar 27 10-31-2004 10:55 PM
window woes el cheapo Mustang Audio & Video 13 10-06-2003 11:59 AM
05:14 PM
