2011-2014 mustang v6 fake 305 hp - Mustang Evolution
Old 09-29-2014, 08:23 AM   #1
IS3
IS3's Avatar
I saw an article and a few videos about the 11-14 mustang v6 advertised with 305hp but the dyno results shows around 250hp. Can someone explain to me why? Isn't that false advertisement?
IS3 is offline   Reply With Quote
Old 09-29-2014, 08:27 AM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
It's 305hp at the crank, approximately 250-270 at the wheels. You've got to factor in drivetrain loss (auto or manual) as well as local weather/altitude conditions. It can also change from dyno to dyno.
2012 Kona Blue 3.7L V6:
Old 09-29-2014, 08:27 AM   #3
elkoritaNAY's Avatar
Rwhp not engine hp is what you are referring to. 305 is at the engine and 275 or whatnot is power at the rear wheels
Flowmaster force 2 exhaust, jlt cai, x4 bama tuner, carbon fiber dash overlay kit, modern retro shift knob, mmd hood and side scoops, classic quarter louvers, gt500 spoiler, 3.7 and pony emblems, mustang rocker stripes, eibach anti sway roll bar kit
elkoritaNAY is offline   Reply With Quote
Old 09-29-2014, 08:30 AM   #4
IS3
IS3's Avatar
So in reality a mustang v6 or even say an 08 350z isn't on the 300 hp range. Kind off disappointing...
Old 09-29-2014, 08:32 AM   #5
Joaquin_ii's Avatar
+1
they advertise as the hp from the crank. but you will loose power as it reaches to the back tires. which is why some people post RWHP (rear wheel horse power) on this forum. as stated
Joaquin_ii is offline   Reply With Quote
Old 09-29-2014, 08:33 AM   #6
Joaquin_ii's Avatar
correct. neither is in the 300 range but you can surely get it in that range
Old 09-29-2014, 08:35 AM   #7
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Not really disappointing when you think about where N/A V6s were at prior to this. And horsepower at the motor is what ALL manufacturers rate their vehicles on, meaning a lot of those 300-range hp cars are actually mid to high 200.
Old 09-29-2014, 08:36 AM   #8
IS3
IS3's Avatar
By making the car lighter (replacing parts with aluminum or carbon fiber) will it help raise the rwhp? Or do you have to make major mods like making the engine breathe better or use force induction?
Old 09-29-2014, 08:46 AM   #9
Laquisha's Avatar
Yes making a car lighter gives a car more horses. 🙊😋
Old 09-29-2014, 08:47 AM   #10
Laquisha's Avatar
OP,
Weight reduction does not make the car produce more power, but it does make the car move faster since lighter weight.
Old 09-29-2014, 08:54 AM   #11
IS3
IS3's Avatar
Lol sorry I just thought about it.
Old 09-29-2014, 09:18 AM   #12
SixBanger's Avatar
Well no. The Mustang V6 is in the 300hp-range. The Cyclone V6 makes over 300 peak horsepower. Those 305 horsepower are not all transferred through the wheels because of drivetrain loss. So both the Mustang and 350Z are in the 300hp club.
And engine horsepower isn't constant either. The engine doesn't make 305 horsepower at idle - as a side note.
2014 V6 Base Coupe, Sterling Gray Metallic///3.31 Gears///FP6 Appearance Package///Tech. Package///Reverse Sensing and Security Package///Mods: Boss 302 grille, MMD Ducktail Spoiler, Weathertech Floor Mats, Bassani Axle-Back Exhaust
SixBanger is offline   Reply With Quote
Old 09-29-2014, 09:39 AM   #13
bucko's Avatar
If you think this is "disapointing", it's good you did not live and own musclecars that existed in the 80's and 90's!
Even the crank rated HP of the Mustang's current V6 tops the HP rating of the V8's of the 60's and 70's.
Old 09-29-2014, 09:40 AM   #14
bucko's Avatar
Old 09-29-2014, 09:56 AM   #15
Not true, a good amount were rated at more than 305 back in the mid to late 60's. Mainly big blocks though.
Old 09-29-2014, 10:01 AM   #16
Voltwings's Avatar
with twice the displacement lol. Hell, the original Fox 5.0 made all of 225 at the crank... crazy how far we've come, there's 4 cylinders nearly making that from the factory all motor now.
Old 09-29-2014, 10:15 AM   #17
Midnight2012's Avatar
Oh but it is true. In the 60's and 70's HP was rated at SAE Gross. Today the ratings are SAE Net at the crank. Net is roughly 80% of Gross. Therefore a 67 Mustang 390 V8 rated back then at 320 HP would be rated 256 HP today. Reversing the situation our 3.7s would be rated 385 HP by 60s/70s standards. Now that little 256 HP 390 had tons more torque, yet only running high 14s in a quarter mile. There was a history of under rating HP figures for insurance purposes but not by a lot in most cases.
Midnight2012 is offline   Reply With Quote
Old 09-29-2014, 10:29 AM   #18
The engine makes 305 horsepower. But think.... The transmission, driveshaft, and rear gears still need something to turn them. It takes power for that. So you lose a bit of your power through that before it actually gets to the pavement.
Old 09-29-2014, 10:30 AM   #19
Strange Mud's Avatar
so a number on paper makes your car feel not as fun?
Also to clarify less weight does not change HP but it does make it faster...
I will say the power/performance/mpg of these engines is great. They also make a decent sound and seem to be rather reliable. The differance between 2k rpm and 4k when the TIVOT starts kicking into POWER!!! is great use of technology and a hoot whenever you get on it. Every time I use 3rd to pass someone I am amazed at what Ford has done with these cars.
Old 09-29-2014, 10:31 AM   #20
That's interesting midnight! So can we easilly assume that the 3.7 can easily outrun a stock 289 in the 60s? :p
Sent from my SM-N9005 using Mustang Evolution mobile app
2014 6 banger premium (girls' mustang)
Performance: Roush CAI, LT headers, off road x pipe, 73mm TB, Ford racing 4.10 gears, H&R LS, DSS aluminum driveshaft, Magnaflow exhaust, Nitto NT05,SCT X4, Lund Racing tune
Exterior: Real carbon quarter panel window louvers+Side scoops+Side diffusers, Polished billet retro grill, 20' AR rims
Soon: Procharger & NOS
dubaighost is offline   Reply With Quote
Old 09-29-2014, 10:32 AM   #21
bigmac3's Avatar
The 302ci in an original 1979 Fox body didn't put out but 140hp. It didn't get to 225hp until 1987. That number was later dropped in 1989 to 205hp until the advent of the 1993 Cobra with a whopping 235hp. Woohoo!
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 09-29-2014, 10:45 AM   #22
None of the HP #'s you see on a manufacturers page, Are to the wheels... It's always the amount of power the ENGINE produces.
RushGotti is offline   Reply With Quote
Old 09-29-2014, 11:05 AM   #23
Voltwings's Avatar
Originally Posted by RushGotti View Post
None of the HP #'s you see on a manufacturers page, Are at the crank... It's always the amount of power the ENGINE produces.
To avoid confusion, i think you mean at the wheels. "At the crank" = engine HP, "At the wheels," obviously is whp after drivetrain loss.
Old 09-29-2014, 11:32 AM   #24
hctr154's Avatar
Engine horsepower has come a long way in recent years. 305 hp from a base model V6 Mustang is pretty cool compared to some of those Mustangs in the past. Let's not forget the couple of years (80-81?) the GT was saddled with a pathetic 4.2 liter V8 that was way down on power (120 hp IIRC) and a gas hog.
My first Mustang was a '94 Mustang Cobra rated at 240 hp. Since it was heavier that the previous Cobra, it was actually a little slower in straight line speed.
hctr154 is offline   Reply With Quote
Old 09-29-2014, 11:40 AM   #25
Correct, My apologies. Post corrected to reflect what I originally meant.
Old 09-29-2014, 12:08 PM   #26
bigmac3's Avatar
My second 1966 coupe had a 271hp 289ci (4.7L). At just under 2,800lbs and 3.50 gears, it was quite a little screamer. Starting in 1974 with the gas crunch and tree huggers gone mad, horsepower went out the window. I'm so glad that it has returned with a vengence.
Frank
Old 09-29-2014, 12:53 PM   #27
No imagine if we weren't saddled down with emissions regs.
Old 09-29-2014, 01:33 PM   #28
bigmac3's Avatar
Yeah, look at the hp they get out of a 1.6L V6 in a F1 car. Unbelievable!
Frank
Old 09-29-2014, 02:51 PM   #29
b2673ad's Avatar
Interesting thread
Kevin C.
2015 Roush RS1 Premium w PP
Roush Performance upgrade-- Tinted Windows
JLT Catch Can--Ford Racing Strut Brace
Flowmaster scavenger "Y" pipe resonator delete
b2673ad is offline   Reply With Quote
Old 09-29-2014, 04:35 PM   #30
Yes including the 271 HP HIPO. Quicker than a stock Boss 302, Boss 429 and the 390 I mentioned. The Torque was where all the fun was. They are stock for stock in the quarter as quick as The 428 Cobra Jet. 1/8 mile I'm going to guess all those cars were quicker because of the torque.
As comparison the stock 65 289 2 barrel ran 17 seconds or so.
Old 09-29-2014, 04:47 PM   #31
Doesn't the Boss 429 run 11s?
Old 09-29-2014, 07:42 PM   #32
JDM
JDM's Avatar
1969 Boss 429 Mustang
1/4 mile: 14.0 @ 103
The engine was primarily developed for Stock Car (NASCAR) racing.
JDM is offline   Reply With Quote
Old 09-29-2014, 07:59 PM   #33
That's what it's rated at. But I know for a fact it is one of the most under rated cars ford ever produced
Old 09-29-2014, 08:03 PM   #34
That and the Mach 1 with the 428 Cobra Jet.
Old 09-29-2014, 08:52 PM   #35
Ford Boss 429 engine
It was designed for Nascar Racing but was never used due to Ford pulling out. It was put in Mustangs but made the Mustangs so front heavy it worked against the performance.
They sure bring a lot of $$$$$ if you can find one.
I forget the name of the company but they got license from Ford to manufacture the Boss 429 engines. I'll try to find out the name of the company when I go to Breakfast with my Street Rod friends Saturday morning.
The 428 Cobra jet worked much better in the Mustangs. It was good for everything except handling because it was heavy too.
The 351 engines always did work the all around best in Mustangs and Comets back in those days for all around performance. The were much lighter and still produced a good amount of power.
That was the good old days when Tires, Brakes, etc. just plain sucked. But it was really fun for us Car people back then.
2014 mustang
//////// whos got some nice rear pics with 305 tires //////////// prcmauricio Pictures and Videos 13 04-06-2013 11:29 AM
305 on laguna seca rims?? McQueen 2011-2014 Mustang GT 7 04-02-2013 01:43 PM
2 gt500 wheels with 305/35-18 nitto 555rs godsdisciple85 Mustang Parts for Sale and Wanted 2 02-07-2013 09:57 AM
285,295,305 or 315 for 18x10 rims?? 1hotv6 1996-2004 Mustang GT 21 09-21-2012 10:21 AM
Intimidator 305 wiarumas The Bar 3 09-13-2010 03:56 PM
01:10 PM
