Clutch problem! - Mustang Evolution
Old 09-29-2014, 12:05 PM   #1
Clutch problem!
So I was driving from pensacola to atlanta. Then in the middle of the highway the clutch didn't work! After I pulled over to the side, I tried to put to 1st gear and release the clutch but the car didn't accelerate! Anyone has any idea what happened to my car? It's a v6 2013.
sempak is offline   Reply With Quote
Old 09-29-2014, 12:08 PM   #2
elkoritaNAY's Avatar
Ouch man no Bueno. I have a 14 manual w 21000 miles and I haven't had any clutch issues
Flowmaster force 2 exhaust, jlt cai, x4 bama tuner, carbon fiber dash overlay kit, modern retro shift knob, mmd hood and side scoops, classic quarter louvers, gt500 spoiler, 3.7 and pony emblems, mustang rocker stripes, eibach anti sway roll bar kit
elkoritaNAY is offline   Reply With Quote
Old 09-29-2014, 01:23 PM   #3
Voltwings's Avatar
Going to need a lot more detail than what you provided there ... Did the car go into gear? Do you have pedal pressure? basically all the info you can give.
Old 09-29-2014, 03:35 PM   #4
Yeah it did go into the gear. The pedal pressure is just normal. But it was stuck then go back to normal like 45 minutes before the car won't accelerate.
Old 09-29-2014, 06:03 PM   #5
Voltwings's Avatar
OK, if you have normal pedal pressure,
The transmission will go into gear
The car does not accelerate in gear?
Based on the still limited information:
Do the rpms change when you push the gas, but the vehicle physically does not move? If so, clutch is likely shot and/or worn out.
If the rpms do not change and the vehicle does not accelerate when the gas is applied then the issue is not the clutch if you are able to get it in gear.
Clutch adjuster, clutch, or tranny Elcobrachingom SVT Mustang 3 09-05-2012 07:32 PM
clutch slipping and new clutch? iphonemaster93 Pre-2005 V6 Mustang 29 08-06-2012 10:37 AM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 04:53 PM
just installed new clutch ram hdx drove about 5 miles and clutch got really hard? Cobra209 SVT Mustang 11 04-01-2012 05:44 PM
Dual Clutch Vs Single Clutch 504 Stang Rida 1996-2004 Mustang GT 7 11-29-2011 08:22 PM
03:26 AM
