Tire pressure monitoring system :/ - Mustang Evolution
Old 09-30-2014, 09:58 AM   #1
RomanG's Avatar
Hello forums, I recently ran over rail road track pretty fast recently And immediately after my TPMS light came on and on "TMP Sensor Fault" appears in the dash.
I want to replace the sensor, i assume it cracked or something. However, the dash doesn't tell me which one is faulted, or how many faulted.
How would i be able to find out which it is, id prefer not to not take all the tires off to inspect the sensors.
RomanG is offline   Reply With Quote
Old 09-30-2014, 10:02 AM   #2
Voltwings's Avatar
That light can also indicate your tires pressures need to be checked, not necessarily that a sensor has failed. Did you check your tire pressures?
Old 09-30-2014, 10:05 AM   #3
RomanG's Avatar
Well I've had a "Tire pressure low" light come on before, so aren't they different? I check my pressure on a weekly basis, i run thin tires
Old 09-30-2014, 10:13 AM   #4
JoeyM91's Avatar
Yeah the fault and just low pressure are different. Wouldn't hurt to go ahead and check the pressure regardless.
As for diagnosing which one is damaged, I'd say go to Ford. They likely have a machine that will communicate with each sensor and find the one that isn't responding. Much like the calibration tool you can buy for aftermarket wheels.
Old 09-30-2014, 10:14 AM   #5
Voltwings's Avatar
I stand corrected then lol. Carry on.
I would not however go to Ford, you will likely pay the most there. I've found Pepboys has the best prices on anything tire related (other than maybe the tires themselves).
Old 09-30-2014, 10:16 AM   #6
RomanG's Avatar
I figured thats what it would come down to i was hoping there would be an less time consuming option.
Old 09-30-2014, 10:18 AM   #7
RomanG's Avatar
Thanks guys
Old 09-30-2014, 10:21 AM   #8
Strange Mud's Avatar
or a small piece of painters tape over the light.....only takes 30 seconds
I just put on my cold weather shoes which don't have sensors.
Old 09-30-2014, 10:38 AM   #9
Grabber Blue5.0's Avatar
I haven't run TPMS valves in my car for years.
Old 09-30-2014, 10:46 AM   #10
RomanG's Avatar
The little light doesn't bother you? Im OCD about that kinda thing
Old 09-30-2014, 04:40 PM   #11
Doesn't bother me. When you shut off traction control there's a light for that as well.
Old 10-01-2014, 04:37 AM   #12
the msg in the info center goes away with pressing reset (it does come on next time you start) but the painters tape covers the light and does not leave residue. I would have paid more for a set up with TPMS still in them but ain't gonna go the the expense/chance of rim damage to add it.
Old 10-01-2014, 05:04 AM   #13
stanglife305's Avatar
Ford has a tool that checks each sensor and they sell the sensor for like $3
stanglife305 is offline   Reply With Quote
Understanding SCT monitoring help Stephen06v6 2005-2010 V6 Mustang 0 07-30-2013 12:07 PM
How does the SCT data logging and monitoring work rebeltx 2011-2014 V6 Mustang 3 01-30-2013 08:29 AM
06 gt. The ecm has detected pressure in the EVAP system Silver GT 2005-2010 Mustang GT 3 03-23-2012 09:25 AM
fuel line pressure vs rail pressure Sirtat 2005-2010 Mustang GT 2 01-10-2012 05:03 PM
01 gt diablo tuner monitoring lowering kit 1996-2004 Mustang GT 0 06-20-2008 07:59 AM
02:07 PM
