Sync is not working? - Mustang Evolution
Old 10-03-2014, 01:39 AM   #1
Hey guys, my bad for not searching but I'm somewhat at work and driving at the same time? Lol anyways earlier the port in the center console lost power, didn't think anything of it until now that I pressed aux and it goes to the am channels... Meaning none of the auxiliary, including Bluetooth and sync work.
What could it be?
Sent from my HTC One Max using Tapatalk.
RushGotti is offline   Reply With Quote
Old 10-03-2014, 08:55 AM   #2
Sakib's Avatar
What could it be?
I had the exact same symptoms when I got a new phone. Maybe when you lost power to the console the system forgot your phone. Try re-pairing your phone, as if it was new. The instructions are on page 11 of the Sync manual. Hopefully this will solve your problem.
Sakib is offline   Reply With Quote
Old 10-03-2014, 09:57 AM   #3
No, When I press "Aux" it goes blank and moves to the AM/FM stations...
Like, The port doesn't have power, No sync line in pops up, no bluetooth, nothing!
Old 10-03-2014, 10:01 AM   #4
Sakib's Avatar
I understood that. The same thing would happen to mine. Aux won't do anything if there is no phone or device plugged in, and it will go back to radio. You pair the phone by holding the phone button on the steering wheel. That's the first step, I don't remember the rest of the steps off the top of my head. You'll have to check the instructions on page 11 of the manual. I looked up the page number before I came to work because I saw your post.
Old 10-03-2014, 10:15 AM   #5
Oh, Okay! My bad. =P
I just got home right now, I'll go try it out in a bit!
Although I'm not sure why that would cause the port to lose power (Fail to charge the phone), But I'll try it out!
Old 10-03-2014, 01:50 PM   #6
Sakib's Avatar
Yeah, I'm not sure either. That is weird. The symptoms of your problem are the same as mine, but not necessarily the root cause, so it might not work for you. I hope it does..
Sent from my HTCONE using Mustang Evolution mobile app
Old 10-04-2014, 12:44 AM   #7
Okay, just tried it and the controls on the steering wheel no longer work either.
Do the main sound processor and sync module use the same fuse? I'm at work again but I'm about to look for the diagram online so I can check it after work.
Old 10-04-2014, 02:12 PM   #8
Sakib's Avatar
Socal stangman knows a lot about this stuff.
Old 10-06-2014, 01:38 PM   #9
...Ugh. Took me a while, But I checked the fuses and that wasn't the problem.
Even though the fuses were good, I still changed the SYNC and AUX ones to be 100% sure and nothing.... =/
I'll contact Socal Stangman and see if he knows what else it could be. Thanks.
Old 10-06-2014, 01:57 PM   #10
Socal Stangman's Avatar
Did you try swapping out the cables?
Old 10-06-2014, 02:08 PM   #11
Which cables should I be swapping out exactly?
If you're talking about the USB cable I use to connect my phone, Then yes. I tried 3 different ones and none worked. =/
Old 10-06-2014, 02:21 PM   #12
Ok...and you havent taken apart the center console for anything?
Old 10-06-2014, 02:30 PM   #13
Nope, It was working and I stopped by the DMV, Left a cellphone connected to the USB while I went inside, Came out and it no longer worked....
Old 10-06-2014, 02:32 PM   #14
Have you tried unplugging your battery? If not unplug it for at least 20 mins. to reset the computer..
Do you have a warranty? This might be an issue for Ford to deal with...
Old 10-06-2014, 03:26 PM   #15
Hadn't tried that, Just unplugged it and let it sit for 30 minutes, plugged back in and same issue.
Yeah, I think I still do. It's a 2013 with 28,000 miles... When I go take it for the emissions recall, I'll ask them about it... =/
Thanks!
Old 10-06-2014, 05:10 PM   #16
@Socal Stangman
That must have done the trick, Although it didn't work immediately, I drove to get some food and halfway there decided to press AUX and it actually worked again.
Thank you for your help!! I appreciate you taking the time to help me troubleshoot this !
Old 10-06-2014, 05:26 PM   #17
Sakib's Avatar
Just like fixing computers... if all else fails, restart, haha
Old 10-07-2014, 12:09 AM   #18
GrabberBlue1993's Avatar
I would just bring it in to the dealer and have them check to make sure it doesn't happen again or nothing is wrong. Might as well have them check now for free rather than it be fine for a few months then "conveniently" stop working again right after your warranty is up
Sent from my 831C using Mustang Evolution mobile app
"At least it isn't a Honda"
GrabberBlue1993 is offline   Reply With Quote
Old 10-08-2014, 12:43 AM   #19
jonyou's Avatar
I agree with grabber. This same thing happened to me but I did the battery trick, worked ever since. I would be more worried if I was as close to warranty as you were. There is a Sync TSB however. So I'd say just go ahead and get it checked out for free.
TSB 13-09-22 - Effective Sep 25 2013
SYNC - Various vehicles equipped with SYNC may exhibit concerns related to SYNC features. Refer to the vehicle list to determine applicable vehicle lines and build dates located in the Service Procedure Section along with complete symptom details
2014 V6 Performance Package Sterling Grey
MPT Tuned.
Airaid CAI, BBK Shorty Headers, Borla S-types, Stubby Antenna, JLT Catch Can, MMD hood struts, GT500 spoiler, Oracle Halos on GT Grille, Dynotech One piece Aluminum Driveshaft.
jonyou is offline   Reply With Quote
Old 10-08-2014, 12:44 PM   #20
Fintile's Avatar
SAKIB just sent me to take a look. I have been dealing with this issue off an on now the past 2 years. i just thought it was normal. SYNC is a product of Microsoft and we all know how they are. Now this TSB. Will I be able to get this done no charge? I'm past the 40k miles now so not sure what is covered still. either way 3 years in a car made in 2012 shouldnt get problems like this that the manufacturer wont fix.
Fintile is offline   Reply With Quote
Old 10-08-2014, 01:00 PM   #21
@Socal Stangman
Cool Im glad it worked.
Old 10-08-2014, 02:45 PM   #22
Sakib's Avatar
I should get the tsb checked out too. Although I didn't have that problem, Sync in my car just plain sucks. People can never understand me when I talk on it, they always complain and I end up just talking normally on my phone and they go, "Oh, that's much better."
Old 10-08-2014, 10:32 PM   #23
jonyou's Avatar
If there is a TSB on it and your symptoms sound similar to the problem they should fix it whether you are in warranty or not. At least that's what Bucko said.
MPT Tuned.
Sync Apps not finding apps iPhone Mlarv5 Mustang Audio & Video 7 06-08-2013 10:47 PM
Iphone 5 new sync not working Ratraget Mustang Audio & Video 6 01-12-2013 08:01 AM
Sync not working JJB82 2011-2014 Mustang GT 3 09-22-2012 12:26 AM
A\C working then not working Bohogin Pre-2005 V6 Mustang 3 07-14-2011 01:44 PM
1976 ford mustang will not start, not headlights come on, it is not the battery, why? eifion Classic Mustangs 6 08-24-2009 03:12 AM
10:20 AM
