Are You Using the #47 Fuse Bypass Relay? - Mustang Evolution
Old 10-05-2014, 08:49 AM   #1
TedG's Avatar
I've been using mine for 6 months and it's been working fine. Sure beats physically pulling the fuse every week.
Fuse 47 By-Pass to Relay w/photos
Become an Organ Donor today: http://donatelife.net/register-now/
Save as many as 50 lives. Thanks.
TedG is offline   Reply With Quote
Old 10-05-2014, 12:35 PM   #2
iantrusive's Avatar
I want to do it, but I'm not going to without seeing a video of the process first.
iantrusive is offline   Reply With Quote
Old 10-05-2014, 03:30 PM   #3
MustangDawg's Avatar
^+1 A Vedic on YouTube we be great
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 10-05-2014, 03:32 PM   #4
^ Dang, sorry, I meant video.
Old 10-05-2014, 07:46 PM   #5
JoeyM91's Avatar
Tried to. Followed the instructions for the relay to the T but my car flipped the hell out when I started it with it in.
Bad idle, surging and a CEL. Obviously there's something wrong with the relay, but it's just not important enough to me to redo the whole thing.
Old 10-05-2014, 09:26 PM   #6
andrewheath09's Avatar
Ideally, doesn't the computer need to 'relearn' everything after the 47 fuse pull? Kinda like reloading a tune?
Sent from my SM-N900V using Mustang Evolution mobile app
andrewheath09 is offline   Reply With Quote
Old 10-05-2014, 09:57 PM   #7
bazinga11's Avatar
Here's an actual dyno of before and after 47 pull. Stock tune.
|| ~BlackOnBlack~ ||
Old 10-05-2014, 11:25 PM   #8
2011 Kona Blue's Avatar
|| ~BlackOnBlack~ ||
So you loss torque after pull fuse 47, wow
The Mustang Source Website is complete trash and the moderators are complete toolbags. TMS, Go F yourselves!
Old 10-05-2014, 11:29 PM   #9
JoeyM91's Avatar
Pulling the fuse then immediately on a dyno isn't a good idea. The whole system has to relearn the timing.
There's a sweet spot between the initial pull and when it starts to get "watered down".
Old 10-06-2014, 12:06 AM   #10
Midnight2012's Avatar
Doesn't the car just relearn by driving it anyway?
Midnight2012 is offline   Reply With Quote
Old 10-06-2014, 12:30 AM   #11
VIG
VIG's Avatar
Region: Delaware
Yeah, not only that, but the pre 47 pull stays higher for more time than the after 47 pull number.
There is a peak where it makes more horsepower, but for the great majority of the time the pre pull is making more power.
I'm really curious about if these would be the same results for the automatics, because I believe he drives a standard.
VIG is offline   Reply With Quote
Old 10-06-2014, 02:08 AM   #12
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Yeah the main reason for the Fuse 47 pull/relay is to clear the automatic's adative shifting, not really for power gains. Even with a tune, the adative shifting is still active and will cause some sluggish shifts after a while. Especially if you hit some slow-mocing traffic on occasion.
2012 Kona Blue 3.7L V6:
Fuse 47 Changeover to Relay DIY TedG Mustang DIY and Technical 15 06-08-2015 05:51 PM
Has anyone done the Fuse 47 Changeover to Relay TedG 2011-2014 V6 Mustang 11 06-25-2014 08:10 AM
Fuse 47 By-Pass to Relay w/photos TedG Mustang DIY and Technical 6 06-03-2014 07:40 PM
12V Relay Brake Bypass? ColeJohnson Mustang Audio & Video 8 01-26-2012 10:22 AM
Window fuse/relay jjpea 1996-2004 Mustang GT 1 03-13-2009 11:15 PM
10:39 PM
